Results 1 to 24 of 24
Thread: Teensyduino 1.54 Beta #10
    Administrator Paul's Avatar
    Oct 2012
    437
    Here is a tenth beta test for Teensyduino 1.54.
    Digital signatures have changed on Windows. Edge/IE might show a dire warning.
    Please click the site is safe button.
    Install into a clean copy of Arduino if you previously installed beta3 or beta4.
    Linux 32 bit:
    https://www.pjrc.com/teensy/td_154-b...nstall.linux32
    Linux 64 bit:
    https://www.pjrc.com/teensy/td_154-b...nstall.linux64
    Linux ARM:
    https://www.pjrc.com/teensy/td_154-b...stall.linuxarm
    Linux ARM64:
    https://www.pjrc.com/teensy/td_154-b...l.linuxaarch64
    MacOS 10.10 to 11.4:
    https://www.pjrc.com/teensy/td_154-b...S_Catalina.zip
    MacOS 10.8 to 10.14:
    https://www.pjrc.com/teensy/td_154-b...inoInstall.dmg
    Windows:
    https://www.pjrc.com/teensy/td_154-b...inoInstall.exe
    Changes since Teensyduino 1.54-beta9:
    Fix startup bug on Teensy 4
    Fix emulated EEPROM corruption bug on Teensy LC
    Fix typo in Audio TDM input documentation
    Update FlexIO_t4 (from KurtE)
    LittleFS persist ramdisk (Defragster)
    16,356
    Installed td 1.54 b10 on Win 10 over IDE 1.8.15 - Install good and no problems w/LittleFS LFSIntegrity onto T_4.0.
    Ramdisk note - Primary RAM / RAM1 is always zeroed on any restart to won't persist.
    Does work with DMAMEM / RAM2 : using LFSIntegrity {DMAMEM char buf[490000];} found an anomaly filling half of disk with a 'B'igfile then 'R'estart and 'b'igfile delete does a forever delete. using 256 byte blocks for file of size 223232 leaves something about the long file chain file unwritten. Will add .flush to see if it triggers safe use. Other I/O after 'B' is safe so not a lfs problem. Will move to T_4.1 PSRAM and try similar.
    >> .flush() didn't fix ?
    1,884
    Installed 1.54b10 over the top of 1.54b9 on Win10 Pro x64. No problems, but I haven't tried anything exotic.
    Pete
    New York
    8,403
    Ok - installed 1.54b10 over 154b9 on Win10 home x64 with no issues. This time I didn;t even get the windows block install screen
    Quote Originally Posted by defragster
    Tried to duplicate on a T4.0 and can't seem to duplicate the issue. Filled T4 more than half way, did a restart, then did the 'b' to delete and deleted without an issue.
    More testing on LittleFS issues in post starting at: https://forum.pjrc.com/threads/58033...l=1#post281594 and following.
    10,946
    Likewise I installed over B9 on 1.8.15 Windows 10 64 bit... No problems. And Yeah I did not get the windows block message. Hopefully that will be true for others who have not installed some of these betas as well.
    I have not tried the littlefs stuff, but have tried out a few usb host programs, with the Glorious Model O mouse. and the two programs still work... (Have not tried to debug yet on how to get this up to 1000fps yet)
    Will play with some other stuff, will try littleFS later if it looks like there is something to help to try to debug
    16,356
    UPDATE LittleFS working properly :: Did wipe of IDE 1.8.15 folder and fresh unZIP and TD 1.54b10 install and LittleFS is fine DMAMEM/RAM2 for RAM_DISK
    Not sure what caused the build error - but clean installs and all is well for T_4.0 and T_4.1 as tested for Persistent RamDisk on Warm Restart.
    ALSO: On Win10 download of Beta 10 I did not get a System warning 'BLOCKED' on the TeensyInstall.exe download, meant to add that to post #2.
    9,756
    I get this warning:
    C:\Arduino\hardware\teensy\avr\libraries\SdFat\src\ExFatLib\ExFatPartition.cpp: In member function 'bool ExFatPartition::freeChain(uint32_t)':
    C:\Arduino\hardware\teensy\avr\libraries\SdFat\src\ExFatLib\ExFatPartition.cpp:225:5: warning: 'next' may be used uninitialized in this function [-Wmaybe-uninitialized]
      225 |     if ((cluster + 1) != next || status == 0) {
    9,756
    Weird:
    I'm using Pauls Teensy4 + CS42448 board he sent me some time aqo for testing. No other Hardware, only well known, good active speakers.
