Results 1 to 7 of 7
Thread: Virus report
    Cheltenham, UK
    301
    Virus report
    I just received this below from BitDefender. Running Teensyduino 1.54b11
    The file C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\ extras\wav2sketch\wav2sketch.exe is infected with Gen:Variant.Fugrafa.106157 and was moved to quarantine. It is recommended that you run a System Scan to make sure your system is clean.
    1,691
    I think it's a false positive. I use Kaspersky and ran it on the entire 1.8.15 + 1.54b11 installation and it found nothing.
    YMMV.
    Pete
    24,470
    That file hasn't changed for almost 6 months.
    https://github.com/PaulStoffregen/Au...wav2sketch.exe
    While it's theoretically possible it's had a virus all along and nobody noticed until now (despite 5 beta installers having it), a false positive seems much more likely.
    8,605
    Quote Originally Posted by BriComp View Post
    Scanned it with the online Scanner form VirusTotal. It uses a bunch of scanners (including BitDefender) and all report the file as clean.
    Perhaps you have a local virus problem on your machine?
    24,470
    The original file has these checksums.
    sha512: 10c543a1462f5638361e1df8f0a3cc9b7bd1dd9d024797566a1126d9e93360ded5352874e7e9319486930ed95045a1ca72b4a0f5fa30befdc693f34054647ad6
    sha256: 622197592649c5229c4bc1c222d125a86b426405f755c60acd0f49bd9ce91e84
    sha1: 283b1b98b8cbcb0256541fe3f2f06e2b55547837
    md5: f6383055746633683b9f08a8cdefd73a
    If you have a program which can compute any of these, you can check whether the file has been modified from its original data.
    My hunch is its probably not altered. False positives are a sad reality of anti-virus software.
    Cheltenham, UK
    301
    The only way I was/am able to install Teensyduino is to uninstall/delete teensyduino, uninstall BitDefender. Re-install Arduino and Teensyduino then BitDefender.
    Oh what a pain and I have 18months of paid BitDefender to go.
    Cheltenham, UK
    301
    Teensyduino 1.54b11 checks out fine, it's only when the files in 1.54b11 are decompressed and installed that the problem occurs.
