NikCA
Summer is here and I have a little robotic project in mind I'm looking for some guidance from more experienced people.
The core idea of the project is to make a little delta robot with servos and to control it from a program on а computer. In my mind, this means that somehow the Teensy needs to be able to send messages/commands to the pc as "updates" (e.g. "Servos moves to x degrees" or "Movement failed") and the computer also needs to be able to send commands/messages along the lines of "Move servo A to X degrees" etc..
What I'm struggling with is, what is the best way to accomplish this?
Do I have to try to make a USB device from the Teensy (for example the way a Webcam is a USB device) or can I just use serial on the Teensy and make a program on the computer that reads/sends data.
Thank you for taking your time to read this and I hope I've described what I want to do clearly, if there is anything confusing/not exact I'll try to rewrite it.
