Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 26 to 50 of 58
Thread: @Kurt: USB_HOST (T4.1) Serial, hardware handshake
  1. #26
    9,056
    Fixed: https://github.com/PaulStoffregen/US...cf14eeff93fcaf
    Avrdude works now
    C:\Users\Frank>C:\Users\Frank\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\Frank\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -PCOM19 -b115200 -D -Uflash:w:c:\temp\arduino_build_405010/Blink.ino.hex:i
    avrdude: Version 6.3-20190619
             Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
             Copyright (c) 2007-2014 Joerg Wunsch
             System wide configuration file is "C:\Users\Frank\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
             Using Port                    : COM19
             Using Programmer              : arduino
             Overriding Baud Rate          : 115200
             AVR Part                      : ATmega328P
             Chip Erase delay              : 9000 us
             PAGEL                         : PD7
             BS2                           : PC2
             RESET disposition             : dedicated
             RETRY pulse                   : SCK
             serial program mode           : yes
             parallel program mode         : yes
             Timeout                       : 200
             StabDelay                     : 100
             CmdexeDelay                   : 25
             SyncLoops                     : 32
             ByteDelay                     : 0
             PollIndex                     : 3
             PollValue                     : 0x53
             Memory Detail                 :
                                      Block Poll               Page                       Polled
               Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
               eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
               flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
               lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
               hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
               efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
               lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
               calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
               signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
             Programmer Type : Arduino
             Description     : Arduino
             Hardware Version: 3
             Firmware Version: 4.4
             Vtarget         : 0.3 V
             Varef           : 0.3 V
             Oscillator      : 28.800 kHz
             SCK period      : 3.3 us
    avrdude: AVR device initialized and ready to accept instructions
    Reading | ################################################## | 100% 0.01s
    avrdude: Device signature = 0x1e950f (probably m328p)
    avrdude: safemode: lfuse reads as 0
    avrdude: safemode: hfuse reads as 0
    avrdude: safemode: efuse reads as 0
    avrdude: reading input file "c:\temp\arduino_build_405010/Blink.ino.hex"
    avrdude: writing flash (936 bytes):
    Writing | ################################################## | 100% 0.23s
    avrdude: 936 bytes of flash written
    avrdude: verifying flash memory against c:\temp\arduino_build_405010/Blink.ino.hex:
    avrdude: load data flash data from input file c:\temp\arduino_build_405010/Blink.ino.hex:
    avrdude: input file c:\temp\arduino_build_405010/Blink.ino.hex contains 936 bytes
    avrdude: reading on-chip flash data:
    Reading | ################################################## | 100% 0.21s
    avrdude: verifying ...
    avrdude: 936 bytes of flash verified
    avrdude: safemode: Fuses OK (E:00, H:00, L:00)
    avrdude done.  Thank you.
    This was a longstanding bug, has nothing to do with your DTR addition, so I commited the PR to Pauls repository.
  2. #27
    9,056
    The sketch I use is attached.
    It can be modified to be a subroutine that kicks in when programming is desired and do "normal" communication otherwise.
    With UNO, DTR can be used to detect programming start and ready programmed (perhaps better use a timeout here.)
    @Kurt: Shall we now try ESP? (would need rts..)
    Attached Files Attached Files
  3. #28
    9,430
    Avrdude works now
    Good catch , It is interesting that mostly used the Serial stuff for output...
    Note: looks like we need to fix :eek as well, as it does not increment the tail pointer for the character it is returning... Will add that on as well.
    Will try out your fix and sketch
  4. #29
    9,430
    It works!
    I have a mucked up version of your sketch:
    Reads and writes full buffers at a time.
    Has a USBHub object in case I plug it in through a hub.
    Prints out information about the serial object plugged in.
    And if you type any key in Serial object, it toggles debug output on and off...
    Now to see what the ESP32 needs...
  5. #30
    9,056
    Thank you
    Yes, peek() needs a fix, too.
    I think, we just need RTS, it will work, then.
    UNO / Arvdude/ Optiboot was a good proof that USB-Host serial should work good, now.