    F_CPU 150MHz.
    I was listeing radio through my PC, using the board as external USB-Dac in this case (want to test something, later).
    Suddenly, without touching, without uploading something, just listening (in fact I was some meters away) it stopped working.
    USB seemed dead. Button worked, and the red LED was switched on after pressing it - but Teensy could not be found by the PC. USBView showed a corrupted descriptor.
    Disconnected, waited 10 minutes. Tried again. Nothing. Pressed button. Now, I was able to reflash, and it works again.
    What was this?
    9,756
    Unable to open COM16 for reboot request
      Windows Error Info: Zugriff verweigert
      more ideas... https://forum.pjrc.com/threads/40632?p=126667&viewfull=1#post126667
    Previously selected Teensy port is offline.
      2 other Teensy boards found.  Please select
      a Teensy from the Tools > Ports menu.
    The message is not correct. There is only one other Teensy connected (via usb Audio)
Name:	2021-06-24 09_25_02-sketch_jun23a _ Arduino 1.8.14.png
    May 2015
    USA
    1,094
    AudioProcessorUsage() has dropped from a correct .52 to .02.
    Continuous overruns (usb_audio_overrun_count) with pulseaudio/linux until I fix usb_audio.cpp with:
    if (f) {
                    int diff = AUDIO_BLOCK_SAMPLES/2 - (int)c;
                    if (diff > 0)
                            feedback_accumulator = 45.0 * (1<<24);       // faster
                            feedback_accumulator = 44.0 * (1<<24);       // slower
                    //feedback_accumulator += diff * 1;
    9,756
    @jonr: What Teensy model?
    And is it AudioInputUSB or AudioOutputUsb?
    @Paul: There is an open PR re: Muting Audio Usb
    May 2015
    USA
    1,094
    I'm using teensy 4 with AudioInputUSB.
    Of minor interest, I also tried gcc 10 with -fanalyzer. Everything I compiled except SDfat was warning free.
    3,459
    Following warning
    Using board 'teensy35' from platform in folder: C:\Users\zimmer\Documents\arduino-1.8.15\hardware\teensy\avr
    Using core 'teensy3' from platform in folder: C:\Users\zimmer\Documents\arduino-1.8.15\hardware\teensy\avr
    Warning: Board teensy:avr:teensy32 doesn't define a 'build.board' preference. Auto-set to: AVR_TEENSY32
    Detecting libraries used...
    Seems there is something missing
    9,756
    @Paul:
    We should update the USB Waveplayer example. It uses AudioOutputAnalog.. not a good choice for T4.
    Or, we should provide a clock source for USB. Should be doable on T4.
    I could add a dummy I2S Clock, if you want. But I need a reaction here. I'm not going to work on this without knowing wether it gets merged or not.
    Reminder: Teensy LC: Waveplayer needs an update.
    3,459
    I did once a audio object that was acting like a input/output object (was based on a timer similar to adc) only to handle updates.
    i.e. a dedicated clock module could be an option
    New York
    8,403
    Following warning
    Just looked in the boards.txt file for the teensy and it looks like its there.
    teensy31.build.board=TEENSY32
    So not sure why its not picking it up. Also I am not seeing that error when I compile for T3.5. I am using the latest Core
    3,459
    I see the warning for all teensies T32,T35,T36,T40,T41 (A1.8.15; TD154b10; Win10)
    by adding
    teensy32.build.board=TEENSY32
    Warning disappears
    New York
    8,403
    by adding
    Warning disappears
    Hmm - thats strange. I am using IDE 1.54 but with the latest core (as of yesterday for all the new fault handling) but I am not seeing any warnings. But to be honest I never saw that warning before today? I attaching my boards.txt file that got installed as part of 1.54.b10 install - can you give that a try. Trying to figure out if we have different boards files?
    boards.txt
    10,946
    @WMXZ and @mjs513 - I have not seen this warning. I am running 1.8.15 TD latest plus update cores...
