Results 1 to 5 of 5
Thread: Teensy 4.0 SPI Clock isn't Square at Relatively Low Speeds
    Hey everyone! I have been trying to use SPI on my Teensy4.0 that is running at 600MHz at faster speeds then 5MHz but I can't even manage to get square waves at this speed. The code is a simplified version of what I'm trying to do but the behavior is same in the code provided below and the more cluttered code that I'm using in the actual device. Please take a look at the screenshots and you'll understand what I mean. I captured the waveforms using Saleae Logic Pro 16 Logic analyzer.
    How can I manage to get cleaner signals here?
    Thank you very much for your answers.
    Edit: I'm using the latest Teensyduino software
    1.5MHz SCK
    2.5MHz SCK
Name:	Screen Shot 2021-07-22 at 12.55.29 AM.jpg
    5MHz SCK
    Capture Config & Device
Name:	Screen Shot 2021-07-22 at 12.59.34 AM.png
    #include "SPI.h"
    //#include <SPI.h> gives the same result
    SPISettings spiWrite(5000000, MSBFIRST, SPI_MODE0);
    byte printBytes[2] = {0, 0};
      SPI.begin();
      SPI.beginTransaction(spiWrite);
      SPI.transfer(printBytes[1]);
      SPI.transfer(printBytes[0]);
      delayNanoseconds(250);
      SPI.endTransaction();
    Jul 2020
    1,348
    Looks like you are using the analog inputs (BW 5MHz), rather than digital inputs for this.
    Jul 2020
    1,348
    Yes, that's the issue I think, with 100MHz bandwidth you'll see
    for SCLK at 5MHz
    That LA's analog mode uses much slower ADC that has 12 bit resolution - the digital channels are fast but 1 bit...
    My 100MHz 'scope has 8 bit ADC at 1GSPS. The Salae ADC is 50MSPS - it nothing like as capable as a cheap 'scope,
    which is why I seldom use an LA these days, 4 channel scope is more powerful unless you need to debug a databus.
    9,393
    Agreed!
    I think it is safe to assume that an LA in 1 bit mode sees exactly what connected chips see. After all, this is what an LA is designed for(?!).
    That's why an analog view of a clock signal doesn't make much sense if the LA processes the signal correctly in digital mode.
    This is only useful if something is not working. But then you should know the limits of the LA and use an oscilloscope if necessary.
    Edit: The probes play a role, too.
    Edit: The analog bandwidth of the LogicPro is 5Mhz.
    Jul 2020
    1,348
    It strikes me a LA with dual comparator sets would be able to show trapezoidal waveforms fairly accurately and indicate fault
    conditions (static and dynamic discipline violations). Just having a single set of comparators at the middle of the forbidden
    zone is sometimes going to hide signal integrity issues.
