/* Audio Library for Teensy 3.X
* Copyright (c) 2014, Paul Stoffregen, paul@pjrc.com
* Development of this audio library was funded by PJRC.COM, LLC by sales of
* Teensy and Audio Adaptor boards. Please support PJRC's efforts to develop
* open source software by purchasing Teensy or other PJRC products.
* THE SOFTWARE.
#ifndef play_sd_raw_h
#define play_sd_raw_h
#include "Arduino.h"
#include "AudioStream.h"
#include "SD.h"
class AudioPlaySdRaw : public AudioStream
public:
AudioPlaySdRaw(void) : AudioStream(0, NULL) { begin(); setSpeed(1.0f);}
void begin(void);
void setSpeed(float speed)
if (speed < 0)
playback_direction = -1;
speed = speed * -1;
playback_direction = 1;
if(speed < 0.25)
speed = 0.25f;
else if(speed > 4)
speed = 4.0f;
playback_speed = speed;
playback_speed_inv = 1.0f / playback_speed;
bool play(const char *filename);
bool play(const char *filename, float startPoint, float endPoint);
void stop(void);
bool isPlaying(void) { return playing; }
uint32_t positionMillis(void);
uint32_t lengthMillis(void);
virtual void update(void);
private:
int32_t millisToByte(float time_ms);
File rawfile;
int32_t file_size;
volatile int32_t file_offset;
volatile bool playing;
float playback_speed;
float playback_speed_inv;
int16_t playback_direction;
int16_t calc_buffer[AUDIO_BLOCK_SAMPLES * 5];
int32_t buffer_index;
int32_t endpoint_sample;
* THE SOFTWARE.
#include <Arduino.h>
#include "play_sd_raw.h"
#include "spi_interrupt.h"
void AudioPlaySdRaw::begin(void)
playing = false;
file_offset = 0;
file_size = 0;
buffer_index = 0;
endpoint_sample = 0;
bool AudioPlaySdRaw::play(const char *filename)
stop();
#if defined(HAS_KINETIS_SDHC)
if (!(SIM_SCGC3 & SIM_SCGC3_SDHC)) AudioStartUsingSPI();
#else
__disable_irq();
rawfile = SD.open(filename);
__enable_irq();
if (!rawfile) {
//Serial.println("unable to open file");
if (!(SIM_SCGC3 & SIM_SCGC3_SDHC)) AudioStopUsingSPI();
#else
return false;
file_size = rawfile.size();
if(playback_direction > 0)
file_offset = 0;
endpoint_sample = file_size;
file_offset = file_size;
//Serial.println("able to open file");
playing = true;
return true;
bool AudioPlaySdRaw::play(const char *filename, float startPoint, float endPoint)
stop();
#else
__disable_irq();
__enable_irq();
if (!rawfile) {
#else
return false;
// endPoint should be greater than startPoint
if(startPoint <= 0)
file_offset = 0;
file_offset = millisToByte(startPoint);
if(file_offset >= file_size)
playing = false;
return false;
endpoint_sample = millisToByte(endPoint);
if(endpoint_sample >= file_size)
if(endpoint_sample <= file_offset)
playing = false;
return false;
rawfile.seek(file_offset);
//reverse startPoint should be greater than endPoint
if(startPoint <= 0)
playing = false;
return false;
if(endpoint_sample < 0)
if(endpoint_sample >= file_offset)
