Page 3 of 3 FirstFirst 1 2 3
Results 51 to 58 of 58
Thread: @Kurt: USB_HOST (T4.1) Serial, hardware handshake
  1. #51
    9,429
    You are welcome... Need to do some more testing and then probably wrap up into PR...
  2. #52
    9,056
    Good news - works perfectly:
    C:\Users\Frank\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.0.0/esptool.exe  --chip esp32 --port COM19 --baud 921600 --before default_reset --after  hard_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size  detect 0xe000  C:\Users\Frank\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.0-alpha1/tools/partitions/boot_app0.bin  0x1000 c:\temp\arduino_build_589020/Blink.ino.bootloader.bin 0x10000  c:\temp\arduino_build_589020/Blink.ino.bin 0x8000  c:\temp\arduino_build_589020/Blink.ino.partitions.bin
    esptool.py v3.0-dev
    Serial port COM19
    Connecting........_
    Chip is ESP32-D0WDQ6 (revision 1)
    Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
    Crystal is 26MHz
    MAC: 8c:aa:b5:83:5d:8c
    Uploading stub...
    Running stub...
    Stub running...
    Changing baud rate to 921600
    Changed.
    Configuring flash size...
    Auto-detected Flash size: 8MB
    Compressed 8192 bytes to 47...
    Writing at 0x0000e000... (100 %)
    Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.0 seconds (effective 4369.0 kbit/s)...
    Hash of data verified.
    Flash params set to 0x023f
    Compressed 17152 bytes to 11576...
    Writing at 0x00001000... (100 %)
    Wrote 17152 bytes (11576 compressed) at 0x00001000 in 0.1 seconds (effective 994.3 kbit/s)...
    Compressed 208272 bytes to 116489...
    Writing at 0x00010000... (12 %)
    Writing at 0x00014000... (25 %)
    Writing at 0x00018000... (37 %)
    Writing at 0x0001c000... (50 %)
    Writing at 0x00020000... (62 %)
    Writing at 0x00024000... (75 %)
    Writing at 0x00028000... (87 %)
    Writing at 0x0002c000... (100 %)
    Wrote 208272 bytes (116489 compressed) at 0x00010000 in 2.5 seconds (effective 674.3 kbit/s)...
    Compressed 3072 bytes to 128...
    Writing at 0x00008000... (100 %)
    Wrote 3072 bytes (128 compressed) at 0x00008000 in 0.0 seconds (effective 1638.4 kbit/s)...
    Leaving...
    Hard resetting via RTS pin...
  3. #53
    7,429
    Ok - Frank got me inspired and since I had all the micromod stuff out.
    Put a ESP32 micromod on the display carrier - loaded up blink and ran the updated library and it loaded the sketch.
    C:\Users\Merli>C:\Users\Merli\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.0.0/esptool.exe --chip esp32 --port COM20 --baud 921600 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0xe000 C:\Users\Merli\AppData\Local\Arduino15\packages\SparkFun\hardware\esp32\1.0.1/tools/partitions/boot_app0.bin 0x1000 C:\Users\Merli\AppData\Local\Arduino15\packages\SparkFun\hardware\esp32\1.0.1/tools/sdk/bin/bootloader_qio_80m.bin 0x10000 C:\Users\Merli\AppData\Local\Temp\arduino_build_548685/Blink.ino.bin 0x8000 C:\Users\Merli\AppData\Local\Temp\arduino_build_548685/Blink.ino.partitions.bin
    esptool.py v3.0-dev
    Serial port COM20
    Connecting........_____.....____
    Chip is ESP32-D0WDQ6-V3 (revision 3)
    Crystal is 40MHz
    MAC: 24:6f:28:8f:5f:5c
    Uploading stub...
    Running stub...
    Stub running...
    Changed.
    Auto-detected Flash size: 16MB
    Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.0 seconds (effective 4369.1 kbit/s)...
    Flash params set to 0x024f
    Compressed 17392 bytes to 11186...
    Wrote 17392 bytes (11186 compressed) at 0x00001000 in 0.1 seconds (effective 1070.3 kbit/s)...
    Compressed 207840 bytes to 105398...
    Wrote 207840 bytes (105398 compressed) at 0x00010000 in 1.6 seconds (effective 1045.1 kbit/s)...
    Wrote 3072 bytes (128 compressed) at 0x00008000 in 0.0 seconds...
    Leaving...
