Page 1 of 3 1 2 3 LastLast
Results 1 to 25 of 66
Thread: Teensyduino 1.54 Beta #11
    Administrator Paul's Avatar
    Oct 2012
    415
    Here is an eleventh beta test for Teensyduino 1.54.
    This beta is meant as a 1.54 release candidate. Please report any bugs.
    At this point, new features will be considered for 1.55. We need to
    get 1.54 wrapped up and released!
    Linux 32 bit:
    https://www.pjrc.com/teensy/td_154-b...nstall.linux32
    Linux 64 bit:
    https://www.pjrc.com/teensy/td_154-b...nstall.linux64
    Linux ARM:
    https://www.pjrc.com/teensy/td_154-b...stall.linuxarm
    Linux ARM64:
    https://www.pjrc.com/teensy/td_154-b...l.linuxaarch64
    MacOS 10.10 to 11.4:
    https://www.pjrc.com/teensy/td_154-b...S_Catalina.zip
    MacOS 10.8 to 10.14:
    https://www.pjrc.com/teensy/td_154-b...inoInstall.dmg
    Windows:
    https://www.pjrc.com/teensy/td_154-b...inoInstall.exe
    Changes since Teensyduino 1.54-beta10:
    Fault handler on Teensy 4 stores info, keeps USB active, reboots after 8 sec
    Add CrashReport for printing or logging fault info
    Fix NULL pointer read after String subString returning empty
    Fix String operator == ambiguous overload
    Disable Arduino Sketch-Upload Using Programmer menu item
    LittleFS minor updates (mjs513)
    1,736
    Installed b11 over b10. No problems but haven't beaten it up yet.
    Pete
    15,067
    Downloaded WIN version with no browser warning.
    Installed with no errors into IDE 1.8.15
    A couple of uploads work as expected.
    Germany
    9,265
    Issues:
    - Teensy LC waveplayer does not work (simple solution: fix buffer size Edit: simple, but not perfect because it needs more memory)
    - Usb - mute Audio does not work. (edit: fixed)
    - usb audio example uses DAC on T4
    - usb audio uses a buffer not marked as DMAMEM (usb_audio_transmit_buffer, Line 297)
    - see post from jonr in last beta thread.
    - MMeissner: use #ifdef's so the correct SPI pins are selected on the Teensy 4.0/4.1 compared to the Teensy 3.2/3.5/3.6.
    - not sure: CrashReport uses printf (edit: fixed)
    - crashreport does not report interrupt number.
    - unused interrupt is in RAM.
    - SD-Library has a warning. (edit: fixed by Bill in newest version @ github)
    - round(): double promotion
    - _VectorsRam not volatile. (edit: fixed)
    - MPU settings not optimal.
    Feature request for 1.55: Easy way to change USB name, vendor id etc. whthout having to copy and patch the whole arduino directory. Currently, updates are very complicated
    15,067
    Indeed CrashReport.cpp has 6 calls to printf.
    Quick hack remove of them - before and after:
    teensy_size: Memory Usage on Teensy 4.0:
    teensy_size:   FLASH: code:26828, data:5776, headers:8352   free for files:1990660
    teensy_size:    RAM1: variables:12992, code:23752, padding:9016   free for local variables:478528
    teensy_size:    RAM2: variables:12384  free for malloc/new:511904
    teensy_size:   FLASH: code:11220, data:2520, headers:8784   free for files:2009092
    teensy_size:    RAM1: variables:8896, code:8240, padding:24528   free for local variables:482624
    Germany
    9,265
    Wow that's a big difference.
    15,067
    Removed PrintF() ... did a github.com/PaulStoffregen/cores/pull/577
    can test #define selective copy of MyFault examples using : all.ino
    New York
    7,548
    Just installed beta 11 over beta 10 on a Win10x64 home edition without issue. Again no blue screen from windows.
    Ran a couple of fault examples - noticed a lot more descriptive info printed. One note on Unused_ISR.ino sketch. I am getting the following message:
    No Crash Data To Report
      Hopefully all is well, but certain types of crashes can't be reported:
    	stuck in an infinite loop (technically, hardware still running properly)
    	remaining in a low power sleep mode
    	access to certain peripherals without their clock enabled (eg, FlexIO)
    	change of CPU or bus clock speed without use of glitchless mux
    Is this to be expected with this sketch?
