Results 1 to 5 of 5
Thread: Teensyduino 1.54 SD Errors
    Jul 2017
    103
    Hi all, i'm having errors compiling on 3.6 using the built in sd, i tried compiling the "SD > Files" example which is exactly how i use the library on my sketches and also gets the same compile errors, it's mainling and redefinition error for File
    error: redefinition of 'class File' class File : public Stream {
    error: previous definition of 'class File' class File : public FatFile, public Stream {
    another common error is
    error: 'class SDClass' has no member named 'sdfs'
    Is there a workaround that i'm not aware of? i keep seeing that the SD library has a compatibility layer to work with old libraries but i can't get it work.
    Germany
    9,318
    Tried that -> no problems.
    Please check if you have other versions of df.h or sdfat installed. if yes, delete them.
    If you have still problems, please post the output of verbose compile.
    3,318
    do you have some sdfat-beta or local sdfat libraries around?
    Jul 2017
    103
    I didn't even realized i had a local SDFAT library installed, removing it fixed the issues, thank you for your help!
    Germany
    9,318
    You see that in the compiler window