    But heres the caveat - as you already mentioned for the ESP32 - after the hard reset the LED doesn't start blinking. To get it running again had to unplug it and replug the power cable. But it does upload the sketch.
  4. #54
    7,429
    Just because, and for no other reason, I just tried it with the Micromod Artemis processor board and it still work and blinking happily:
    Artemis SVL Bootloader
    Script version 1.7
    Phase:  Setup
            Cleared startup blip
            Got SVL Bootloader Version: 5
            Sending 'enter bootloader' command
    Phase:  Bootload
            have 119640 bytes to send in 59 frames
            Sending frame #1, length: 2048
            Sending frame #2, length: 2048
            Sending frame #3, length: 2048
            Sending frame #4, length: 2048
            Sending frame #5, length: 2048
            Sending frame #6, length: 2048
            Sending frame #7, length: 2048
            Sending frame #8, length: 2048
            Sending frame #9, length: 2048
            Sending frame #10, length: 2048
            Sending frame #11, length: 2048
            Sending frame #12, length: 2048
                    Retrying...
            Sending frame #13, length: 2048
            Sending frame #14, length: 2048
            Sending frame #15, length: 2048
            Sending frame #16, length: 2048
            Sending frame #17, length: 2048
            Sending frame #18, length: 2048
            Sending frame #19, length: 2048
            Sending frame #20, length: 2048
            Sending frame #21, length: 2048
            Sending frame #22, length: 2048
            Sending frame #23, length: 2048
            Sending frame #24, length: 2048
            Sending frame #25, length: 2048
            Sending frame #26, length: 2048
            Sending frame #27, length: 2048
            Sending frame #28, length: 2048
            Sending frame #29, length: 2048
            Sending frame #30, length: 2048
            Sending frame #31, length: 2048
            Sending frame #32, length: 2048
            Sending frame #33, length: 2048
            Sending frame #34, length: 2048
            Sending frame #35, length: 2048
            Sending frame #36, length: 2048
            Sending frame #37, length: 2048
            Sending frame #38, length: 2048
            Sending frame #39, length: 2048
            Sending frame #40, length: 2048
            Sending frame #41, length: 2048
            Sending frame #42, length: 2048
            Sending frame #43, length: 2048
            Sending frame #44, length: 2048
            Sending frame #45, length: 2048
            Sending frame #46, length: 2048
            Sending frame #47, length: 2048
            Sending frame #48, length: 2048
            Sending frame #49, length: 2048
            Sending frame #50, length: 2048
            Sending frame #51, length: 2048
            Sending frame #52, length: 2048
            Sending frame #53, length: 2048
            Sending frame #54, length: 2048
            Sending frame #55, length: 2048
            Sending frame #56, length: 2048
            Sending frame #57, length: 2048
            Sending frame #58, length: 2048
            Sending frame #59, length: 856
            Upload complete
            Nominal bootload bps: 30524.28
  5. #55
    9,429
    Yep - As I mentioned I ran into that on the ESP32... Will try now with different ESP32... And See if that makes a difference... Not sure if they have LED...
  6. #56
    9,056
    Didn't mention it.. have the esp32 reset issue, too.
  7. #57
    9,056
    Just to mention - it is great.
    Was back to our project. We use Platformio, Teensy41, Arduino Uno.
    Teensy Usb-Mode Audio + Serial + Midi, Uno connected to the Teensy USB-Host.
    I don't know how it works, but Platformio chooses automatically the Teensy-COM port to program the UNO.
    WOW.
    Now development on both platforms it pretty easy. No Levelshifters, cables.. just USB-Host. No unplugging ...
    When Teensy detects 115200 baud, it starts the programmer code. (It stops after a timeout).
    Works perfectly.
    And both can communicate thourgh the same usb serial without any problems.
    Switching between both in platformio is pretty easy (click on the source-file, platformio switches the platform..)
    This is how development for two platforms which communicate should look like
    And you get a "free" level shifter.. can use cheap 5v boards and just plug it in.. no soldering (but USB for Teensy).. we use a cheap china LCD Keypad shield.
    Yes, Teensy can do this alone, but we wanted a project we can develop together without too much hassle.. now, the hardware is "plug&play". he does the uno part (a menusystem etc..)
  8. #58
    9,429
    Glad it is working reasonably
    I just issued PR: https://github.com/PaulStoffregen/USBHost_t36/pull/68
    It does have conflict with current code as this also included the Fix for usbSerial.read();
    As well as Peek.