  6. #31
    7,429
    Plugged in a Mega 2560 but no joy in mudville:
    C:\Users\Merli>C:\Users\Merli\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\Merli\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega2560 -cwiring -PCOM20 -b115200 -D -Uflash:w:C:\Users\Merli\AppData\Local\Temp\arduino_build_510640/Blink.pde.hex:i
             System wide configuration file is "C:\Users\Merli\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
             Using Port                    : COM20
             Using Programmer              : wiring
    avrdude: stk500v2_ReceiveMessage(): timeout
    avrdude: stk500v2_getsync(): timeout communicating with programmer
    Teensy Sermon
    Programmer started.
     Debug output can be turned on by pressing any key
    usbhost serial connected
      manufacturer: Arduino (www.arduino.cc)
      product: Arduino (www.arduino.cc)
    SerialUSB1 changed BAUD from 0 to 115200
    SerialUSB1 DTR change 1
    Send(7): 0x1B 0x1 0x0 0x1 0xE 0x1 0x14
    RCV(6): 0x0 0x1B 0x1 0x0 0xB 0xE
    RCV(11): 0x1 0x0 0x8 0x41 0x56 0x52 0x49 0x53 0x50 0x5F 0x32
    Send(7): 0x1B 0x2 0x0 0x1 0xE 0x1 0x17
    RCV(17): 0x74 0x1B 0x2 0x0 0xB 0xE 0x1 0x0 0x8 0x41 0x56 0x52 0x49 0x53 0x50 0x5F 0x32
    Send(7): 0x1B 0x3 0x0 0x1 0xE 0x1 0x16
    RCV(17): 0x77 0x1B 0x3 0x0 0xB 0xE 0x1 0x0 0x8 0x41 0x56 0x52 0x49 0x53 0x50 0x5F 0x32
    Send(7): 0x1B 0x4 0x0 0x1 0xE 0x1 0x11
    RCV(3): 0x76 0x1B 0x4
    RCV(14): 0x0 0xB 0xE 0x1 0x0 0x8 0x41 0x56 0x52 0x49 0x53 0x50 0x5F 0x32
    Send(7): 0x1B 0x5 0x0 0x1 0xE 0x1 0x10
    RCV(17): 0x71 0x1B 0x5 0x0 0xB 0xE 0x1 0x0 0x8 0x41 0x56 0x52 0x49 0x53 0x50 0x5F 0x32
    Send(7): 0x1B 0x6 0x0 0x1 0xE 0x1 0x13
    RCV(17): 0x70 0x1B 0x6 0x0 0xB 0xE 0x1 0x0 0x8 0x41 0x56 0x52 0x49 0x53 0x50 0x5F 0x32
    SerialUSB1 DTR change 0
    Next post a DUE
  7. #32
    9,056
    Have you used the fix?
    Can you try the non-buffered version?
    Do the boards use DTR only?
    Frank
  8. #33
    7,429
    For the Due - looks like may changing the baud to 1200bps?
    Send auto-baud
    Set binary mode
    No device found on COM20
    Programmer started.
      product: Arduino Due Prog. Port
      Serial: 8
    Send(1): 0x80
    Send(1): 0x80
    Send(1): 0x23
    Send(2): 0x4E 0x23
    Send(12): 0x77 0x30 0x30 0x30 0x30 0x30 0x30 0x30 0x30 0x2C 0x34 0x23
    EDIT: Ok think I broke my due.... Any probably wouldn't have worked anyway since is uses bossac and not avrdude - was just experimenting now back to Mega
  9. #34
    7,429
    Frank
    A couple of things.
    Yes I have your fix nice catch
    Can;t seem to find anything definitive but think yes, I think it may need RTS as well for the mega: https://forum.arduino.cc/t/does-avrd...reset/635894/8, maybe. From what I am seeing as well the mega doesnt use the stk500v2 but wiring so something different: https://false.ekta.is/2011/05/avrdud...ine-uploading/
    Did find a nice reference though for avrdude
    http://ladyada.net/learn/avr/avrdude.html
  10. #35
    9,056
    A couple of things.
    I don't have these boards ... no i do not buy them.. have too much of this stuff here..
