Page 1 of 3 1 2 3 LastLast
Results 1 to 25 of 58
Thread: @Kurt: USB_HOST (T4.1) Serial, hardware handshake
    Germany
    9,058
    Hi Kurt, Paul referred me to you.
    In the USB_HOST_ the functions for the hardware handshake signals (dtr, rts) are missing.
    I tried to connect a UNO. This one uses DTR.
    But it is not only practical for the UNO - you could also connect an ESP which uses both HW handshake signals.
    You could then program the boards with the Teensy.
    But it is also useful for many other things.
    Can you extend the library to be able to use hardware handshake/switch the signals??
    Thanks!!!
    Frank
    Just for the sake of completeness:
    - https://www.arduino.cc/en/uploads/Ma...-schematic.pdf
    - https://docs.ai-thinker.com/_media/e...cification.pdf (Page 11)
    Uno says:
    16:59:12.343 ->
    16:59:12.343 ->
    16:59:12.343 -> USB Host Testing - Serial
    16:59:12.582 -> *** Device USERIAL1 2341:43 - connected ***
    16:59:12.582 -> manufacturer: Arduino (www.arduino.cc)
    16:59:12.582 -> product: Arduino (www.arduino.cc)
    16:59:14.334 ->
    24,834
    I believe DTR & RTS should be possible with CDC-ACM devices using only control transfers. The other modem signals require listening to the 3rd endpoint.
    9,461
    Hi Frank and Paul , I am really rusty with some of CDC-ACM stuff, Will try to take a look. First up will be to brush back up on the the drivers...
    9,461
    First with like DTR... We already set and clear them when we startup... So are you maybe needing method in class to allow your sketch to control?
    New York
    7,469
    Ok curious now Frank - are you connecting the uno directly to the usbhost connector so usb on the arduino is connected to the USBHost on the Teensy?
    Germany
    9,058
    Yes. With my son, I'm working on a system where both communicate.
    That's the most convenient way.
    But it's pain to develop...
    It would be great for ESP, too. Plug@play WLAN and the opportunity to program the ESP without disconnecting it..
    Germany
    9,058
    Kurt, yes. As a minimum that would be enough. Full access to all hs signals(both directions) would be better, but is not needed for my application.
    Just would be good for completeness..
    Germany
    9,058
    He asked me why we need level shifters wires etc to connect a usb serial board when we have USB.
    And he' s right
    Senior Member ETMoody3's Avatar
    Mar 2014
    New Ulm, Mn
    176
    This has intriguing potential
    Germany
    9,058
    Yes it has
    9,461
    I will hack something in soon...
    Was sort of distracted today with similar but different stuff.
    It looks like to work for several different boards, will need to implement it for several Serial types...
    That is Serial Uno: CDC(ACM)
      product: Arduino Uno
      Serial: 649353433333
    control callback (serial) 6
    CDCACM setup: 00 96 00 00 00 00 08
    I plugged in an ESP32
    Manufacturer: Silicon Labs
    enumeration:
    Product: CP2102 USB to UART Bridge Controller
    Edit: ESP32 in MicroMod: different CP2102
    product: CP2102N USB to UART Bridge Controlle
    I plugged in an UNO clone (earlier Seeedstudio)...
    Shows up as an FTDI:
    Manufacturer: FTDI
    enumeration:
    Product: FT232R USB UART
    enumeration:
    Serial Number: A100WP2C
    And if I remember correctly one of the Adafruit boards showed up as something else as well...
    But will give it a try.
    9,461
    I started playing with some of this, but brings me up to interesting question.
    What does for example FTDI devices work with Arduino IDE? Example the Trossen Arbotix board using FTDI cable to program the AVR chip..
    If you look at the FTDI Cable pin outs you see:
    I am thinking they are driving the RTS line
    That is if you look at the Sparkfun Serial basic board, which uses a CH340 That pin is DTR
    Now back to playing
    9,461
    Quick update, I put up a new branch: https://github.com/KurtE/USBHost_t36/tree/Serial_DTR
    That has setDTR(true/false);
    Only partially there.
