Results 1 to 15 of 15
Thread: Implementing TeensyLoader into a C# app?
    Oct 2019
    214
    I'm in the process of creating a simple app for updating a teensy based product (to be) and I was wondering, how can I implement the teensy cli C file into my existing visual studio wrapper (.cs) app without having to call the Teensy Cli externally?
    I see the CLI version, but not sure how to import the .c source code into my .cs project
    Would love to hear suggestions from others who have done this before.
    Thanks,
    Germany
    1,591
    Sure, here https://github.com/luni64/TeensySharp a library which identifies Teenies on the bus and can upload firmware. For easy installation it is also available via nuget: https://www.nuget.org/packages/lunoptics.TeensySharp/
    You basically do:
    var Board = PJRC_Board.Teensy_31;
    var FlashImage = SharpUploader.GetEmptyFlashImage(Board);                   // generate an empty flash image for the required board
    SharpHexParser.ParseStream(File.OpenText("firmware.hex"), FlashImage);      // parse the hex file into this image
    USB_Device Teensy = Watcher.ConnectedDevices.FirstOrDefault();              // get the first teensy found on the USB bus
    SharpUploader.StartHalfKay(Teensy.Serialnumber);                            // switch it to bootloader mode...
    SharpUploader.Upload(FlashImage, Board, Teensy.Serialnumber, reboot: true); // ... and upload the firmware
    The idea is to be able to integrate firmware uploading into the user application. But, you can of course use it to do a simple customized standalone uploader as well.
    Hope that helps.
    Oct 2019
    214
    Thanks luni, this is great!
    Does it support the T4/4.1?
    Germany
    1,591
    Didn't use it for quite some time. I remember that I implemented the T4.0 when it came out. Chances are that it will work for the T4.1 as well. Let me know if not. If necessary, adapting it to the 4.1 is not a big deal.
    Feb 2021
    19
    You've really made a nice library, even for me as an amature, I started using Visual Studio 4 days ago, I still understand the basics of your lib. Well done!
    Is there a way to see if no devices are connected? For example "if (!ConnectedDevices)"
    Germany
    1,591
    Glad you like it.
    Of course you can check if no boards are connected. Watcher.ConnectedDevices contains a list of all found Teensies. Simply check for Watcher.ConnectedDevices.count == 0.
    If you are new to C# I recommend to have a close look at System.linq which is the standard way to work with data in c#. The following examples show how to use LINQ to filter the Teensy list for maybe interesting features.
    using System;
    using System.Linq;
    using TeensySharp;
    using static TeensySharp.USB_Device;
    namespace sharptest
        class Program
            static void Main(string[] args)
                var Watcher = new TeensyWatcher();
                if (Watcher.ConnectedDevices.Count() == 0)
                    Console.WriteLine("No Teensy found");
                var allT36s = Watcher.ConnectedDevices.Where(t => t.BoardType == PJRC_Board.Teensy_36); // select all connected T3.6 devices
                if (allT36s.Any())  // do we have at least one T3.6 on the bus?
                    Console.WriteLine("The following T3.6 devices where found on the USB bus");
                    foreach (var teensy in allT36s)
                        Console.WriteLine($"   T3.6 with Serialnumber {teensy.Serialnumber}");  // print serial number of the connected T3.5 devices
                    Console.WriteLine();
                var myTeensy = Watcher.ConnectedDevices.FirstOrDefault(t => t.Serialnumber == 8077220);  // return the first Teensy with the given serial number. If not found return  null
                if (myTeensy != null)
                    Console.WriteLine("my teensy is connected");
                var HalfKayedTeensies = Watcher.ConnectedDevices.Where(t => t.UsbType == USBtype.HalfKay);  // look for boards in programming mode
                if (HalfKayedTeensies.Count() > 0)
                    Console.WriteLine("The following teensies are in programming mode");
                    foreach (var teensy in HalfKayedTeensies)
                        Console.WriteLine($"   Type {teensy.BoardType}, SN: {teensy.Serialnumber}");
                while (!Console.KeyAvailable) ;  // press key to stop
    Feb 2021
    19
    Glad you like it.
    using System;
    using System.Linq;
    using TeensySharp;
    namespace sharptest
        class Program
    That is brilliant, I read your code and I get the structure of it. Thanks for such a great example. This will help allot!
    Im used to PHP and with this example I feel very much at home! Brilliant work once again
    Feb 2021
    19
    Luni, there is one thing I wonder.
    When I have compiled the project it works fine in Visual Studio, it also starts fine as an executable .exe file in the debug folder.
    But, as soon as I click a button that calls for TeensySharp, I get an error that it's missing.
    I installed it via NuGet package, should I perhaps include it in some other way to get it to work?
    My end goal is a standalone runable .exe without anything else.
    Germany
    1,591
    Since dotNet doesn't support static linking you can not have a dotNet application in a single exe if it uses additional libraries *). So, either use some tool to generate an installer (which can be a single exe) or simply zip the contents of the debug (or release) folder for distribution. You can delete the *.pdb files they only contain debug info. Actually, you can try to delete everything except the *.exe and the *.dll files and try if it still runs. To install you can simply unzip the folder wherever you want.
    *) Well, technically you can, there are tools which will pack the dll's and the exe into a single file and unpack everything on startup but this is quite advanced and IMHO not worth the hassle. You can also include the TeensySharp sources directly in your application, but again, if you are new to this stuff you are better off with zipping the folder.
    Feb 2021
    19
    Thanks for your reply.
    My goal will be to implement the source into my project.
    Basically having your TeensySharp folder in my project and "including" it, I just need to figure out how to do that. I'm a quick learner, I already have a fully working program with functions, graphics and everything. Your library is the key to it all tho :P
    Germany
    1,591
    Just had a look at the sources. TeensySharp itself references moreLinq and hidLibrary. So, even if you include the TeensySharp sources you'll have the moreLinq.dll and the hidLibrary.dll to handle. You probably could get the corresponding sources but I don't know which libraries they use... then there are some system libraries and... I'm afraid that you will need to spend a lot of time fighting against the system instead of using dotNet as it was meant to be used.
    BTW: what's wrong with a simple zip file or a single file installer?
    Edit: This https://www.hanselman.com/blog/makin...gle-executable sounds interesting
    Feb 2021
    19
    I see. An installer is fine as well but it just seems neat to use a executable exe, fancy puncy stuff xD
    Feb 2021
    19
    Luni, I just wanted to let you know, I solved it. Now works with executable exe file. No other files needed.
    I've spend many hours on this, and the solution was easy. I added Costura.Fody to my Visual Studio via NuGet. It just makes everything work as a standalone .exe. Just like magic.
    So now you know, if you ever wanna make something standalone.
    Once again thanks!
    Germany
    1,591
    Sounds good. I'll have a look at this Costura.Fody. How large is the exe ?
    Feb 2021
    19
    Exe is 2.6mb, I have a few images and a nice style. And a web browser that loads an external URL to be able to show stuff inside the exe. And ofc your TeensySharp.
    I just installed Costura.Fody in NuGet, it will then start to make every package available, so it will run for like 5 - 10 minutes, after that it just works automatically.
