Page 1 of 4 1 2 3 ... LastLast
Results 1 to 25 of 99
Thread: Teensyduino 1.54 Released
    Administrator Paul's Avatar
    Oct 2012
    412
    Teensyduino 1.54 has been released.
    Quick summary: 1.54 brings support for MicroMod Teensy and Arduino 1.8.15. The higher performance SdFat library is included the SD library is only a thin wrapper for SdFat. LittleFS is now included, for filesystems on flash chips or in Teensy 4 program memory. Audio now has bandwidth limited waveform syntheis and a ladder filter for Moog-like subtractive sound synthesis. OctoWS2811 now supports RGBW LEDs. Teensy 4.0, 4.1 & MicroMod can now recover from many types of memory faults and crashes, and info about what caused the problem can be seen after rebooting with Serial.print(CrashReport).
    Detailed article about new features:
    https://www.pjrc.com/teensyduino-1-54-released/
    Changes since 1.54-beta12:
    Updated Linux udev rules
    CrashReport placehold for Teensy 2.0, LC, 3.x
    LittleFS Integrity exmaples cleanup (Defragster)
    Fix TEMPMON register defs (ssilverman)
    Delete wav2sketch.exe - triggers anti-virus false positives
    Fix Audio compile error on Teensy LC
    Improve USBhost_t36 examples arrangement
    Complete list of changes since 1.53:
    Support for MicroMod
    Fix SPI with DMA to cached memory on Teensy 4.x
    Support alternate Wire3 pins on Teensy 4.1
    Improve map() function
    Show Serial.printf format warnings
    Fixes for HAB secure boot
    Update imxrt.h comments for RT1060 Reference Manual, Rev 2
    AsyncAudioInputSPDIF3 bugs fixed
    synth_tonesweep update?
    NativeEthernet & FNET update
    Update ILI9341_t3
    Update QuadEncoder
    Update RadioHead
    Update ST7735_t3
    Update USBHost_t36
    XPT2046_Touchscreen
    Wait up to 6.2 seconds for Teensy to reboot (was 5 seconds)
    Fix 1.54-beta1 startup problem on Teensy 4.1
    EEPROM put/get handle String and warn for incompatible classes (luni64)
    Add _extram_start & _extram_end for Teensy 4.1
    Update Bounce2
    Add File base class and FS.h header
    Add SdFat-beta library
    Replace SD library with wrapper which uses SdFat
    SoftwareSerial improvements on Teensy 3.5, 3.6, 4.1
    Update NativeEthernet
    Audio: Improve simultaneous WAV playing & add SimultaneousPlay test
    SD default to 16 MHz SPI clock
    Serial Monitor fix double spaced lines copied to clipboard
    Serial Monitor avoid auto horizontal scroll on very long lines
    Serial Monitor fix memory leak on MacOS
    File & FS classes improved - many changes!
    Add LittleFS library - lots of new stuff here...
    FS open() supports FILE_WRITE_BEGIN mode
    SdFat-beta renamed to SdFat
    Add delayNanoseconds() on Teensy 2.0, LC, 3.x
    Print class support for 64 bit integers
    DMAChannel attachInterrupt(isr, priority) (WMXZ)
    SD listfiles example improved
    Fix Audio PT8211 issue on Teensy 4.x
    Improve Audio simultaneous WAV playing
    Fix USB issue for MTP to run at 600 MHz
    Fix double space on copy from serial monitor on Windows
    Configurable MIDIx16 port names (vjmuzik)
    Support for no USB (vjmuzik)
    Fix multiple def with EEPROM put() & get()
    Update FlexCAN_t4
    Update RadioHead
    Update ST7735_t3
    Update SdFat to 2.0.5.beta1
    Wire lib Scanner example updated
    Audio waveform synth add bandwidth limited waveforms (Mark Tillotson)
    Fix audio design tool conflict with DAC & PWM outputs (manicken)
    Fix audio compile errors with Teensy LC (Frank B)
    Add I2S output for Teensy LC (Frank B)
    Add PT8211 output for Teensy LC (Frank B)
    Add support for SGTL5000 in I2S master mode
    Fix bug in SGTL5000 BiQaud filter calculation (Graham Whaley)
    Fix minor bug in S/PDIF resampling (alex6679)
    Add Play/Pause function to WAV player (standarddeviant)
    Fix waveform synth discontinuities in phase modulation (Mark Tillotson)
    Fix buzzing noise in FreeVerb due to numerical truncation (matt venn)
    SGTL5000 support for switching headphones to input signal (Jurgen BeliŽn)
    Add JavaScript version of wav2sketch (Matt Bradshaw)
    Add LittleFS NAND & FRAM support (MJS513)
    Add LittleFS LFSintegrity test program (Defragster)
    Add OctoWS2811 RGBW LED support
    Add OctoWS2811 VideoDisplay example for Teensy 4.x
    USBHost_t36 add MassStorageDriver work-in-progress (wwatson)
    USBHost_t36 Serial driver support for Teensy seremu (KurtE)
    Update WS2812Serial for extra Teensy 4.1 pins
    Improve serial emulation for non-serial USB types
    Windows digital signature changed - old cert expired
    Improved memory usage info for Teensy 4.0 & 4.1
    Audio input PDM on Teensy 4.x (Mark T)
    Audio ladder filter (Richard van Hoesel)
    Audio fixes on Teensy LC (Frank B)
    USBHost_t36 improve MIDI transmit speed
    Fix Teensy Loader slow startup on Ubuntu 20.04
    Update Linux udev rules - NOTE: filename changed!