playing = false;
return false;
playing = true;
return true;
void AudioPlaySdRaw::stop(void)
__disable_irq();
if (playing) {
playing = false;
__enable_irq();
rawfile.close();
#else
__enable_irq();
void AudioPlaySdRaw::update(void)
unsigned int i, n;
audio_block_t *block;
// only update if we're playing
if (!playing) return;
// allocate the audio blocks to transmit
block = allocate();
if (block == NULL) return;
if (rawfile.available() && file_offset < endpoint_sample)
//we must have at least AUDIO_BLOCK_SAMPLES samples in the buffer
while(buffer_index < AUDIO_BLOCK_SAMPLES)
n = rawfile.read(block->data, AUDIO_BLOCK_SAMPLES*2);
file_offset += n;
for (i = n/2; i < AUDIO_BLOCK_SAMPLES; i++)
block->data[i] = 0;
for (i = 0; i < AUDIO_BLOCK_SAMPLES; i++)
block->data[i] = 0;
//here we calculate the buffer
unsigned int samples_to_write = int((float)AUDIO_BLOCK_SAMPLES * playback_speed_inv);
for(i = 0; i < samples_to_write; i++)
calc_buffer[i + buffer_index] = block->data[int((float)i * playback_speed)];
buffer_index += samples_to_write;
//read from buffer the samples to transmit and transmit
for(i = 0; i < AUDIO_BLOCK_SAMPLES; i++)
block->data[i] = calc_buffer[i];
transmit(block);
//shift the buffer and update buffer_index
for(i = 0; i < (AUDIO_BLOCK_SAMPLES * 4); i++)
calc_buffer[i] = calc_buffer[i + AUDIO_BLOCK_SAMPLES];
buffer_index -= AUDIO_BLOCK_SAMPLES;
rawfile.close();
#else
playing = false;
// reverse direction
if (file_offset >= endpoint_sample)
//we have to be sure not to read data before file zero-position
int seek_point = file_offset - (AUDIO_BLOCK_SAMPLES * 2);
if(file_offset >= endpoint_sample)
i = 0;
while(seek_point < 0)
block->data[i] = 0;
i++;
seek_point++;
seek_point++;
rawfile.seek(seek_point);
if(i == 0)
int16_t temp_buffer[AUDIO_BLOCK_SAMPLES];
n = rawfile.read(temp_buffer, AUDIO_BLOCK_SAMPLES*2);
for(int j = i; j < AUDIO_BLOCK_SAMPLES; j++)
block->data[j] = temp_buffer[j - i];
file_offset -= AUDIO_BLOCK_SAMPLES * 2;
block->data[i] = 0;
//here we calculate the buffer, also reversing the samples
calc_buffer[i + buffer_index] = block->data[AUDIO_BLOCK_SAMPLES - int((float)i * playback_speed) - 1];
transmit(block);
rawfile.close();
#else
playing = false;
release(block);
#define B2M (uint32_t)((double)4294967296000.0 / AUDIO_SAMPLE_RATE_EXACT / 2.0) // 97352592
uint32_t AudioPlaySdRaw::positionMillis(void)
return ((uint64_t)file_offset * B2M) >> 32;
uint32_t AudioPlaySdRaw::lengthMillis(void)
return ((uint64_t)file_size * B2M) >> 32;
int32_t AudioPlaySdRaw::millisToByte(float time_ms)
return (AUDIO_SAMPLE_RATE_EXACT * time_ms * 0.002f);
AudioPlaySdRaw playSdRaw1; //xy=266,236
AudioFilterStateVariable filter1; //xy=440,245.55556106567383
AudioOutputI2S i2s1; //xy=659.1110992431641,234.0000057220459
