Results 1 to 4 of 4
Thread: Teensy 4.1 Interrupt basics to create a square wave signal
    May 2021
    10
    Hello everyone,
    I'm trying to get started with interrupt programming for a project in which I want to measure voltages and other things under real time conditions. First of all I wanted to try a very simple program, where the Teensy creates a square wave signal by toggling an output pin on every timer overflow. Therefore I used the following code:
    #include <avr/io.h>
    #include <avr/interrupt.h>
    #define PWM_PIN 2
    volatile byte PWMState = LOW;
      pinMode(PWM_PIN, OUTPUT);
    ISR(TIMER0_OVF_vect)
        if(PWMstate == LOW){
          PWMstate = HIGH;
          PWMstate = LOW;
      digitalWrite(PWM_PIN, PWMstate);
    Later I want to try a PWM signal, with adjustable pulse width and frequency, but first the square wave is already a problem.
    I'm not really sure, but I think I have to put the digitalWrite function into the ISR(){} or could the code above also work?
    The Arduino software throws an error at me, that it expects a constructor or destructor before "(" is used in ISR(TIMER0_OVF_vect). Did I do something wrong including the libraries or is something in the code missing?
    Am I on the right track with my approach?
    Thank you in advance
    May 2015
    USA
    1,085
    May 2021
    10
    Thank you jonr. That helped
    25,247
    Quote Originally Posted by MrZ80Dude View Post
    You can also get adjustable frequency from the hardware PWM pins, using analogWriteFrequency() and analogWrite(). Details here:
    https://www.pjrc.com/teensy/td_pulse.html