    C:\arduino-1.8.15\arduino-builder -dump-prefs -logger=machine -hardware C:\arduino-1.8.15\hardware -hardware C:\Users\kurte\AppData\Local\Arduino15\packages -hardware C:\Users\kurte\Documents\Arduino\hardware -tools C:\arduino-1.8.15\tools-builder -tools C:\arduino-1.8.15\hardware\tools\avr -tools C:\Users\kurte\AppData\Local\Arduino15\packages -built-in-libraries C:\arduino-1.8.15\libraries -libraries C:\Users\kurte\Documents\Arduino\libraries -fqbn=teensy:avr:teensy31:usb=serial,speed=96,opt=o2std,keys=en-us -ide-version=10815 -build-path C:\Users\kurte\AppData\Local\Temp\arduino_build_293461 -warnings=all -build-cache C:\Users\kurte\AppData\Local\Temp\arduino_cache_958442 -verbose C:\arduino-1.8.15\examples\01.Basics\Blink\Blink.ino
    C:\arduino-1.8.15\arduino-builder -compile -logger=machine -hardware C:\arduino-1.8.15\hardware -hardware C:\Users\kurte\AppData\Local\Arduino15\packages -hardware C:\Users\kurte\Documents\Arduino\hardware -tools C:\arduino-1.8.15\tools-builder -tools C:\arduino-1.8.15\hardware\tools\avr -tools C:\Users\kurte\AppData\Local\Arduino15\packages -built-in-libraries C:\arduino-1.8.15\libraries -libraries C:\Users\kurte\Documents\Arduino\libraries -fqbn=teensy:avr:teensy31:usb=serial,speed=96,opt=o2std,keys=en-us -ide-version=10815 -build-path C:\Users\kurte\AppData\Local\Temp\arduino_build_293461 -warnings=all -build-cache C:\Users\kurte\AppData\Local\Temp\arduino_cache_958442 -verbose C:\arduino-1.8.15\examples\01.Basics\Blink\Blink.ino
    Using board 'teensy31' from platform in folder: C:\arduino-1.8.15\hardware\teensy\avr
    Using core 'teensy3' from platform in folder: C:\arduino-1.8.15\hardware\teensy\avr
    Wonder if you are running a modified boards.txt to support MTP with Serial? and/or using boards.local.txt?
    3,459
    I run boards with MTP serial text before T4.1
    will later try without modifications
    something like
    menu.usb=USB Type
    menu.speed=CPU Speed
    menu.opt=Optimize
    menu.keys=Keyboard Layout
    teensy41.menu.usb.mtpserial=MTP Disk Serial (Experimental)
    teensy41.menu.usb.mtpserial.build.usbtype=USB_MTPDISK_SERIAL
    teensy40.menu.usb.mtpserial=MTP Disk Serial (Experimental)
    teensy40.menu.usb.mtpserial.build.usbtype=USB_MTPDISK_SERIAL
    teensy36.menu.usb.mtpserial=MTP Disk SERIAL (Experimental)
    teensy36.menu.usb.mtpserial.build.usbtype=USB_MTPDISK_SERIAL
    teensy35.menu.usb.mtpserial=MTP Disk SERIAL (Experimental)
    teensy35.menu.usb.mtpserial.build.usbtype=USB_MTPDISK_SERIAL
    teensy41.name=Teensy 4.1
    4,270
    @Paul:
    It would be nice if all of the audio examples that access either the flash memory or the SD card had #ifdef's so the correct SPI pins are selected on the Teensy 4.0/4.1 compared to the Teensy 3.2/3.5/3.6. Even if they didn't have #ifdef's, add comments about the Teensy 4.0/4.1 defaults. It gets depressing to answer the same old question about using the examples time and time again.
    3,459
    Found it:
    I used
    teensy32.menu.usb.mtpserial=MTP Disk SERIAL (Experimental)
    teensy32.menu.usb.mtpserial.build.usbtype=USB_MTPDISK_SERIAL
    and not
    teensy31.menu.usb.mtpserial=MTP Disk SERIAL (Experimental)
    teensy31.menu.usb.mtpserial.build.usbtype=USB_MTPDISK_SERIAL
    so Arduino was looking for teensy32, but in boards.txt there is only teensy31
    will update githup
    9,756
    if (f) {
                    if (diff > 0)
    jonr,
    i printed the overuns on with my win10 pc.
    there are a few on start, but that's all.
    unfortunately, i can't test with a linux box.
    May 2015
    USA
    1,094
    I understand, this one is going to be difficult to duplicate. But think about the control logic - there is no reason to keep adding more and more to the feedback_accumulator and then slowly decrease it. Why "diff * 1" for a bin point 24 number? And note that sometimes the PC saves power by sending no audio - the feedback_accumulator shouldn't increase to absurd values that take a long time to come down to a reasonable value (see "+= 3500" code).
    On the other hand, such a change would need testing on all platforms....