AudioConnection patchCord1(playSdRaw1, 0, filter1, 0);
AudioConnection patchCord2(filter1, 0, i2s1, 0);
AudioConnection patchCord3(filter1, 0, i2s1, 1);
//teensy 4.1 has builtin soundcard
//if using audio shield soundcard, look into the examples for the correct setup
#define SDCARD_CS_PIN BUILTIN_SDCARD
AudioMemory(250);
//add a filter in case playing at higher speed
filter1.frequency(15000);
if (!(SD.begin(SDCARD_CS_PIN)))
Serial.println("Unable to access SD card!");
Serial.println("Play from 1s to 5s at 1x speed");
playSdRaw1.setSpeed(1.0);
playSdRaw1.play("my_file.RAW", 1000.0, 5000.0);
while (playSdRaw1.isPlaying())
//wait
Serial.println("Play from 5s to 1s at 1x speed");
playSdRaw1.setSpeed(-1.0);
playSdRaw1.play("my_file.RAW", 5000.0, 1000.0);
//wait
Serial.println("Play from 1s to 5s at 2x speed");
playSdRaw1.setSpeed(2.0);
//wait
//LIBS
#include <MIDI.h>
#include <LiquidCrystal_I2C.h>
#include <Encoder.h>
//CLASSES
LiquidCrystal_I2C lcd(0x27, 16, 2); // I2C address 0x27, 16 column and 2 rows
Encoder myEnc(4, 5);
MIDI_CREATE_INSTANCE(HardwareSerial, Serial1, MIDI);
AudioPlaySdWav playSdWav1;
AudioPlaySdWav playSdWav4;
AudioPlaySdWav playSdWav3;
AudioPlaySdWav playSdWav2;
AudioPlaySdWav playSdWav9;
AudioPlaySdWav playSdWav8;
AudioPlaySdWav playSdWav15;
AudioPlaySdWav playSdWav6;
AudioPlaySdWav playSdWav5;
AudioPlaySdWav playSdWav7;
AudioPlaySdWav playSdWav14;
AudioPlaySdWav playSdWav16;
AudioPlaySdWav playSdWav11;
AudioPlaySdWav playSdWav12;
AudioPlaySdWav playSdWav13;
AudioPlaySdWav playSdWav10;
AudioMixer4 mixer7;
AudioMixer4 mixer3;
AudioMixer4 mixer4;
AudioMixer4 mixer6;
AudioMixer4 mixer8;
AudioMixer4 mixer2;
AudioMixer4 mixer9;
AudioMixer4 mixer1;
AudioMixer4 mixer5;
AudioMixer4 mixer10;
AudioConnection patchCord1(playSdWav1, 0, mixer4, 0);
AudioConnection patchCord2(playSdWav1, 1, mixer6, 0);
AudioConnection patchCord3(playSdWav4, 0, mixer4, 3);
AudioConnection patchCord4(playSdWav4, 1, mixer6, 3);
AudioConnection patchCord5(playSdWav3, 0, mixer4, 2);
AudioConnection patchCord6(playSdWav3, 1, mixer6, 2);
AudioConnection patchCord7(playSdWav2, 0, mixer4, 1);
AudioConnection patchCord8(playSdWav2, 1, mixer6, 1);
AudioConnection patchCord9(playSdWav9, 0, mixer2, 0);
AudioConnection patchCord10(playSdWav9, 1, mixer8, 0);
AudioConnection patchCord11(playSdWav8, 0, mixer3, 3);
AudioConnection patchCord12(playSdWav8, 1, mixer7, 3);
AudioConnection patchCord13(playSdWav15, 0, mixer1, 2);
AudioConnection patchCord14(playSdWav15, 1, mixer9, 2);
AudioConnection patchCord15(playSdWav6, 0, mixer3, 1);
AudioConnection patchCord16(playSdWav6, 1, mixer7, 1);
AudioConnection patchCord17(playSdWav5, 0, mixer3, 0);
AudioConnection patchCord18(playSdWav5, 1, mixer7, 0);
AudioConnection patchCord19(playSdWav7, 0, mixer3, 2);