    Fix Teensy Loader excessive CPU use on Linux
    SD typecast to SdFat reference, for libs like MD_MIDIFile
    SdFat fix corrupted filename from getName()
    Wire Scanner update known chips
    Wire initializion code in flash memory only (Frank B)
    Fix USB audio volume range (Frank B)
    Improve individual audio object CPU usage info
    Fix EEPROM on Teensy 4.x when compiled with -Os (Frank B)
    Fix Arduino IDE Java IOException on quit
    Support for Arduino 1.8.14
    Fix MPU settings, solve mystery 1.7 sec stalls (FrankB)
    Fix Ethernet W5100 on Teensy 4.0 running at > 150 MHz
    Wire library names updated for MicroMod (mjs513)
    Add Kurt's FlexIO_t4 library (KurtE)
    Add missing FlexIO defs to imxrt.h
    Fix IMXRT_GPIO_t ISR name on Teensy 4
    Serial.begin() to wait up to 2 seconds for serial monitor
    Audio add WaveFolder (Mark T)
    Audio fix double promotion warnings (FrankB)
    Audio improve ladder filter (Richard van Hoesel)
    LittleFS updates to lowLevelFormat (Defragster, KurtE)
    RA8875 updates
    ST7735_t3 updates
    USBHost_t36 update mass storage
    USBHost_t36 undo zero interrupt latency change, breaks some drivers
    Fix memory usage on MicroMod
    Show ITCM actual memory usage & padding
    Support for Arduino 1.8.15
    Fix FreqMeasureMulti on Teensy 4 (joepasquariello)
    Fix USB buffer bug on Teensy 3, remove old workaround (ryanrs)
    Fix mempy crossing memory regions on Teensy 3.x
    Fix EEPROM compile issue on Teensy 2.0
    Align code & non-code boundaries to 1K on Teensy 4.x
    Fix startup bug on Teensy 4
    Fix emulated EEPROM corruption bug on Teensy LC
    Fix typo in Audio TDM input documentation
    Update FlexIO_t4 (from KurtE)
    LittleFS persist ramdisk (Defragster)
    Fault handler on Teensy 4 stores info, keeps USB active, reboots after 8 sec
    Add CrashReport for printing or logging fault info
    Fix NULL pointer read after String subString returning empty
    Fix String operator == ambiguous overload
    Disable Arduino Sketch-Upload Using Programmer menu item
    LittleFS minor updates (mjs513)
    Add cmsis_gcc.h, for Arduino_TensorFlowLite library
    Fix Serial2 vs Serial4 on MicroMod (KurtE)
    Add SD library SdFat_Usage example
    Reduce CrashReport memory usage
    _VectorsRam change to volatile
    14,871
    Fresh unzip Win IDE 1.8.15 and TD 1.54 install.
    IDE Blink to T_MM okay
    Recent mjs513 HM01B0 example to SFUN MMod ML board camera and display working to TFT_ST7789
    No warnings or errors.
    Confirmed only sketchbook lib is the camera:
    Memory Usage on Teensy MicroMod:
      FLASH: code:89772, data:15720, headers:9192   free for files:16400388
       RAM1: variables:262848, code:86280, padding:12024   free for local variables:163136
       RAM2: variables:321856  free for malloc/new:202432
     Used: T:\arduino-1.8.15\hardware\teensy\avr\libraries\SD
     Not used: T:\arduino-1.8.15\libraries\SD
    Using library SD at version 2.0.0 in folder: T:\arduino-1.8.15\hardware\teensy\avr\libraries\SD
    Using library SdFat at version 2.0.5-beta.1 in folder: T:\arduino-1.8.15\hardware\teensy\avr\libraries\SdFat
    Using library SPI at version 1.0 in folder: T:\arduino-1.8.15\hardware\teensy\avr\libraries\SPI
    Using library Wire at version 1.0 in folder: T:\arduino-1.8.15\hardware\teensy\avr\libraries\Wire
    Using library HM01B0 at version 1.0.0 in folder: T:\tCode\libraries\HM01B0
    Using library FlexIO_t4 at version 1.0.0 in folder: T:\arduino-1.8.15\hardware\teensy\avr\libraries\FlexIO_t4
    Using library ST7735_t3 at version 1.0.0 in folder: T:\arduino-1.8.15\hardware\teensy\avr\libraries\ST7735_t3
    Ran this okay : T:\arduino-1.8.15\hardware\teensy\avr\libraries\LittleFS\exam ples\Integrity\PROG
    > Only edit was 12MB Media size from default 1MB
    24,784
    Hopefully the Microsoft warnings about the new digital signature are gone?