  11. #36
    7,429
    Don't blame you - rarely use them anymore since the Teensy. Have enough as well. Guess will have to see about a non arduino board
  12. #37
    9,430
    Just pushed up some changes in the USBHost code. Brought in Frank's fix, plus peek.
    Also tried with CP210x board... ESP32 Micromod... It was totally hanging the Teensy... Did not properly handle the usbSerial.end() function on these... So put in some code to handle that.
    Still it is not fully connecting up...
    SerialUSB1 changed BAUD from 9600 to 115200
    Send(46): 0xC0 0x0 0x8 0x24 0x0 0x0 0x0 0x0 0x0 0x7 0x7 0x12 0x20 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0x55 0xC0
    RCV(64): 0x13 0x82 0x72 0x2 0x8C 0x6C 0xF2 0x70 0x2 0x8C 0x6C 0xC 0x8C 0xC 0x24 0x6C 0xC 0x6C 0x8C 0x8C 0x8C 0x6C 0x8C 0xC 0x8E 0x8E 0xE 0x6C 0x72 0x6C 0x8C 0x72 0x82 0x62 0xC 0xC 0x72 0xC 0x4 0x23 0x6C 0x9E 0xF2 0x12 0x6C 0x13 0x72 0x92 0x90 0x92 0x6C 0x70 0x8C 0xF2 0x6E 0x6E 0xDE 0x1E 0x80 0xC 0x12 0xEC 0xC 0xC
    RCV(64): 0x62 0x6C 0x80 0x12 0x6C 0x12 0x90 0x80 0x8E 0x82 0x92 0x12 0x90 0x6C 0x80 0x8E 0x2 0x6C 0x12 0x60 0x7E 0xF2 0x6C 0x92 0x6C 0x72 0x6C 0xE 0xF2 0x6E 0x6E 0x9C 0xEC 0x1E 0x72 0x12 0x6E 0x62 0xC 0xC 0xC 0x63 0xEC 0x12 0x92 0x6C 0x92 0x12 0x1F 0x80 0xC 0x92 0x92 0x92 0x60 0x2 0xE 0xC3 0x6E 0x72 0xFE 0x82 0x62 0xE2
    RCV(64): 0x62 0xC 0xC 0x2 0xC 0xC 0x62 0xF0 0xFF 0x82 0x62 0xE2 0x62 0xC 0xC 0x2 0xC 0xC 0x62 0x9C 0x12 0x9C 0x7C 0x9C 0x62 0xC 0xC 0x2 0xC 0xC 0x62 0x70 0x8E 0x2 0xEC 0x12 0x9C 0x7C 0x9C 0x62 0xC 0xC 0x3 0xC 0xC 0x62 0x6F 0x9C 0x12 0x9C 0x7C 0x9C 0x62 0xC 0xC 0x2 0xC 0xC 0x63 0x9E 0xF2 0x12 0x9C 0x7C
    RCV(64): 0x9C 0x62 0xC 0xC 0x2 0xC 0x24 0x60 0x2 0x72 0xF2 0x6E 0x9C 0xE2 0xEC 0xC 0x90 0x8C 0x7E 0x82 0x62 0xE4 0x82 0x6E 0x6E 0x70 0x6E 0x2 0xC 0x9C 0xEC 0x9C 0x62 0x6C 0x6C 0x60 0x2 0x70 0xF2 0x6E 0xE0 0x10 0x62 0xC 0xC 0x72 0x8C 0x9C 0x9C 0x9C 0xC 0x6C 0xC 0xC 0x62 0x6E 0xE3 0x7C 0x62 0xC 0x8E 0xE 0x6C 0x70
    RCV(64): 0xF2 0x6E 0xE0 0x10 0x62 0xC 0xC 0x72 0x8C 0x9C 0x9C 0x9C 0xC 0x6C 0xEC 0x82 0x62 0x6E 0xE2 0x7C 0x62 0x6C 0x8C 0x6C 0x8C 0x8E 0xF 0x6C 0x60 0xF2 0x6E 0xC 0xC 0xC 0x9E 0xE0 0x62 0x82 0x6E 0x6C 0x8C 0xC 0x8C 0xF2 0x6E 0x6F 0xEF 0x0 0xC 0x8E 0xE 0x6C 0x70 0xF2 0x6E 0xE0 0x10 0x62 0xC 0xC 0x82 0xC 0xC 0xEC