AudioConnection patchCord20(playSdWav7, 1, mixer7, 2);
AudioConnection patchCord21(playSdWav14, 0, mixer1, 1);
AudioConnection patchCord22(playSdWav14, 1, mixer9, 1);
AudioConnection patchCord23(playSdWav16, 0, mixer1, 3);
AudioConnection patchCord24(playSdWav16, 1, mixer9, 3);
AudioConnection patchCord25(playSdWav11, 0, mixer2, 2);
AudioConnection patchCord26(playSdWav11, 1, mixer8, 2);
AudioConnection patchCord27(playSdWav12, 0, mixer2, 3);
AudioConnection patchCord28(playSdWav12, 1, mixer8, 3);
AudioConnection patchCord29(playSdWav13, 0, mixer1, 0);
AudioConnection patchCord30(playSdWav13, 1, mixer9, 0);
AudioConnection patchCord31(playSdWav10, 0, mixer2, 1);
AudioConnection patchCord32(playSdWav10, 1, mixer8, 1);
AudioConnection patchCord33(mixer7, 0, mixer10, 1);
AudioConnection patchCord34(mixer3, 0, mixer5, 1);
AudioConnection patchCord35(mixer4, 0, mixer5, 0);
AudioConnection patchCord36(mixer6, 0, mixer10, 0);
AudioConnection patchCord37(mixer8, 0, mixer10, 2);
AudioConnection patchCord38(mixer2, 0, mixer5, 2);
AudioConnection patchCord39(mixer9, 0, mixer10, 3);
AudioConnection patchCord40(mixer1, 0, mixer5, 3);
AudioConnection patchCord41(mixer5, 0, i2s1, 0);
AudioConnection patchCord42(mixer10, 0, i2s1, 1);
//PINS
#define SDCARD_CS_PIN 10
#define SDCARD_MOSI_PIN 7
#define SDCARD_SCK_PIN 13
#define e1r 14
#define e1g 15
#define e1sw 3
//VARS
char filechar[13] = "BANK02/00.WAV";
char *MENU [] = {"Channel","Mode","Bank","Save & Exit"};
int globalsettings[]={10,1,2,0};//channel,mode,bank,smth
float slotvol[]={0.75,0.75,0.75,0.75,0.75,0.75,0.75,0.75,0.75,0.75,0.75,0.75,0.75,0.75,0.75,0.75,};
byte slot[16]={0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15};
long oldPosition = 999;
long newPosition = 666;
byte i=0;
bool e1press=false;
pinMode(e1r,OUTPUT);
pinMode(e1g,OUTPUT);
pinMode(e1sw,INPUT_PULLUP);
lcd.init(); // initialize the lcd
lcd.backlight();
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("Press and hold");
lcd.setCursor(0, 1);
lcd.print("for settings");
//delay(500);
Serial.begin(57600);
MIDI.begin(MIDI_CHANNEL_OMNI);
AudioMemory(32);
sgtl5000_1.enable();
sgtl5000_1.volume(0.5);
SPI.setMOSI(SDCARD_MOSI_PIN);
SPI.setSCK(SDCARD_SCK_PIN);
while (1)
lcd.clear();
lcd.print("SD FAIL");
lcd.clear();
if (digitalRead(e1sw)==LOW)
settings();
void settings()
while(true)
newPosition = myEnc.read()/2;
if (newPosition != oldPosition)
oldPosition = newPosition;
i = oldPosition;
if(i>=5)
i=0;
myEnc.write(0);
if(i==0||i==1)
lcd.clear();
lcd.setCursor(1, 0);
lcd.print(MENU[0]);
lcd.setCursor(14, 0);
lcd.print(globalsettings[0]);
lcd.setCursor(1, 1);
lcd.print(MENU[1]);
switch(globalsettings[1])
case 0:
lcd.setCursor(13, 1);
lcd.print("USB");
case 1:
lcd.setCursor(12, 0);
lcd.print("MIDI");
else if(i==2||i==3)
