Page 4 of 4 FirstFirst ... 2 3 4
Results 76 to 81 of 81
Thread: Teensyduino 1.54 Beta #12
  1. #76
    7,209
    Okay, maybe SD hang/Crash is just an issue with TFT_ST7789 in DMA?
    - certainly a good example ...
    Indeed lighting and reverse image not NEW - just pointing out alternate behavior madr apparent because SFUN went off/on between git updates ... like that typo ")
    Yeah - sorry about that - its whatever config I was using to verify the changes. Oh as to your mirroring/flipping I just remembered that we added 2 commands to try and correct orientation issues:
      //horizontal flip for my screen/camera orientation
      hm01b0.set_hmirror(true);
      //Vertical flip is also available
      //hm01b0.set_vflip(true);
    adding them in the sketch as a reminder that they are there Not doe yet
  2. #77
    7,209
    I'm uploading the final 1.54 right now.
    Everything else can go into 1.55.....
    Great news - hope you had a good 4th.
  3. #78
    14,441
    @Paul - do you want to craft a release post in threads/64978-TeensyDuino-New-Release-Thread-Subscribe-for-notice-of-future-releases
    TeensyDuino 1.54 has been released.
    Download at pjrc.com/teensy/td_download.html
    For release notes and added information see :: Teensyduino-1-54-Released
  4. #79
    Mar 2013
    138
    Thanks everyone for the extensive work and testing behind this release.
  5. #80
    8,605
    I see Frank B caught some corrections in display when printf was removed - that probably relates to the "OVF" display above.
    No
    https://github.com/PaulStoffregen/co...2a78f36401f877
  6. #81
    14,441
    I saw the 0x's in a quick scan - assumed that was something in there too ...
    But : https://github.com/PaulStoffregen/co...191d962463b6ae
    It is just doing : p.print(info->temp);
    - so that value must have been recorded wrong - and it was CRC'd so it was saved that way in the Crash handler ...