    RCV(64): 0x8E 0xC 0xC 0xC 0xC 0x63 0x27 0xE2 0x7C 0x62 0x6C 0xEC 0x8E 0x1C 0x80 0x6C 0x20 0x2 0x60 0xF2 0x6E 0xC 0xC 0xC 0x9E 0xE0 0x62 0x82 0x27 0x6C 0x8C 0xC 0x8C 0xF2 0x6E 0x6E 0xEE 0x0 0xC 0x8E 0xE 0x6C 0x70 0xF2 0x6E 0xE0 0x10 0x62 0xC 0xC 0x82 0xC 0xC 0xC 0xC 0xC 0x8E 0xC 0xC 0x22 0x6F 0xE2 0x7C 0x62
    RCV(29): 0x8C 0x8E 0x1C 0xDB 0xC4 0x6C 0x60 0x2 0x12 0xE2 0x6E 0x9E 0x7C 0xE2 0x2 0xC 0xC 0x82 0xC 0xC 0xC 0xC 0x8C 0x8E 0x70 0xE0 0x6C 0x60 0x2
    RCV(15): 0x50 0x72 0x6F 0x67 0x72 0x61 0x6D 0x20 0x73 0x74 0x61 0x72 0x74 0xD 0xA
    RCV(64): 0x13 0x82 0x72 0x2 0x8C 0x6C 0xF2 0x70 0x2 0x8C 0x6C 0xC 0x8C 0xC 0x6C 0x6C 0xC 0x6C 0x8C 0x8C 0x8C 0x6C 0x8C 0xC 0x8E 0x8E 0xE 0x6C 0x72 0x6C 0x8C 0x3B 0x82 0x62 0xC 0xC 0x72 0xC 0xC 0x62 0x6C 0x9E 0xF2 0x13 0x6C 0x12 0x72 0x92 0x90 0x92 0x6C 0x70 0x8C 0xF2 0x6E 0x6E 0x9E 0x1E 0x80 0xC 0x12 0xEC 0xC 0xC
    RCV(64): 0x62 0x6C 0x80 0x12 0x24 0x1B 0xD8 0xC0 0xC7 0xC3 0xDB 0x1B 0xD8 0x24 0x80 0x8E 0x2 0x6C 0x12 0x60 0x7E 0xF2 0x6C 0x92 0x6C 0x72 0x6C 0xE 0xF2 0x6F 0x6E 0x9C 0xEC 0x1E 0x72 0x12 0x6E 0x62 0xC 0xC 0xC 0x23 0xEC 0x12 0x92 0x6C 0x92 0x12 0x1E 0x80 0xC 0x92 0x92 0x92 0x20 0x3 0xE 0x82 0x6E 0x72 0xFE 0x82 0x62 0xE3
    RCV(64): 0x62 0x4 0x4 0x3 0x4 0x4 0x23 0xF8 0xFF 0xC3 0x62 0xE2 0x62 0xC 0xC 0x2 0xC 0x4 0x63 0x9C 0x12 0x9C 0x7C 0x9C 0x62 0xC 0xC 0x2 0xC 0xC 0x62 0x70 0x8E 0x2 0xEC 0x12 0x9C 0x7C 0x9C 0x62 0x4 0xC 0x2 0xC 0xC 0x62 0x27 0x9C 0x12 0x9C 0x7C 0x9C 0x62 0xC 0xC 0x2 0xC 0xC 0x62 0x9E 0xF2 0x12 0x9C 0x7C
    RCV(64): 0x9C 0x62 0xC 0xC 0x2 0xC 0x64 0x60 0x3 0x72 0xF2 0x6E 0x9C 0xE2 0xEC 0xC 0x90 0x8C 0x7E 0x82 0x62 0xEC 0x82 0x6F 0x6E 0x70 0x6E 0x2 0xC 0x9C 0xEC 0x9C 0x23 0x6C 0x6C 0x60 0x2 0x70 0xF2 0x6F 0xE0 0x10 0x23 0xC 0xC 0x72 0x8C 0x9C 0x9C 0x9C 0xC 0x6C 0xC 0xC 0x62 0x6E 0xE2 0x7C 0x62 0xC 0x8E 0x7 0x6C 0x70
    RCV(64): 0xF2 0x6E 0xE0 0x10 0x63 0xC 0xC 0x72 0x8C 0x9C 0x9C 0x9C 0xC 0x6C 0xEC 0x82 0x62 0x6E 0xE2 0x7C 0x22 0x6C 0x8C 0x6C 0x8C 0x8E 0x7 0x6C 0x60 0xF2 0x6F 0xC 0xC 0xC 0x9E 0xE0 0x62 0x82 0x6E 0x6C 0xC4 0xC 0x8C 0xF2 0x6E 0x6E 0xEE 0x0 0xC 0x8E 0xE 0x6C 0x70 0xF3 0x6E 0xE0 0x10 0x62 0x4 0xC 0x82 0xC 0xC 0xEC