    I was able to verify that I could set DTR and in the case I mentioned above I also set RTS pin...
    Sketch I am running:
    // Simple test of USB Host Mouse/Keyboard
    // This example is in the public domain
    #include "USBHost_t36.h"
    #define USBBAUD 38400
    uint32_t baud = USBBAUD;
    uint32_t format = USBHOST_SERIAL_8N1;
    USBHost myusb;
    USBHub hub1(myusb);
    USBHub hub2(myusb);
    USBHIDParser hid1(myusb);
    USBHIDParser hid2(myusb);
    USBSerial userial(myusb);
    const int led_pin = 13;  // 13 = Teensy 3.X & LC
    USBDriver *drivers[] = {&userial, &hub1, &hub2, &hid1, &hid2};
    #define CNT_DEVICES (sizeof(drivers)/sizeof(drivers[0]))
    const char * driver_names[CNT_DEVICES] = {"USERIAL1", "Hub1", "Hub2",  "HID1", "HID2"};
    bool driver_active[CNT_DEVICES] = {false, false, false, false};
      pinMode(led_pin, INPUT_PULLDOWN);  // LED driven by IO pin
      while (!Serial && (millis() < 2000)) ; // wait for Arduino Serial Monitor
      Serial.println("\n\nUSB Host Testing - USB Serial to USB Serial");
      myusb.begin();
    long led_on_time = 0;
    byte buffer[80];
    bool dtr_value = false;
      int ch;
      myusb.Task();
      if (Serial.available()) {
        while (Serial.read() != -1);
        dtr_value = !dtr_value;
        userial.setDTR(dtr_value);
        Serial.printf("Dtr set to %u\n", dtr_value);
      updateDeviceList();
      while (userial.available()) {
         Serial.write(userial.read());
    void updateDeviceList() {
      // Print out information about different devices.
      for (uint8_t i = 0; i < CNT_DEVICES; i++) {
        if (*drivers[i] != driver_active[i]) {
          if (driver_active[i]) {
            Serial.printf("*** Device %s - disconnected ***\n", driver_names[i]);
            driver_active[i] = false;
            Serial.printf("*** Device %s %x:%x - connected ***\n", driver_names[i], drivers[i]->idVendor(), drivers[i]->idProduct());
            driver_active[i] = true;
            const uint8_t *psz = drivers[i]->manufacturer();
            if (psz && *psz) Serial.printf("  manufacturer: %s\n", psz);
            psz = drivers[i]->product();
            if (psz && *psz) Serial.printf("  product: %s\n", psz);
            psz = drivers[i]->serialNumber();
            if (psz && *psz) Serial.printf("  Serial: %s\n", psz);
            // If this is a new Serial device.
            if (drivers[i] == &userial) {
              // Lets try first outputting something to our USerial to see if it will go out...
              userial.begin(baud);
    So far on FTDI breakout I confirmed the signals
    On Arduino Uno, I have simple sketch:
    uint16_t loop_count = 0;
      Serial.begin(38400);
      Serial.println("Program start");
      Serial.println(loop_count++, DEC);
    Which counts up. Playing with setting and clearing appears to restart the UNO...
    Have a few other chips to try ... Some of them I don't have with these signals...
    Germany
    9,058
    Great news! Thank you *very* much.
    I'll test it.
    Germany
    9,058
    Hm...
    DTR seems to work.
    But programming the UNO.. not.
    Not sure what the problem is.
    As a first experiment, i use avrdude on the PC where Teensy is just "man in the middle".
    Resetting the UNO with DTR seems to work.
    Attached my program. Teensy must be set to usb type "Dual Serial".
