Hi
Im working on sampler and i come across bug that when to much pads(to many midi messages) are sent from beatstep teensy freezes and crashes.
This is the code that im using witch is still WIP teense is clocked at 600Mhz.
Could this be to slow response of optocoupler or is this software problem? I'm using schematic of midi connection from PJRC midi library page.
//LIBS
#include <SerialFlash.h>
#include <MIDI.h>
#include <LiquidCrystal_I2C.h>
#include <Encoder.h>
//CLASSES
LiquidCrystal_I2C lcd(0x27, 16, 2); // I2C address 0x27, 16 column and 2 rows
Encoder myEnc(4, 5);
MIDI_CREATE_INSTANCE(HardwareSerial, Serial1, MIDI);
AudioPlaySdWav playSdWav1;
AudioPlaySdWav playSdWav4;
AudioPlaySdWav playSdWav3;
AudioPlaySdWav playSdWav2;
AudioPlaySdWav playSdWav9;
AudioPlaySdWav playSdWav8;
AudioPlaySdWav playSdWav15;
AudioPlaySdWav playSdWav6;
AudioPlaySdWav playSdWav5;
AudioPlaySdWav playSdWav7;
AudioPlaySdWav playSdWav14;
AudioPlaySdWav playSdWav16;
AudioPlaySdWav playSdWav11;
AudioPlaySdWav playSdWav12;
AudioPlaySdWav playSdWav13;
AudioPlaySdWav playSdWav10;
AudioMixer4 mixer7;
AudioMixer4 mixer3;
AudioMixer4 mixer4;
AudioMixer4 mixer6;
AudioMixer4 mixer8;
AudioMixer4 mixer2;
AudioMixer4 mixer9;
AudioMixer4 mixer1;
AudioMixer4 mixer5;
AudioMixer4 mixer10;
AudioOutputI2S i2s1;
AudioConnection patchCord1(playSdWav1, 0, mixer4, 0);
AudioConnection patchCord2(playSdWav1, 1, mixer6, 0);
AudioConnection patchCord3(playSdWav4, 0, mixer4, 3);
AudioConnection patchCord4(playSdWav4, 1, mixer6, 3);
AudioConnection patchCord5(playSdWav3, 0, mixer4, 2);
AudioConnection patchCord6(playSdWav3, 1, mixer6, 2);
AudioConnection patchCord7(playSdWav2, 0, mixer4, 1);
AudioConnection patchCord8(playSdWav2, 1, mixer6, 1);
AudioConnection patchCord9(playSdWav9, 0, mixer2, 0);
AudioConnection patchCord10(playSdWav9, 1, mixer8, 0);
AudioConnection patchCord11(playSdWav8, 0, mixer3, 3);
AudioConnection patchCord12(playSdWav8, 1, mixer7, 3);
AudioConnection patchCord13(playSdWav15, 0, mixer1, 2);
AudioConnection patchCord14(playSdWav15, 1, mixer9, 2);
AudioConnection patchCord15(playSdWav6, 0, mixer3, 1);
AudioConnection patchCord16(playSdWav6, 1, mixer7, 1);
AudioConnection patchCord17(playSdWav5, 0, mixer3, 0);
AudioConnection patchCord18(playSdWav5, 1, mixer7, 0);
AudioConnection patchCord19(playSdWav7, 0, mixer3, 2);
AudioConnection patchCord20(playSdWav7, 1, mixer7, 2);
AudioConnection patchCord21(playSdWav14, 0, mixer1, 1);
AudioConnection patchCord22(playSdWav14, 1, mixer9, 1);
AudioConnection patchCord23(playSdWav16, 0, mixer1, 3);
AudioConnection patchCord24(playSdWav16, 1, mixer9, 3);
AudioConnection patchCord25(playSdWav11, 0, mixer2, 2);
AudioConnection patchCord26(playSdWav11, 1, mixer8, 2);
AudioConnection patchCord27(playSdWav12, 0, mixer2, 3);
AudioConnection patchCord28(playSdWav12, 1, mixer8, 3);
AudioConnection patchCord29(playSdWav13, 0, mixer1, 0);
AudioConnection patchCord30(playSdWav13, 1, mixer9, 0);
AudioConnection patchCord31(playSdWav10, 0, mixer2, 1);
AudioConnection patchCord32(playSdWav10, 1, mixer8, 1);
AudioConnection patchCord33(mixer7, 0, mixer10, 1);
AudioConnection patchCord34(mixer3, 0, mixer5, 1);
AudioConnection patchCord35(mixer4, 0, mixer5, 0);
AudioConnection patchCord36(mixer6, 0, mixer10, 0);
AudioConnection patchCord37(mixer8, 0, mixer10, 2);
AudioConnection patchCord38(mixer2, 0, mixer5, 2);
AudioConnection patchCord39(mixer9, 0, mixer10, 3);
AudioConnection patchCord40(mixer1, 0, mixer5, 3);
AudioConnection patchCord41(mixer5, 0, i2s1, 0);
AudioConnection patchCord42(mixer10, 0, i2s1, 1);
//PINS
#define SDCARD_CS_PIN 10
#define SDCARD_MOSI_PIN 7
#define SDCARD_SCK_PIN 13
#define e1r 14
#define e1g 15
#define e1sw 3
//VARS
char filechar[13] = "BANK02/00.WAV";
char *MENU [] = {"Channel","Mode","Bank","Save & Exit"};