    14,871
    Correct, No warnings on RELEASE or prior two beta releases.
    Apparently TeensyInstaller cert back on the Known Good list!
    7,429
    Just installed 1.54 over 1.54b12 without issue on a Win10x64 home pc. Download no issue with blue screen warning and cleared Norton as safe. No problems with installation noted.
    Ran a the temp fault examples sketches on the Teensy MicroMod board.
    1. Panic temp exceeded - worked no issue
    CrashReport:
      A problem occurred at (system time) 19:38:43
      Code was executing from address 0x774
      Temperature inside the chip was 56.35 įC
      Startup CPU clock speed is 600MHz
      Reboot was caused by temperature sensor
    Panic Temp Exceeded Shutting Down
    Can be caused by Overclocking w/o Heatsink or other unknown reason
    2. High temp set arm clock to 24mhz example - passed
    No Crash Data To Report
      Hopefully all is well, but certain types of crashes can't be reported:
    	stuck in an infinite loop (technically, hardware still running properly)
    	remaining in a low power sleep mode
    	access to certain peripherals without their clock enabled (eg, FlexIO)
    	change of CPU or bus clock speed without use of glitchless mux
    Temp(degC) = , 45.416668
    Temp(degC) = , 47.604168
    Temp(degC) = , 49.791668
    Danger Will Robinson
    HIGH Temperature Alarm 51.2.
    System Clock set to 24Mhz
    Temp(degC) = , 44.687500
    Temp(degC) = , 42.500000
    Temp(degC) = , 41.770832
    Temp(degC) = , 41.041668
    Temp(degC) = , 40.312500
    14,871
    @Paul - (from b12 thread) do you want to craft a release post in threads/64978-TeensyDuino-New-Release-Thread-Subscribe-for-notice-of-future-releases
    TeensyDuino 1.54 has been released.
    Download at pjrc.com/teensy/td_download.html
    For release notes and added information see :: Teensyduino-1-54-Released
    * This will notify whatever # of folks 'Subscribed' to threads/64978-TeensyDuino-New-Release-Thread-Subscribe-for-notice-of-future-releases
    24,784
    You can do it. You started that thread.
    Feb 2021
    19
    I'm using PlatformIO, will 1.54 automatically be used or do I need to put something in my .ini file, anyone?
    9,056
    I think, best is to ask the platformio guys.
    Senior Member ETMoody3's Avatar
    Mar 2014
    New Ulm, Mn
    176
    Seems okay on Raspberry Pi
    14,871
    Also a forum search ... Not using P_IO here ... but in recent days there was a post of a simple edit it seemed to link it to install location.
    24,784
    Usually PlatformIO publishes an update within a week. Or at least they have in the past.
    Ivan has said he follows the cores github repo, and this time I made sure to tag a 1.54 release, so they should already be aware.
    Wouldn't hurt to ask them (nicely) but just keep in mind they've had not even 24 hours since 1.54 released. The process has always taken at least a few days. This update made a change to showing memory usage in a completely different way, so it'd be reasonable to expect they'll take a little longer this time to consider how (or if) to use the detailed memory usage.
    Oct 2015
    Vermont, USA
    311
    Installed Arduino 1.8.15 and then installed TD 1.54. no installation problems.
    I compiled a complex sketch for T4.1 (Tympan RevE) using my floating point audio library which uses a the new SD functionality. So far, everything looks good.
    Nice work.
    Chip
    Feb 2021
    19
    Thanks Paul, Iíll wait and see. Good you cleared that up. Appreciate it. And once again, thanks for making the Micromod reality!
    7,429
    @PaulStoffregen
    Somewhere, can't seem to find it, was mention of another PSRAM chip that could be used for the T4.1. Specifically, the LY68L6400 by Lyontek. So I purchased a few for testing and just installed on the T4.1 and looks like its another candidate to be used.