lcd.clear();
lcd.print(MENU[2]);
lcd.print(MENU[3]);
lcd.setCursor(0, i%2 );
lcd.write(0x7E);//arrow char
if(MIDI.read())
byte type = MIDI.getType();//type
if(type==0x90)
case 0:
usbmidi();
case 1:
dinmidi();
i = oldPosition;
if(i>=16)
i=0;
myEnc.write(0);
if(i<0)
i=15;
myEnc.write(i*2);
lcd.clear();
lcd.print("Slot ");
lcd.write(0x7E);
lcd.print(i);
lcd.print(" ");
lcd.print("Spl ");
lcd.print(slot[i]);
if (digitalRead(e1sw)==LOW&&e1press==false)
e1press=true;
digitalWrite(e1r , HIGH);
lcd.setCursor(0, 5);
lcd.print(" ");
slotMenuSelect(i);
lcd.print(" ");
myEnc.write(i*2);
delay(200);
e1press=false;
//digitalWrite(e1r , LOW);
//digitalWrite(e1g , LOW);
void slotMenuSelect(byte slot_number)
byte n;
lcd.write(0x7E);
lcd.print("Sample ");
myEnc.write(0);
while(digitalRead(e1sw)==LOW&&e1press==true)
delay(200);
//wait for depress
e1press=false;
while(true)
n = oldPosition;
if(n>=6)
n=0;
myEnc.write(0);
if(n<0)
n=5;
myEnc.write(5*2);
switch(n)
case 0:
lcd.write(0x7E);
case 1:
lcd.write(0x7E);
lcd.print("Vol ");
case 2:
lcd.write(0x7E);
lcd.print("Start ");
case 3:
lcd.write(0x7E);
lcd.print("End ");
case 4:
lcd.write(0x7E);
lcd.print("Rev ");
case 5:
lcd.print("Back ");
e1press=true;
switch(n)
case 0:
slotSampleSelect(slot_number);
lcd.write(0x7E);
delay(200);
case 1:
//slotSampleSelect();
lcd.write(0x7E);
lcd.print("WIP_Back ");
case 2:
lcd.write(0x7E);
case 3:
lcd.write(0x7E);
case 4:
lcd.write(0x7E);
case 5:
return 0;
if (digitalRead(e1sw)==HIGH)
e1press=false;
void slotSampleSelect(const byte slot_number)
byte n=0;
myEnc.write(0);
lcd.write(0x7E);
lcd.setCursor(8, 1);
lcd.print(slot[slot_number]);
//wait for depress
delay(200);
e1press=false;
while (true)
if(myEnc.read()<0)
myEnc.write(99*2);
n = oldPosition;
Serial.print(n);
if(n>99)
n=0;
myEnc.write(0);
lcd.print(n);
lcd.print(" ");
playPlayer(n,slot_number);
if(digitalRead(e1sw)==LOW&&e1press==false)
slot[slot_number]=n;
lcd.setCursor(12,0);
lcd.print(n);
lcd.print(" ");
return 0;
void usbmidi()
Serial.println(usbMIDI.getChannel());
Serial.println(usbMIDI.getType(),HEX);
Serial.print(usbMIDI.getData1(),HEX);
Serial.print(" HEX| ");
Serial.print(usbMIDI.getData1(),DEC);
Serial.print(" DEC| ");
Serial.print(usbMIDI.getData2(),HEX);
Serial.print(usbMIDI.getData2(),DEC);
byte type = usbMIDI.getType();
byte data1 = usbMIDI.getData1();
byte data2 = usbMIDI.getData2();
if(usbMIDI.getType()==0x90&&usbMIDI.getData1()==0x24)
playPlayer(slot[0],0);
if(usbMIDI.getType()==0x90&&usbMIDI.getData1()==0x25)
playPlayer(slot[1],1);
if(usbMIDI.getType()==0x90&&usbMIDI.getData1()==0x26)
//playFile(slot[2],2);
if(usbMIDI.getType()==0x90&&usbMIDI.getData1()==0x27)
//playFile(slot[3],3);
if(usbMIDI.getType()==0x90&&usbMIDI.getData1()==0x28)
//playFile(slot[4],4);