    RCV(64): 0x8E 0xC 0xC 0xC 0xC 0x62 0x6E 0xE2 0x3C 0x62 0x6C 0xEC 0x8E 0x1C 0x80 0x6C 0x60 0x2 0x60 0xF2 0x6E 0xC 0xC 0xC 0x9E 0xE0 0x62 0x82 0x6F 0x6C 0x8C 0xC 0x8C 0xF2 0x6E 0x6E 0xEE 0x0 0xC 0x8E 0x7 0x6C 0x70 0xF2 0x6E 0xE0 0x10 0x62 0xC 0x4 0x82 0xC 0xC 0xC 0xC 0xC 0x8E 0xC 0xC 0x63 0x6E 0xE2 0x7C 0x62
    RCV(29): 0x8C 0x8E 0x1C 0x93 0x84 0x6C 0x20 0x2 0x12 0xE2 0x6F 0x9F 0x7C 0xE2 0x2 0xC 0xC 0x82 0xC 0xC 0x4 0xC 0x8C 0x8E 0x38 0xE0 0x6C 0x60 0x2
    C:\\Users\\kurte\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-size" -A "C:\\Users\\kurte\\AppData\\Local\\Temp\\arduino_build_582690/bar.ino.elf"
    Sketch uses 213209 bytes (16%) of program storage space. Maximum is 1310720 bytes.
    Global variables use 15372 bytes (4%) of dynamic memory, leaving 312308 bytes for local variables. Maximum is 327680 bytes.
    C:\Users\kurte\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\2.6.1/esptool.exe --chip esp32 --port COM27 --baud 921600 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0xe000 C:\Users\kurte\AppData\Local\Arduino15\packages\SparkFun\hardware\esp32\1.0.0/tools/partitions/boot_app0.bin 0x1000 C:\Users\kurte\AppData\Local\Arduino15\packages\SparkFun\hardware\esp32\1.0.0/tools/sdk/bin/bootloader_qio_80m.bin 0x10000 C:\Users\kurte\AppData\Local\Temp\arduino_build_582690/bar.ino.bin 0x8000 C:\Users\kurte\AppData\Local\Temp\arduino_build_582690/bar.ino.partitions.bin
    esptool.py v2.6
    Serial port COM27
    Connecting........_____....._____....._____....._____....._____....._____....._____
    A fatal error occurred: Failed to connect to ESP32: Timed out waiting for packet header
  13. #38
    9,056
    Hm, the ESP-Boards I know use RTS (i.e. "nodeMcu"). In the log above i see no RTS..
  14. #39
    9,430
    Note everywhere you see DTR change it is doing both DTR and RTS...
    I geared it after the CP210 Linux driver which:
    static void cp210x_dtr_rts(struct usb_serial_port *p, int on)
    	if (on)
    		cp210x_tiocmset_port(p, TIOCM_DTR|TIOCM_RTS, 0);
    		cp210x_tiocmset_port(p, 0, TIOCM_DTR|TIOCM_RTS);
    Sets both and clears both...
    Update: It was able to program an older Arduino Mega 1280 board I have.