    The FPU_Turned_Off.ino goes into an continuous reboot with seeing any crash report unless you put a delay before turning off the FPU. Also, not sure continuous reboot is good, makes it very difficult to upload another sketch - pretty much have to do a 15s restore unless you time it right.
    Germany
    9,265
    I'd expect a little more information.
    New York
    7,548
    Ok - going to be sorry I asked - but like what?
    Germany
    9,265
    Don't know what is possible without too much work - The Interrupt number would be fine.
    Also, when a crash occurs inside an interrupt.
    New York
    7,548
    Separate Topic - LittleFS check
    Ran @defragster LFSIntegrity sketch on the memory board for the 2GB memory chip with no issues - created files, deleted etc.
    Also tested memory retention on restart for the T4 and TMM.
    25,026
    I have mixed feelings about losing the nice formatting. 15K seems like a lot, but this needs to be considered in the context of a feature which is temporarily added for troubleshooting, then (usually) removed once the problem is solved. The design is for the always-built fault handler to be small & simple, and CrashReport which is optional can have lots of code to show it nicely.
    I'm going to merge this now. Maybe in 1.55 we'll improve CrashReport with nicer formatting....
    25,026
    How's this look?
    https://github.com/PaulStoffregen/co...92d368849814f8
    Germany
    9,265
    Perfect
    25,026
    - Teensy LC waveplayer does not work (simple solution: fix buffer size)
    No such a simple solution, since Teensy LC has so little RAM.
    25,026
    Merged your pull request.
    https://github.com/PaulStoffregen/cores/pull/572
    25,026
    I can't reproduce this.
    Can you give me more detail, which board & settings, and which example to compile to reproduce the problem?
    Dec 2015
    LA
    223
    macOS 10.15.7
    Installed and ran normally. My crashing programs now spring back to life! Where do I find info on how to use this 'Crash Reporter' ?
    15,067
    Another note >> I didn't even notice :: I was NOT Warned about the EXE and I did not 'UNBLOCK' it manually under 'Properties'!
    So it was marked SAFE to run - not 'danger from a download' - Very Nice.
    Indeed dropping Printf compromises desired formatting - as noted in the PR. But some sketches already running on the edge using RAM and possibly adding 15K to debug won't fly. Some amount of alternate code might work in TD 1.55.
    Though running the Faulty sketch - then running the example/TypicalUse - without power off - would expose a recorded CrashReport.
    @Paul: Is there a place in 'examples' for a sketch like :: TypicalUse.ino?
    > it would be a ready Forum reference for 'TypicalUse' and also as way to expose as noted above.
    15,067
    Quote Originally Posted by bicycleguy View Post
    macOS 10.15.7
    Just seeing this - was on my mind though for post #20:
    See/RUN THIS :: github.com/PaulStoffregen/MyFault/blob/main/examples/TypicalUse/TypicalUse.ino
    Dec 2015
    LA
    223
    Thanks defragster
    Cheltenham, UK
    407
    If on initial crash the crash data is stored in a non volatile location, then a separate ino can be run to print out the Error data in a nice Formatted manner.
    15,067
    Thanks defragster
    Quote Originally Posted by BriComp View Post
    Indeed ... See p# 21 and #20
    Just confirmed that on T_4 the .print("const char strings data") is stored in Flash like F() ... they do not go into RAM1
    RE: SD Warnings :: Also ran listfiles.ino and did not see any warnings.
    Germany
    9,265
    I completely forgot that I use GCC10 as default.
    So, sorry for the "false" alarm - but maybe someone (you, Bill) wants to fix it anyway now?:
    C:\Arduino\hardware\teensy\avr\libraries\SdFat\src\ExFatLib\ExFatPartition.cpp: In member function 'bool ExFatPartition::freeChain(uint32_t)':
    C:\Arduino\hardware\teensy\avr\libraries\SdFat\src\ExFatLib\ExFatPartition.cpp:225:5: warning: 'next' may be used uninitialized in this function [-Wmaybe-uninitialized]
      225 |     if ((cluster + 1) != next || status == 0) {
    Any Sketch which includes SdFat will do.
    Seen with Teensy 4.0, a Sketch with audio (but SD is not used).