if(usbMIDI.getType()==0x90&&usbMIDI.getData1()==0x29)
//playFile(slot[5],5);
if(usbMIDI.getType()==0x90&&usbMIDI.getData1()==0x2A)
//playFile(slot[6],6);
if(usbMIDI.getType()==0x90&&usbMIDI.getData1()==0x2B)
//playFile(slot[7],7);
if(usbMIDI.getType()==0x90&&usbMIDI.getData1()==0x2C)
//playFile(slot[8],8);
if(usbMIDI.getType()==0x90&&usbMIDI.getData1()==0x2D)
//playFile(slot[9],9);
if(usbMIDI.getType()==0x90&&usbMIDI.getData1()==0x2E)
//playFile(slot[10],10);
if(usbMIDI.getType()==0x90&&usbMIDI.getData1()==0x2F)
//playFile(slot[11],11);
if(usbMIDI.getType()==0x90&&usbMIDI.getData1()==0x30)
//playFile(slot[12],12);
if(usbMIDI.getType()==0x90&&usbMIDI.getData1()==0x31)
//playFile(slot[13],13);
if(usbMIDI.getType()==0x90&&usbMIDI.getData1()==0x32)
//playFile(slot[14],14);
if(usbMIDI.getType()==0x90&&usbMIDI.getData1()==0x33)
// playFile(slot[15],15);
void playPlayer(const byte sample_num, const byte player_num)
byte x = (sample_num/10)%10;
byte y = (sample_num)%10;
filechar[7]='0'+x;
filechar[8]='0'+y;
//Serial.println(filechar);
switch(player_num)
case 0:
//playWav1.stop();
playSdWav1.play(filechar);
case 1:
//playWav2.stop();
playSdWav2.play(filechar);
case 2:
//playWav3.stop();
playSdWav3.play(filechar);
case 3:
//playWav4.stop();
playSdWav4.play(filechar);
case 4:
//playWav5.stop();
playSdWav5.play(filechar);
case 5:
//playWav6.stop();
playSdWav6.play(filechar);
case 6:
//playWav7.stop();
playSdWav7.play(filechar);
case 7:
//playWav8.stop();
playSdWav8.play(filechar);
case 8:
//playWav9.stop();
playSdWav9.play(filechar);
case 9:
//playWav10.stop();
playSdWav10.play(filechar);
case 10:
//playWav11.stop();
playSdWav11.play(filechar);
case 11:
//playWav12.stop();
playSdWav12.play(filechar);
case 12:
//playWav13.stop();
playSdWav13.play(filechar);
case 13:
//playWav14.stop();
playSdWav14.play(filechar);
case 14:
//playWav15.stop();
playSdWav15.play(filechar);
case 15:
//playWav16.stop();
playSdWav16.play(filechar);
void dinmidi()
Serial.println(MIDI.getChannel());
Serial.println(MIDI.getType(),HEX);
Serial.print(MIDI.getData1(),HEX);
Serial.print(MIDI.getData1(),DEC);
Serial.print(MIDI.getData2(),HEX);
Serial.print(MIDI.getData2(),DEC);
// if(type==0x90)
byte data1 = MIDI.getData1();//note
byte data2 = MIDI.getData2();//velo
switch(data1)
case 0x24:
case 0x25:
case 0x26:
playPlayer(slot[2],2);
case 0x27:
playPlayer(slot[3],3);
case 0x28:
playPlayer(slot[4],4);
case 0x29:
playPlayer(slot[5],5);
case 0x2A:
playPlayer(slot[6],6);
case 0x2B:
playPlayer(slot[7],7);
case 0x2C:
playPlayer(slot[8],8);
case 0x2D:
playPlayer(slot[9],9);
case 0x2E:
playPlayer(slot[10],10);
case 0x2F:
playPlayer(slot[11],11);
case 0x30:
playPlayer(slot[12],12);
case 0x31:
playPlayer(slot[13],13);
case 0x32:
playPlayer(slot[14],14);
case 0x33:
playPlayer(slot[15],15);
