bungernaut
I am trying get the EthernetModbusServerLED example to run on the Teensy4.1.
The example code is included in the ModbusTPC library: https://github.com/arduino-librarie...dbusServerLED/EthernetModbusServerLED.ino#L16
The only change I think is required is this line to NativeEthernet.h
I am using v1.0.5 of ArduinoModbus and have tried other versions.
The compilation errors on
C:\Users\bung\Documents\Arduino\libraries\ArduinoModbus\src\libmodbus/modbus.c:162: undefined reference to `delayMicroseconds'
Here is the offending line https://github.com/arduino-librarie...2f977a2a0318d2f15/src/libmodbus/modbus.c#L162
In file included from C:\Users\bung\Documents\Arduino\libraries\ArduinoModbus\src\ModbusRTUClient.cpp:27:0:
C:\Users\bung\Documents\Arduino\libraries\ArduinoModbus\src\ModbusRTUClient.h: In constructor 'ModbusRTUClientClass::ModbusRTUClientClass(RS485Class&)':
C:\Users\bung\Documents\Arduino\libraries\ArduinoModbus\src\ModbusRTUClient.h:44:25: warning: 'ModbusRTUClientClass::_rs485' will be initialized after [-Wreorder]
RS485Class* _rs485 = &RS485;
C:\Users\bung\Documents\Arduino\libraries\ArduinoModbus\src\ModbusRTUClient.cpp:35:36: warning: base 'ModbusClient' [-Wreorder]
_rs485(&rs485), ModbusClient(1000)
C:\Users\bung\Documents\Arduino\libraries\ArduinoModbus\src\ModbusRTUClient.cpp:34:1: warning: when initialized here [-Wreorder]
ModbusRTUClientClass::ModbusRTUClientClass(RS485Class& rs485) :
C:\Users\bung\Documents\Arduino\libraries\ArduinoModbus\src\libmodbus\modbus.c: In function '_sleep_response_timeout':
C:\Users\bung\Documents\Arduino\libraries\ArduinoModbus\src\libmodbus\modbus.c:161:5: warning: implicit declaration of function 'delay' [-Wimplicit-function-declaration]
delay(ctx->response_timeout.tv_sec * 1000);
C:\Users\bung\Documents\Arduino\libraries\ArduinoModbus\src\libmodbus\modbus.c:162:5: warning: implicit declaration of function 'delayMicroseconds' [-Wimplicit-function-declaration]
delayMicroseconds(ctx->response_timeout.tv_usec);
C:\Users\bung\AppData\Local\Temp\arduino_build_329130\libraries\ArduinoModbus\libmodbus\modbus.c.o: In function `_sleep_response_timeout':
Error compiling for board Teensy 4.1.
