Results 1 to 4 of 4
Thread: Teensy 4.1 MIDI iN using 6N138 5V or 3.3V
    Does the IC work with 3.3V or does it need 5V? If 5V, is the output compatible with Rx0 Pin?
    Senior Member ETMoody3's Avatar
    Mar 2014
    New Ulm, Mn
    176
    As far as I know No, the 6N138 does not work at 3.3 v.
    Look at the Adafruit midi feather wing which operates directly with 3.3v logic or consider a suitable logic level shifter like TXS0108E
    https://www.adafruit.com/product/4740
    Alternative is to use this schematic which powers the 6N138 at 5 v but pulls the output logic to a safe 3.3v.
    24,834
    6N138 does indeed require 5V power.
    But it can give a 3.3V output signal while running on 5V power. Its output is open collector, so just connect the 470 ohm pullup resistor to 3.3V. See the schematic on this page for details:
    https://www.pjrc.com/teensy/td_libs_MIDI.html
    Thanks. So my design should work?
