Admin Edit: ICS-52000 microphones do not appear to work well with Teensy at 44100 Hz sample rate.
We are connecting the ics52000 microphone array with teensy 4.1, and we wish to send the microphone
signal to the pc through usb audio.
Here are the pin connection, note that I have shield the pin 1 3 5 7 9 together at the other side of the microphone array board.
and the code used
#include <SerialFlash.h>
AudioInputTDM tdm1; //xy=372.1667022705078,876.5
AudioOutputUSB usb1; //xy=608.3333129882812,785.6666870117188
AudioConnection patchCord1(tdm1, 0, usb1, 0);
AudioConnection patchCord2(tdm1, 1, usb1, 1);
AudioMemory(256);
delay(200);
I have change the port to be "audio" and manully upload the code to teensy.
I am using the https://friture.org/ to inspect the signal,
but I can not see any signal at all.
I do have used the the audio shield and send the signal to the pc as usb audio, and it
works.
I do not understand why it does not work with the ICS52000 TDM microphone.
