I had a Teensy 3.6 program that (among other things) displayed an image from an SD card on the Teensy touchscreen. I switched to Teensy 4.1 and can't get the libraries to work together. In particular, I was using Adafruit_ImageReader to load the image, but it needs the Adafruit fork of SdFat, which doesn't compile on 4.1. The stock SdFat library compiles, but the image reader doesn't work with it.
Here's the code that fails to compile:
To summarize, I'm looking for straightforward libraries to use the Teensy 4.1 and Teensy touchscreen, that support loading images, graphics operations, and touchscreen operations. I'm not particularly attached to the libraries above so I'm happy to switch. I need a fast SD card library for other reasons so I think I want to stick with SdFat.
Thanks,
Ken
#include <Adafruit_GFX.h> // Core graphics library
#include <SdFat.h> // SD card & FAT filesystem library
#include <Adafruit_ILI9341.h>
#include <Adafruit_ImageReader.h> // Image-reading functions
void setup() {}
void loop() {}
Thanks,
Ken