    The command to program the uno is:
    C:\Users\Frank\AppData\Local\Arduino15\packages\ar duino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\Frank\AppData\Local\Arduino15\packages\a rduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -PCOM19 -b115200 -D -Uflash:w:c:\temp\arduino_build_405010/Blink.ino.hex:i
    (modify the paths or just copy it from the verbose output when you program the uno)
    -PCOM19 is the com port
    It too late now... 1:10 AM .. time to sleep..tztzt
    This is the protocol: http://ww1.microchip.com/downloads/e...es/doc2525.pdf
    This a zipfile with the mentioned .h file: https://ww1.microchip.com/downloads/...tes/avr061.zip
    (in case some wants to take a look... :-) quite possible that i don't see something obvious)
    Attached Files Attached Files
    Germany
    9,058
    AVRDude sends Cmnd_STK_GET_SYNC, Sync_CRC_EOP - which is according to the PDF correct,
    But UNO (seems!) to answer 0x10, 0x14 which is wrong - should be 0x14, 0x10 <- wrong order.
    Why?
    Good night.
    New York
    7,469
    @KurtE
    Plugged in the 2 sketches to a Genuine Uno and a T4.1. Connected both up and they worked:
     Program start
    0
    1
    2
    3
    4
    5
    6
    7
    8
    9
    10
    Did the same thing for a Elegoo Uno with the same results:
     Program start
    0
    1
    2
    3
    4
    5
    6
    It does work with a T3.2 but not a T4.0 or a TMicroMod.
    Germany
    9,058
    Good Morning
    Interesting!
    I don't get why my programming attempt with avrdude does not work.
    Must be something strange.
    Perhaps it has to do with all the buffers involved? What do you think?
    Would it help to flush everything *somehow* after each byte in each direction?
    9,461
    Hard to tell... Let me check to see if I can figure out if they are doing something different instead of just doing dtr signal. We may also need to see if they are setting some special baud rate or ...
    New York
    7,469
    @Frank B - @KurtE
    Just gave the usbhost_programmer sketch a try along with using the blink sketch. Going to start where it diverges from the the direct upload:
    avrdude: Version 6.3-20190619
             Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
             Copyright (c) 2007-2014 Joerg Wunsch
             System wide configuration file is "C:\Users\Merli\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
             Using Port                    : COM20
             Using Programmer              : arduino
             Overriding Baud Rate          : 115200
    avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x10  Error but continues so sync probably reestablished?
             AVR Part                      : ATmega328P
             Chip Erase delay              : 9000 us
             PAGEL                         : PD7
             BS2                           : PC2
             RESET disposition             : dedicated
             RETRY pulse                   : SCK
             serial program mode           : yes
             parallel program mode         : yes
             Timeout                       : 200
             StabDelay                     : 100
             CmdexeDelay                   : 25
             SyncLoops                     : 32
             ByteDelay                     : 0
             PollIndex                     : 3
             PollValue                     : 0x53
             Memory Detail                 :
                                      Block Poll               Page                       Polled
               Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
               eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
               flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
               lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
               hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
               efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
               lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
               calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
               signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
             Programmer Type : Arduino
             Description     : Arduino
    avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x14
    avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x03
    avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x10  This is where seems to start getting strange
             Hardware Version: 4744608
             Firmware Version: 0.4611299  This shows as Arduino/Arduino with direct upload
             Vtarget         : 0.4 V
             Varef           : 0.3 V
             Oscillator      : 28.800 kHz
             SCK period      : 3.3 us
    avrdude: stk500_initialize(): (b) protocol error, expect=0x10, resp=0x04
    avrdude: initialization failed, rc=-1
             Double check connections and try again, or use -F to override
             this check.
    avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x10
    avrdude done.  Thank you.
    Not sure but maybe something is out of synch. If you look at the last printed data from the monitor for the last several messages:
    Send:0x20
    RCV:0x10
    RCV:0x14
    RCV:0x4
    RCV:0x10
    RCV:0x14
    RCV:0x10
    RCV:0x14
    9,461
    Good morning again,
    I think with your program, I might try adding a flush in both directions.