    As for the Leonardo... It may have wiped it out... Now it is causing the Teensy program to die... I think I need to add the crash code!
  15. #40
    9,056
    2016 I wrote some code for T3... it did not uses USBHost but a hardware-Serial.
    With this program, I could flash a ESP8266 sucessfully, with the official tools:
    (needs both handshake signals to reset & set the ESP into flashing mode afterwards)
    https://github.com/FrankBoesing/Flex...ashESP8266.ino
  16. #41
    7,429
    	if (on)
    Just tried it on the Mega2560 I was testing with earlier and it worked - slow but it worked:
             Using Port                    : COM20
             AVR Part                      : ATmega2560
             PAGEL                         : PD7
             BS2                           : PA0
             RETRY pulse                   : SCK
             Timeout                       : 200
             StabDelay                     : 100
             CmdexeDelay                   : 25
             SyncLoops                     : 32
             ByteDelay                     : 0
             PollIndex                     : 3
             PollValue                     : 0x53
             Memory Detail                 :
               eeprom        65    10     8    0 no       4096    8      0  9000  9000 0x00 0x00
               flash         65    10   256    0 yes    262144  256   1024  4500  4500 0x00 0x00
               lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
               hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
               efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
               lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
             Programmer Type : Wiring
             Description     : Wiring
             Programmer Model: AVRISP
             Hardware Version: 15
             Firmware Version Master : 2.10
             Vtarget         : 0.0 V
             SCK period      : 0.1 us
    Reading | ################################################## | 100% 0.02s
    avrdude: Device signature = 0x1e9801 (probably m2560)
    avrdude: safemode: lfuse reads as FF
    avrdude: safemode: hfuse reads as D8
    avrdude: safemode: efuse reads as FF
    avrdude: reading input file "C:\Users\Merli\AppData\Local\Temp\arduino_build_436201/Blink.pde.hex"
    avrdude: writing flash (1536 bytes):
    Writing |                                                    | 0% 0.00savrdude: stk500v2_ReceiveMessage(): timeout
    Writing | ########                                           | 16% 5.02savrdude: stk500v2_ReceiveMessage(): timeout
    Writing | #################                                  | 33% 10.05savrdude: stk500v2_ReceiveMessage(): timeout
    Writing | #########################                          | 50% 15.07savrdude: stk500v2_ReceiveMessage(): timeout
    Writing | #################################                  | 66% 20.10savrdude: stk500v2_ReceiveMessage(): timeout
    Writing | ##########################################         | 83% 25.12savrdude: stk500v2_ReceiveMessage(): timeout
    Writing | ################################################## | 100% 30.15s
    avrdude: 1536 bytes of flash written
    avrdude: verifying flash memory against C:\Users\Merli\AppData\Local\Temp\arduino_build_436201/Blink.pde.hex:
    avrdude: load data flash data from input file C:\Users\Merli\AppData\Local\Temp\arduino_build_436201/Blink.pde.hex:
    avrdude: input file C:\Users\Merli\AppData\Local\Temp\arduino_build_436201/Blink.pde.hex contains 1536 bytes
    avrdude: 1536 bytes of flash verified
    avrdude: safemode: Fuses OK (E:FF, H:D8, L:FF)
    QUESTION: How did you try to load to the ESP32?
  17. #42
    9,056
    Kurt, RTS & CTS are different:
    Name:  2021-07-13 21_36_05-nodemcu-32s_product_specification.pdf.png
    See linked PDF (Post #1 )
    It needs all 4 possible states.. DTR 0 RTS 0 , DTR 1 RTS 0 , DTR 0 RTS 1, DTR 1 RTS 1
  18. #43
    7,429
    Just tried the Due again but still no luck. But at least the Mega is working.
