Hi all,
Very new to the Teensy world and looking for some advise and perhaps a guide in the right direction. Sorry if my terminology is not correct.
I am building a gaming Sim Wheel. I am wanting to run 11 encoders in which they would make adjustments to in car controls in a sim game. Basically an up and down button i guess you might say.
Encoders are connected as code below with all centre pins daisy chained to ground
I have uploaded the Teensy/ encoder/ twoknobs example and have edited it to show my 11 encoders. With the serial monitor i can see all encoders and make them count up and down however when rotated i get the odd jump in my steps (count)?
I am also lost as to how to add an analogue input which i would use a potentiometer as a paddle clutch.
The other issue i have is that this doesnt make the teensy a windows USB game device.
As i said i am very new to this and just looking for some assistance please.
Code i am using follows -
#include <Encoder.h>
// Change these pin numbers to the pins connected to your encoder.
// Best Performance: both pins have interrupt capability
// Good Performance: only the first pin has interrupt capability
// Low Performance: neither pin has interrupt capability
Encoder encoder1(0, 1);
Encoder encoder2(2, 3);
Encoder encoder3(4, 5);
Encoder encoder4(6, 7);
Encoder encoder5(8, 9);
Encoder encoder6(10, 11);
Encoder encoder7(12, 14);
Encoder encoder8(15, 16);
Encoder encoder9(17, 18);
Encoder encoder10(19, 20);
Encoder encoder11(21, 22);
// avoid using pins with LEDs attached
Serial.println("Encoder Clutch:");
long position1 = -999;
long position2 = -999;
long position3 = -999;
long position4 = -999;
long position5 = -999;
long position6 = -999;
long position7 = -999;
long position8 = -999;
long position9 = -999;
long position10 = -999;
long position11 = -999;
long enc1, enc2, enc3, enc4, enc5, enc6, enc7, enc8, enc9, enc10, enc11;
enc1 = encoder1.read();
enc2 = encoder2.read();
enc3 = encoder3.read();
enc4 = encoder4.read();
enc5 = encoder5.read();
enc6 = encoder6.read();
enc7 = encoder7.read();
enc8 = encoder8.read();
enc9 = encoder9.read();
enc10 = encoder10.read();
enc11 = encoder11.read();
if (enc1 != position1 || enc2 != position2 || enc3 !=position3 || enc4 != position4 || enc5 !=position5 || enc6 != position6 || enc7 !=position7 || enc8 != position8 || enc9 !=position9 || enc10 != position10 || enc11 !=position11) {
Serial.print("Encoder1 = ");
Serial.print(enc1);
Serial.print(", Encoder2 = ");
Serial.print(enc2);
Serial.print(", Encoder3 = ");
Serial.print(enc3);
Serial.print(", Encoder4 = ");
Serial.print(enc4);
Serial.print(", Encoder5 = ");
Serial.print(enc5);
Serial.print(", Encoder6 = ");
Serial.print(enc6);
Serial.print(", Encoder7 = ");
Serial.print(enc7);
Serial.print(", Encoder8 = ");
Serial.print(enc8);
Serial.print(", Encoder9 = ");
Serial.print(enc9);
Serial.print(", Encoder10 = ");
Serial.print(enc10);
Serial.print(", Encoder11 = ");
Serial.print(enc11);
position1 = enc1;
position2 = enc2;
position3 = enc3;
position4 = enc4;
position5 = enc5;
position6 = enc6;
position7 = enc7;
position8 = enc8;
position9 = enc9;
position10 = enc10;
position11 = enc11;
// if a character is sent from the serial monitor,
// reset both back to zero.
if (Serial.available()) {
Serial.read();
Serial.println("Reset both knobs to zero");
encoder1.write(0);
encoder2.write(0);
encoder3.write(0);
encoder4.write(0);
encoder5.write(0);
encoder6.write(0);
encoder7.write(0);
encoder8.write(0);
encoder9.write(0);
encoder10.write(0);
encoder11.write(0);
I have also uploaded the examples/teensy/usb_joystick sketch and can then see teensy as a usb game controller however the button do very wierd and wonderful things when encoder turned and obviously dont count correctly.
Any help would be greatly appreciated
Serial.print(enc1);
Serial.print(enc2);
Serial.print(enc3);
Serial.print(enc4);
Serial.print(enc5);
Serial.print(enc6);
Serial.print(enc7);
Serial.print(enc8);
Serial.print(enc9);
position1 = enc1;
position2 = enc2;
position3 = enc3;
position4 = enc4;
position5 = enc5;
position6 = enc6;
position7 = enc7;
position8 = enc8;
position9 = enc9;
position10 = enc10;
position11 = enc11;
Serial.read();
encoder1.write(0);
encoder2.write(0);
encoder3.write(0);
encoder4.write(0);
encoder5.write(0);
encoder6.write(0);
encoder7.write(0);
encoder8.write(0);
encoder9.write(0);
encoder10.write(0);
encoder11.write(0);
