Results 1 to 1 of 1
Thread: Best practices for accessing the USB Host pads on a Teensy 4.0
    Oct 2019
    175
    I need to shrink a design that uses a Teensy 4.1. I need to change my PCB from using the through-hole header on the Teensy 4.1, to linking the Teensy 4.0 solder pads to a new PCB. I'm looking for best practices and links to good projects. Any help?
    [Edit] Pogo pads are a better solution.
