DaveBoulden
I have been building a MIDI related project running on a Teensy 4.0 for a few months and recently upgraded to Teensyduino 1.54 to gain access to the new LittleFS capabilities.
I seem to have suffered a weird side effect of losing MIDI output from the Teensy. It still responds to MIDI input, the serial port for debugging is still working and I can send out keystrokes through the Keyboard class, just no MIDI output.
My project has an augmented USB type that I have overridden in usb_desc.h, but have not changed it since updating to Teensyduino 1.54. I created a small test sketch and still no MIDI output. The relevant code is pasted below. Can anyone see something I need to change to match Teensyduino 1.54 or do I have some other problem?
Updated usb_desc.h (code compiled with build flag: "-D USB_MIDI_SERIAL"):
Included names.c to override MIDI port name:
Main test sketch:
#elif defined(USB_MIDI_SERIAL)
#define VENDOR_ID 0x16C0
#define PRODUCT_ID 0x0489
#define MANUFACTURER_NAME {'B','O','U','L','D','E','N','.','d','i','g','i','t','a','l'}
#define MANUFACTURER_NAME_LEN 15
#define PRODUCT_NAME {'C','o','m','p','o','s','e','r','C','t','r','l','-','1'}
#define PRODUCT_NAME_LEN 14
#define EP0_SIZE 64
#define NUM_ENDPOINTS 6
#define NUM_INTERFACE 5
#define CDC_IAD_DESCRIPTOR 1
#define CDC_STATUS_INTERFACE 0
#define CDC_DATA_INTERFACE 1 // Serial
#define CDC_ACM_ENDPOINT 2
#define CDC_RX_ENDPOINT 3
#define CDC_TX_ENDPOINT 3
#define CDC_ACM_SIZE 16
#define CDC_RX_SIZE_480 512
#define CDC_TX_SIZE_480 512
#define CDC_RX_SIZE_12 64
#define CDC_TX_SIZE_12 64
#define MIDI_INTERFACE 2 // MIDI
#define MIDI_NUM_CABLES 1
#define MIDI_TX_ENDPOINT 4
#define MIDI_TX_SIZE_12 64
#define MIDI_TX_SIZE_480 512
#define MIDI_RX_ENDPOINT 4
#define MIDI_RX_SIZE_12 64
#define MIDI_RX_SIZE_480 512
#define KEYBOARD_INTERFACE 3 // Keyboard
#define KEYBOARD_ENDPOINT 5
#define KEYBOARD_SIZE 8
#define KEYBOARD_INTERVAL 1
#define KEYMEDIA_INTERFACE 4 // Keyboard Media Keys
#define KEYMEDIA_ENDPOINT 6
#define KEYMEDIA_SIZE 8
#define KEYMEDIA_INTERVAL 4
#define ENDPOINT2_CONFIG ENDPOINT_RECEIVE_UNUSED + ENDPOINT_TRANSMIT_INTERRUPT
#define ENDPOINT3_CONFIG ENDPOINT_RECEIVE_BULK + ENDPOINT_TRANSMIT_BULK
#define ENDPOINT4_CONFIG ENDPOINT_RECEIVE_BULK + ENDPOINT_TRANSMIT_BULK
#define ENDPOINT5_CONFIG ENDPOINT_RECEIVE_UNUSED + ENDPOINT_TRANSMIT_INTERRUPT
#define ENDPOINT6_CONFIG ENDPOINT_RECEIVE_UNUSED + ENDPOINT_TRANSMIT_INTERRUPT
// To give your project a unique name, this code must be
// placed into a .c file (its own tab). It can not be in
// a .cpp file or your main sketch (the .ino file).
#include "usb_names.h"
// Edit these lines to create your own name. The length must
// match the number of characters in your custom name.
#define SERIAL_NUMBER { 'B', 'D', '-', 'C', 'C', '1', '-', '0', '0', '1' }
#define SERIAL_NUMBER_LEN 10
struct usb_string_descriptor_struct usb_string_manufacturer_name = {
2 + MANUFACTURER_NAME_LEN * 2,
3,
MANUFACTURER_NAME};
struct usb_string_descriptor_struct usb_string_product_name = {
2 + PRODUCT_NAME_LEN * 2,
3,
PRODUCT_NAME};
struct usb_string_descriptor_struct usb_string_serial_number = {
2 + SERIAL_NUMBER_LEN * 2,
3,
SERIAL_NUMBER};
Main test sketch:
#include <Arduino.h>
while (!Serial && millis() < 1000);
usbMIDI.read();
uint8_t rsltSysex[3] = { 0x12, 0x7F, 0x00 };
usbMIDI.sendSysEx(3, rsltSysex, false);
usbMIDI.sendNoteOn(64, 127, 1);
usbMIDI.send_now();
usbMIDI.sendNoteOff(64, 0, 1);
usbMIDI.send_now();
delay(2000);
