Results 1 to 2 of 2
Thread: Which DISPLAY_ILI9341_TOUCH to use?
    In February 2021, I ordered a DISPLAY_ILI9341_TOUCH and designed a PCB for my project around that. Now I would like to buy a few more, but I see that that part number has been replaced by the DISPLAY_ILI9341_TOUCH_28 and DISPLAY_ILI9341_TOUCH_32. Do either of these two match up with the previous DISPLAY_ILI9341_TOUCH? I was specifically wondering about outside dimensions, connector placement, and mounting hole placement.
    On the store webpage (https://www.pjrc.com/store/display_ili9341_touch.html), there is only one picture showing dimensions, so I'm not sure if it just hasn't been updated, or if both of those displays have the same board dimensions.
    9,577
    I am guessing you probably have the 28... (2.8"), I think the new one is the 32(3.2")
    The Dimensions in that listing are for the 2.8".
    Dimensions
    The active screen area is approximately 2.8 inches diagonal.