    C:\Users\Merli>C:\Users\Merli\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.6.1-arduino/bossac.exe -i -d --port=COM20 -U false -e -w -v -b C:\Users\Merli\AppData\Local\Temp\arduino_build_436201/Blink.pde.bin -R
    Send auto-baud
    Set binary mode
    Funny that it can not find the device must be something with the way bossac works
    EDIT: Not sure you are going to get there, i.e., supporting the due. Bossac is going to be looking for a SAM chip.
    http://www.shumatech.com/web/products/bossa
    and looks like you have to do an erase of the Due first:
    Either of the USB ports can be used for programming the board, though it is recommended to use the Programming port due to the way the erasing of the chip is handled :
    • Programming port: To use this port, select "Arduino Due (ProgrammingPort)" as your board in the Arduino IDE. Connect the Due's programming port (the one closest to the DC power jack) to your computer. The programming port uses the 16U2 as a USB-to-serial chip connected to the first UART of the SAM3X (RX0 and TX0). The 16U2 has two pins connected to the Reset and Erase pins of the SAM3X. Opening and closing the Programming port connected at 1200bps triggers a “hard erase” procedure of the SAM3X chip, activating the Erase and Reset pins on the SAM3X before communicating with the UART. This is the recommended port for programming the Due. It is more reliable than the "soft erase" that occurs on the Native port, and it should work even if the main MCU has crashed.
    • Native port: To use this port, select "Arduino Due (NativeUSBPort)" as your board in the Arduino IDE. The Native USB port is connected directly to the SAM3X. Connect the Due's Native USB port (the one closest to the reset button) to your computer. Opening and closing the Native port at 1200bps triggers a 'soft erase' procedure: the flash memory is erased and the board is restarted with the bootloader. If the MCU crashed for some reason it is likely that the soft erase procedure won't work as this procedure happens entirely in software on the SAM3X. Opening and closing the native port at a different baudrate will not reset the SAM3X.
    Unlike other Arduino boards which use avrdude for uploading, the Due relies on bossac.The ATmega16U2 firmware source code is available in the Arduino repository. You can use the ISP header with an external programmer (overwriting the DFU bootloader). See this user-contributed tutorial for more information.
  19. #44
    9,430
    @frankB - Yep I understand RTS is different than CTS... Question is how do they do this over USB... More on this in a bit.
    As for Leonardo... I think it was left in a state of NOT happy... So when I plug it back in, it keeps rebooting the T4.1...
    Put in Crashreport...
    CrashReport:
      A problem occurred at (system time) 11:4:59
      Code was executing from address 0x4BC
      CFSR: 82
    	(DACCVIOL) Data Access Violation
    	(MMARVALID) Accessed Address: 0x9 (nullptr)
    	  Check code at 0x4BC - very likely a bug!
    	  Run "addr2line -e mysketch.ino.elf 0x4BC" for filename & line number.
      Temperature inside the chip was 46.54 °C
      Startup CPU clock speed is 600MHz
    Programmer started.
    *** debug on ***
    C:\Users\kurte\AppData\Local\Temp\arduino_build_usbhost_programmer.ino>addr2line -e usbhost_programmer.ino.elf 0x4d0
    C:\Users\kurte\Documents\Arduino\libraries\USBHost_t36/ehci.cpp:799 (discriminator 1)
    So faulting in:
    bool USBHost::queue_Transfer(Pipe_t *pipe, Transfer_t *transfer)
    	// find halt qTD
    	Transfer_t *halt = (Transfer_t *)(pipe->qh.next);
    	while (!(halt->qtd.token & 0x40)) halt = (Transfer_t *)(halt->qtd.next);
    	// transfer's token
    So need to turn on debug...
  20. #45
    7,429
    @KurtE
    Not going to be able to test a Leonardo as I don't have one sorry. I ran into a similar problem with the due - reinstalled the board drivers from Arduino and reloaded the sketch to the Leonardo - that seemed to clear the issue. Maybe just reloading a sketch the leonardo will help - you probably tried this one already.
  21. #46
    9,430
    @KurtE
    Yes was able to program Leonardo directly... Issue at connection telling it to have DTR... Not processed... Commented out that setting, which keeps us from crashing. But still not programming.
    It was interesting that trying to program the Leonardo it know something about Serial26 and 27... Which I am trying 27 SerialUSB1...
  22. #47
    9,056
    Arduino(or was it platformio? - too late for me) finds the right COM Port, too - it's magic. No.. i guess it parses the USB names or PIDs.. some day i'll add the right PIDs to the .ino. Thanks to the forum, I learned a few days ago that this is possible.
