#include "Watchdog_t4.h"
WDT_T4<WDT3> wdt;
// DMAMEM causes allocation in 'static' RAM2 on Teensy using 1062 processor
// It is not initialized and will retain value while powered
// BUT - it writes through a cache that must be flushed to assure it is current
// This works for any DMAMEM allocation of any variable type or structure
DMAMEM uint32_t loopCnt;
DMAMEM uint32_t feedCnt;
DMAMEM char szLast[32];
void myCallback() {
arm_dcache_flush(&loopCnt, sizeof(loopCnt));
arm_dcache_flush(&feedCnt, sizeof(feedCnt));
uint ii = 1;
while ( ii < (sizeof(szLast) - 1) && Serial.available() ) {
szLast[ii++] = Serial.read();
szLast[ii] = 0;
szLast[0] = 42;
arm_dcache_flush(szLast, sizeof(szLast));
Serial.println("YOU DIDNT FEED THE DOG, 255 CYCLES TILL RESET...");
Serial.begin(1);
delay(600);
Serial.println("Begin......");
Serial.print("\tPRIOR Loop Count = ");
Serial.println(loopCnt);
Serial.print("\tPRIOR Feed Count = ");
Serial.println(feedCnt);
if ( szLast[0] == 42 && szLast[1] != 0 ) {
Serial.print("\tLast User input text : ");
Serial.println(&szLast[1]);
loopCnt = 0;
feedCnt = 0;
szLast[0] = 0;
if ( Serial && CrashReport )
{ // Make sure Serial is alive and there is a CrashReport stored.
Serial.print(CrashReport); // Once called any crash data is cleared
// In this case USB Serial is used - but any Stream capable output will work : SD Card or other UART Serial
WDT_timings_t config;
config.window = 3000; /* in seconds, 32ms to 522.232s, must be smaller than timeout */
config.timeout = 10000; /* in seconds, 32ms to 522.232s */
config.callback = myCallback;
wdt.begin(config);
static uint32_t feed = millis();
loopCnt++;
/* set to below 3000 to demonstrate windowMode effect for feeding the dog too fast */
/* set to 3100 to demonstrate proper processing */
/* set to 12000 to demonstrate an actual non-feeding reset */
if ( millis() - feed > 3100 ) {
feed = millis();
wdt.feed();
feedCnt++;
if ( Serial.available() ) { // Any Serial input will HALT the loop() here causing WD Timeout
Serial.println("Hungry Dog ahead ......");
while ( Serial.available() );
