Results 1 to 2 of 2
Thread: Teensy4.1 deviation wire.setClock(1MHz) / measured SCL-Clock-frequency 0,788MHz
    Hi everybody,
    I did some tests with a teensy 4.1 and a MCP23017 IO-expander.
    I just did a high-speed toggling of a pin with this code:
    #include "Adafruit_MCP23017.h"
    Adafruit_MCP23017 mcp;
    unsigned long I2C_frequency;
      Serial.println("Setup-Start");
      Wire.begin();
      mcp.begin(0x27);        // first call mcp.begin
      I2C_frequency = 1000000;
      Wire.setClock(I2C_frequency); // after the mcp.begin setClock
      Serial.print("Wire.setClock(");
      Serial.print(I2C_frequency);
      Serial.println(")");
      mcp.pinMode(7, OUTPUT);
      Serial.println("IO-pin 7 as OUTPUT");
      Serial.println("start toggling now...");
      mcp.digitalWrite(7, HIGH);
      //delay(100);
      mcp.digitalWrite(7, LOW);
    wire.setclock(1 MHz) but with my DSO I measure only 0,788 MHz.
    This is a too big deviation to be a rounding-error of a timing-pre-scaler or something similar.
    So why is this?
    best regards Stefan
    25,066
    What pullup resistors did you use?
    If the waveform rise times are slow, the hardware automatically waits.