    Then, there are boards that use USB directly (no serial emulation?),I've seen that in the AvrDude sourcecode, but did not dig deeper since it was not interesting.
    Kurt: Is there any chance I can reproduce the crash you're seeing?
    From what you're describing, the crash looks somewhat similar to the weird effect in the main USB-Serial i fixed together with Paul a few days ago.
    The problem was that the timer triggered a transfer at a time when the main code modified values.. we had to set flags to stop this. Perhaps you've followed the thread @ github.
    So now back to Ice+Coke+Bacardi
  23. #48
    9,430
    Right now, I have the crash not crashing...
    I hacked the claim code for the CDCACM mode that at the end it was always turned on the DTR...
    So turned that off:
    		// Wish I could just call Control to do the output... Maybe can defer until the user calls begin()
    		// control requires that device is setup which is not until this call completes...
    #if 0
    		println("Control - CDCACM DTR...");
    		// Need to setup  the data the line coding data
    		mk_setup(setup, 0x21, 0x22, 3, 0, 0);
    		queue_Control_Transfer(dev, &setup, NULL, this);
    		control_queued = true;
    		pending_control = 0x0;	// Maybe don't need to do...
    #else
    		control_queued = false;
    		return true;
    And not crashing... But not sure what else that might impact.
  24. #49
    9,430
    Still WIP - I pushed up current changes to USBHost branch...
    Also my current updated sketch:
    Where I now have split the DTR and RTS functions.
      if (usbserial_active) {
        dtr = SerialUSB1.dtr();
        rts = SerialUSB1.rts();
        baud = SerialUSB1.baud();
        digitalWriteFast(LED_BUILTIN, dtr);
        if (dtr != lastDtr) {
          if (debug_output) Serial.printf("SerialUSB1 DTR change %u\n", dtr);
          usbserial.setDTR( dtr );
          lastDtr = dtr;
        if (rts != lastRts) {
          if (debug_output) Serial.printf("SerialUSB1 RTS change %u\n", rts);
          usbserial.setRTS( rts );
          lastRts = rts;
    I have not updated all of the USB Serial types yet, but did update the one ESP32 uses and FTDI... CDCACM, I think I need to locally hold state values...
    Anyway, some of the time having success with ESP32:
    esptool.py v2.6
    Serial port COM27
    Chip is ESP32D0WDQ6 (revision 1)
    Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
    MAC: 24:6f:28:8f:5b:18
    Uploading stub...
    Running stub...
    Stub running...
    Changing baud rate to 921600
    Changed.
    Configuring flash size...
    Auto-detected Flash size: 16MB
    Compressed 8192 bytes to 47...
    Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.0 seconds (effective 5957.9 kbit/s)...
    Hash of data verified.
    Flash params set to 0x024f
    Compressed 17392 bytes to 11186...
    Wrote 17392 bytes (11186 compressed) at 0x00001000 in 0.1 seconds (effective 1038.3 kbit/s)...
    Compressed 213328 bytes to 108774...
    Wrote 213328 bytes (108774 compressed) at 0x00010000 in 1.7 seconds (effective 976.9 kbit/s)...
    Compressed 3072 bytes to 128...
    Wrote 3072 bytes (128 compressed) at 0x00008000 in 0.0 seconds (effective 2234.2 kbit/s)...
    Leaving...
    Hard resetting via RTS pin...
    Although I don't think it is resetting properly... But if I unplug and plug it back in, it does show a different blink (I changed blink length)...
    Note CDCACM is in the unknown state...
    Update: Pushed up more changes to DTR... remember state of what I have sent so know when each one changes...
    Tested on UNO and Mega
  25. #50
    9,056
    Good morning!
    Wow, a lot happened while I was sleeping.
    I probably won't be able to try this out until tonight.
    If this works (almost) now, you could even write a tool for the Teensy that reads and programs a hex file from the SD card/littlfs or similar. Avrdude or an ESP tool on the Teensy.... I'm just not sure if you really need something like that.
    In any case, it makes development much easier. No more plugging and unplugging... and the working programmers show that usbhost-serial works pretty good.
