Does ofstream in SDFat work with Fat32
bvernham
I have used SDFat with Fat and ofstream with never a hick up.
Try to copy the same code to the Teesnsy 4.1 and nothing.
I can open, read/write flawlessly with File32 (for some reason when I want to the Beta.10 and 1.8.15 File no longer exists which I do not care because the Teensy has plenty to handle Fat32.
Anyways, compile the code, file never opens.
No compiler error or warning.
Thoughts?
Bruce
Thoughts?
Bruce
You probably have to enable it in the config.h file like this:
 * Set INCLUDE_SDIOS nonzero to include sdios.h in SdFat.h.
 * sdios.h provides C++ style IO Streams.
#define INCLUDE_SDIOS 1
By default I think it is set to 0, at least mine was. After I changed it to 1 I was able to use cout and cin.
#include <SdFat.h>
#include <sdios.h>
I always include sdio.h.
Do I need to do both?
Like I said with the DUE, did the above and work as expected.
Bruce
Serial works great!
I am talking about writing log files to an SD card.
Thanks for the help anyways.
Bruce
Serial works great!
Bruce
Sorry miss understood what you were asking thought we were still taking about the question you asked on ofstream.
ofstream Class Reference
Detailed Description
file output stream.
The documentation for this class was generated from the following file:
ArduinoSdFat/libraries/SdFat/src/iostream/fstream.h
For your reference.
Brue
