Hi. A question.
The esp-psram64 datasheet says about power-up:
If I look at the teensy 4.1 schematic, the esp-psram64 CS pin is connected to a processor pin only. No pull-up.
So I'm wondering what happens on the teensy psram CS pin during power-up.
regards,
If I look at e.g. ESP32-WROVER schematics, this is done with a 10k pull-up to 3.3V on the psram CS pin.From the beginning of power ramp to the end of the 150-μs period, CLK should remain low, CE# should remain high (to track Vcc within 200 mV) and SI/SO/SIO[3:0] should remain low.
regards,