    I think I might also try something like in the section:
     if (usbserial_active) {
        dtr = SerialUSB1.dtr();
        digitalWriteFast(LED_BUILTIN, dtr);
        if (SerialUSB1.baud() != lastBaud {
            lastBaud = SerialUSB1.baud();
            usbserial.begin(lastBaud);
        if (dtr != lastDtr) {
          usbserial.setDTR( dtr );
          lastDtr = dtr;
    Not sure if it will work or not, but... It would be interesting to see if avrdude does change baud rates on you...
    9,461
    I have not yet enabled changing the baud rate... Will try that next... I am now monitoring it.
    Also changed the code to check to see how much data is sent or received per usb packet. And read it in all at once and send it all at once and then do flush...
    Debug output looks like:
    Programmer started.
    usbhost serial connected
    SerialUSB1 changed BAUD from 115200 to 0
    RCV(1): 0x0
    RCV(14): 0x50 0x72 0x6F 0x67 0x72 0x61 0x6D 0x20 0x73 0x74 0x61 0x72 0x74 0xD
    SerialUSB1 changed BAUD from 0 to 115200
    SerialUSB1 DTR change 1
    Send(2): 0x30 0x20
    RCV(2): 0xA 0x14
    Send(2): 0x30 0x20
    RCV(2): 0x10 0x14
    Send(2): 0x30 0x20
    RCV(2): 0x10 0x14
    Send(2): 0x30 0x20
    RCV(2): 0x10 0x14
    Send(3): 0x41 0x80 0x20
    RCV(3): 0x10 0x14 0x3
    Send(3): 0x41 0x81 0x20
    Send(3): 0x41 0x82 0x20
    RCV(6): 0x10 0x14 0x4 0x10 0x14 0x4
    Send(3): 0x41 0x98 0x20
    Send(3): 0x41 0x84 0x20
    RCV(6): 0x10 0x14 0x3 0x10 0x14 0x3
    Send(3): 0x41 0x85 0x20
    Send(3): 0x41 0x86 0x20
    Send(3): 0x41 0x87 0x20
    Send(3): 0x41 0x89 0x20
    Send(22): 0x42 0x86 0x0 0x0 0x1 0x1 0x1 0x1 0x3 0xFF 0xFF 0xFF 0xFF 0x0 0x80 0x4 0x0 0x0 0x0 0x80 0x0 0x20
    Send(2): 0x51 0x20
    SerialUSB1 DTR change 0
    RCV(4): 0x10 0x14 0x10 0x14
    RCV(15): 0x10 0x50 0x72 0x6F 0x67 0x72 0x61 0x6D 0x20 0x73 0x74 0x61 0x72 0x74 0xD
    AVRDude is still failing. Next up see if changing baud will help...
    Germany
    9,058
    Send(2): 0x30 0x20
    RCV(2): 0xA 0x14
    Send(2): 0x30 0x20
    RCV(2): 0x10 0x14
    Send(2): 0x30 0x20
    RCV(2): 0x10 0x14
    Send(2): 0x30 0x20
    Yup if I understand the pdf correctly, the uno should answer 0x14, 0x10
    Maybe we just have one byte too much.
    The first 0x0a is 0x00 for me..?!
    I think it shouldn't be there.
    Germany
    9,058
    *rant about the bootloader deleted*
    I'll try it again tonight for an hour, and if I don't get anywhere, I'll put it aside.
    Germany
    9,058
    @kurt: I enabled debug:
    ->usbhost serial connected.
    control callback (serial) 0
    CDCACM setup: 00 C2 01 00 00 00 08
    control callback (serial) 4
    Control - 0x21,0x22, 0x3
    setDTR: 0
    ->PC Connected. Baud:115200
    setDTR: 1
    ->Send: 0 0x30
    ->Send:   0x20
    txtimer
      TX data (2) 30 20
    tx1:
    rx token: 803E8100 transfer length: 64 len:2 - 14 10
    rx: 14 10
    ->Rcv: 0x00   0x14
    (messages of my sketch marked with "->")
    SO, it receives a correct packet 0x14, 0x10, but the sketch receives 0, 0x14
    There must be a little bug in the usb-host serial (because of DTR?)
