Results 1 to 12 of 12
Thread: Teensy 4.1 is returning in July (2021)
    25,092
    Good news. RT1062 chips finally arrived from NXP today. We'll have Teensy 4.1 back in stock by early July.
    Normally production takes 3 weeks, which would put the return date around July 12. But we're hoping to expedite and get Teensy 4.1 back in stock maybe as early as July 6.
    Some distributors still have stock, though all their levels are low. I've been trying to keep a list updated on the Teensy 4.1 page.
    15,120
    That's is great news! Finally something something sooner that (re)promised?
    And until then any new Bootloader code may be ready?
    Germany
    9,349
    Would be cool for the FS in Flash..
    25,092
    I am indeed working on a bootloader update, but it definitely will not ship on the Teensy 4.1 boards next month.
    New York
    7,558
    That must be quite a relief Paul. Good luck and congratulations on getting your parts in
    Jan 2015
    UK
    174
    Hi Paul, do you know when Sparkfun will have stock of the T4.1 ? Their webpage did say 20th July but that has now been removed.
    25,092
    I'm reluctant to speak for Sparkfun. Even if I did have some insight, the situation can change rapidly.
    But I can speak for PJRC. I can tell you we put a 1st moderately sized batch of Teensy 4.1 into production on June 23. Some were completed early and we started shipping backorders on June 30 and July 1-2. On July 6, we started showing it in stock on the PJRC website. The majority of that first batch shipped between July 6-16. As we shipped those, new orders came in from almost every distributor. We sent many to Sparkfun and a good number all the others. Today we're allocating the last part of that 1st batch (only a small number will remain here for orders) to Sparkfun and pin soldering. Whether the Teensy 4.1s we're shipping this week will be enough to clear all of Sparkfun's backlog (early next week), or if they get more orders before those arrive, I can not say. The best PJRC can do is manufacture, test, package and ship as fast as our process allows. That's what we're doing.
    I can also tell you we put a 2nd large batch went into production on July 9. Normal production takes 3 weeks. So by the first & second week of August, we should have plenty to clear all of the non-pins backlog. I'm hopeful we may start to get some of that 2nd batch early, in which case we'll start shipping them on July 26. But when some are ready early, it's usually only a small part of the batch. Then the rest gets completed over the next 3-4 weeks, with approximately equal portions of the batch ready each week.
    Soldering of the pins is starting this week. It's a very labor intensive process. Only so many can be soldered each week. We probably won't manage to clear all the soldered pins backlog until September.
    Jul 2020
    1,258
    Here's a crazy(?) thought: Low temperature solder paste squeegeed on the holes for the pins, oven reflow... Header
    pins are unlikely to see any high temperatures, and a low temperature oven cycle is unlikely to disturb
    the existing components.
    Germany
    9,349
    I've seen users with 100Watt irons gluing wires to pins..
    Jan 2015
    UK
    174
    Sparkfun have T4.1 in stock now. Be quick !!
    25,092
    Sparkfun has Teensy 4.1 in stock again.
    https://www.sparkfun.com/products/16771
    I'm a bit out of touch with current production techniques but are press-fit header pins still a thing ?
    I always buy teensies without pins as I like the option to mount them either way up, but I have a larger build coming up and can see the advantage. I also find it useful to save time by soldering only the pins I'm using.