    Running the PSRAM memTest.ino - chip was recognized and all tests passed:
    EXTMEM Memory Test, 8 Mbyte
     CCM_CBCMR=B5AE8304 (88.0 MHz)
    testing with fixed pattern 5A698421
    testing with pseudo-random sequence, seed=2976674124
    testing with pseudo-random sequence, seed=1438200953
    testing with fixed pattern FFFFFFFF
    testing with fixed pattern 00000000
     test ran for 36.66 seconds
    All memory tests passed :-)
    Next running the new LittleFS example - PSRAM Integrity sketch it comes up immediately with
    printDirectory RAM_DISK
     0 dirs with 0 files of Size 0 Bytes
     Total 0 files of Size 0 Bytes
    Bytes Used: 4096, Bytes Total:8388608
    and running the Big File Test - worked without issue:
    Start Big write of 4161536 Bytes..................................................
    Big write /0_bigfile.txt took  0.97 Sec for 4159488 Bytes : file3.size()=4159488
    	Big write KBytes per second 4269.86
    Bytes Used: 4200448, Bytes Total:8388608
    FILE	0_bigfile.txt		4159488
    DIR	1_dir /
    DIR	2_dir /
    DIR	3_dir /
    DIR	4_dir /
    DIR	5_dir /
     5 dirs with 1 files of Size 4159488 Bytes
     Total 1 files of Size 4159488 Bytes
    Next up was running the LittleFS_test1a sketch for PSRAM. Wanted to test not only if it worked but also if it retained the data from the previous test. Test passed successfully:
    LittleFS Test
    TotalSize (Bytes): 8388608
    started
    MAKE files
    printDirectory
    DIR	1_dir /
    DIR	2_dir /
    DIR	3_dir /
    DIR	4_dir /
    DIR	5_dir /
    DIR	structureData1 /
     6 dirs with 1 files of Size 4159488 Bytes
    printDirectory
    DIR	1_dir /
    DIR	2_dir /
    DIR	3_dir /
    DIR	4_dir /
    DIR	5_dir /
    	FILE	temp_test.txt		19
     0 dirs with 1 files of Size 19 Bytes
    FILE	temp_test1.txt		19
    FILE	temp_test2.txt		19
    FILE	temp_test3.txt		1024
     6 dirs with 4 files of Size 4160550 Bytes
    Disk Usuage:
    Bytes Used: 4206592, Bytes Total:8388608
    Test for SOME DATA TO TEST
    So I would say its a safe bet to add the chip to the list of chips that can be used.
    24,784
    Yes. I have an unopened package here, which is should have those chips. Got really busy with the 1.54 release and testing & packaging Teensy 4.1 over the weekend (so we could ship most backorders this week), and then repairing a couple test fixtures this week.
    I'm pretty sure all of these 8MB QSPI PSRAM parts are really just the exact same Ap Memory chip inside.
    7,429
    Think you had your hands full enough with everything and probably still do. Hopefully its one less thing you can cross off your list. I actually had it for several days, sitting and waiting for me to do something with, but got side tracked with a few other things as well, as always.
    It sure looks like they have the same core ship.
    9,056
    Yes, the datasheets are pretty similar. The only difference I saw at first glance is 200uA Standby current for the Lyontek part vs. 400uA for the ESP part.
    https://datasheet.lcsc.com/szlcsc/Ly...IT_C261881.pdf
    https://www.espressif.com/sites/defa...tasheet_en.pdf
    But that may be due to the different date of the datasheets.
    Aug 2019
    Portland, OR
    5
    Ignorant questions: How do I find out what version of Teensyduino I'm currently running, and how do I safely install the new version over my current version?
    Thanks.
    24,784
    Quote Originally Posted by jstanley View Post
    In Arduino, click Help > About. (or Teensyduino > About if using Macintosh)
    Just run the installer. It's safe to "install on top of" an older version.
    But if you want the latest Arduino 1.8.15, install that first. If using Windows, the .exe installer will delete your old copy before it installs the new version. Then install Teensyduino 1.54.
    9,056
    ... doesnt it need to be clean install? or does it delete the superflues files? (time.h?)
    24,784
    I've added a blog article with a detailed look at the many new features & improvements Teensyduino 1.54 adds.
    7,429
    Just finished reading through the Blog really turned out well.
  24. #24
    14,871
    The TD 1.54 Blog article looks great
    Re:
    RTC RAM
    16 bytes of memory are located within the RTC. If a coin cell is connected to VBAT, contents of
    this memory is preserved while power is off. This memory is accessed as 32 bit registers LPGPR0-LPGPR3.
    This takes the @Frank B discovered activation : SNVS_LPCR |= (1 << 24); //Enable NVRAM - documented in SDK
    There is a working sample here for T_3.x and T_4.x : Teensy-4-x-Battery-backed-Non-volitile-memory
    That also posted here : TeensyUser/doc/wiki/NVRAM-usage-on-T_3.x-and-T_4.x-and-MicroMod
  25. #25
    9,056
    There was an update of Platformio, for Teensy, but they still use the old size tool