int globalsettings[]={10,1,2,0};//channel,mode,bank,smth
float slotvol[]={0.75,0.75,0.75,0.75,0.75,0.75,0.75,0.75,0.75,0.75,0.75,0.75,0.75,0.75,0.75,0.75,};
byte slot[16]={0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15};
long oldPosition = 999;
long newPosition = 666;
byte i=0;
bool e1press=false;
pinMode(e1r,OUTPUT);
pinMode(e1g,OUTPUT);
pinMode(e1sw,INPUT_PULLUP);
lcd.init(); // initialize the lcd
lcd.backlight();
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("Press and hold");
lcd.setCursor(0, 1);
lcd.print("for settings");
//delay(500);
Serial.begin(57600);
MIDI.begin(MIDI_CHANNEL_OMNI);
AudioMemory(32);
sgtl5000_1.enable();
sgtl5000_1.volume(0.5);
SPI.setMOSI(SDCARD_MOSI_PIN);
SPI.setSCK(SDCARD_SCK_PIN);
if (!(SD.begin(SDCARD_CS_PIN)))
while (1)
lcd.clear();
lcd.print("SD FAIL");
lcd.clear();
if (digitalRead(e1sw)==LOW)
settings();
void settings()
while(true)
newPosition = myEnc.read()/2;
if (newPosition != oldPosition)
oldPosition = newPosition;
i = oldPosition;
if(i>=5)
i=0;
myEnc.write(0);
if(i==0||i==1)
lcd.clear();
lcd.setCursor(1, 0);
lcd.print(MENU[0]);
lcd.setCursor(14, 0);
lcd.print(globalsettings[0]);
lcd.setCursor(1, 1);
lcd.print(MENU[1]);
switch(globalsettings[1])
case 0:
lcd.setCursor(13, 1);
lcd.print("USB");
case 1:
lcd.setCursor(12, 0);
lcd.print("MIDI");
else if(i==2||i==3)
lcd.clear();
lcd.print(MENU[2]);
lcd.print(MENU[3]);
lcd.setCursor(0, i%2 );
lcd.write(0x7E);//arrow char
if(MIDI.read())
byte type = MIDI.getType();//type
if(type==0x90)
case 0:
usbmidi();
case 1:
dinmidi();
i = oldPosition;
if(i>=16)
i=0;
myEnc.write(0);
if(i<0)
i=15;
myEnc.write(i*2);
lcd.clear();
lcd.print("Slot ");
lcd.write(0x7E);
lcd.print(i);
lcd.print(" ");
lcd.print("Spl ");
lcd.print(slot[i]);
if (digitalRead(e1sw)==LOW&&e1press==false)
e1press=true;
digitalWrite(e1r , HIGH);
lcd.setCursor(0, 5);
lcd.print(" ");
slotMenuSelect(i);
lcd.print(" ");
myEnc.write(i*2);
delay(200);
e1press=false;
//digitalWrite(e1r , LOW);
//digitalWrite(e1g , LOW);
void slotMenuSelect(byte slot_number)
byte n;
lcd.write(0x7E);
lcd.print("Sample ");
myEnc.write(0);
while(digitalRead(e1sw)==LOW&&e1press==true)
delay(200);
//wait for depress
e1press=false;
while(true)
n = oldPosition;
if(n>=6)
n=0;
myEnc.write(0);
if(n<0)
n=5;
myEnc.write(5*2);
switch(n)
case 0:
lcd.write(0x7E);
case 1:
lcd.write(0x7E);
lcd.print("Vol ");
case 2:
lcd.write(0x7E);
lcd.print("Start ");
case 3:
lcd.write(0x7E);
lcd.print("End ");
case 4:
lcd.write(0x7E);
lcd.print("Rev ");
case 5:
lcd.print("Back ");
e1press=true;
switch(n)
case 0:
slotSampleSelect(slot_number);
lcd.write(0x7E);
delay(200);
case 1:
//slotSampleSelect();
lcd.write(0x7E);
lcd.print("WIP_Back ");
case 2:
lcd.write(0x7E);
case 3:
lcd.write(0x7E);
case 4:
lcd.write(0x7E);
case 5:
return 0;
if (digitalRead(e1sw)==HIGH)
e1press=false;
void slotSampleSelect(const byte slot_number)
byte n=0;
myEnc.write(0);
lcd.write(0x7E);
lcd.setCursor(8, 1);
lcd.print(slot[slot_number]);
//wait for depress
delay(200);
e1press=false;
while (true)
if(myEnc.read()<0)
myEnc.write(99*2);
n = oldPosition;
Serial.print(n);
if(n>99)
n=0;
myEnc.write(0);
lcd.print(n);
lcd.print(" ");
playPlayer(n,slot_number);
if(digitalRead(e1sw)==LOW&&e1press==false)
slot[slot_number]=n;
lcd.setCursor(12,0);
lcd.print(n);
lcd.print(" ");
return 0;
void usbmidi()
Serial.println(usbMIDI.getChannel());
Serial.println(usbMIDI.getType(),HEX);
Serial.print(usbMIDI.getData1(),HEX);
Serial.print(" HEX| ");
Serial.print(usbMIDI.getData1(),DEC);
Serial.print(" DEC| ");
Serial.print(usbMIDI.getData2(),HEX);
Serial.print(usbMIDI.getData2(),DEC);
byte type = usbMIDI.getType();
byte data1 = usbMIDI.getData1();
byte data2 = usbMIDI.getData2();
if(usbMIDI.getType()==0x90&&usbMIDI.getData1()==0x24)
playPlayer(slot[0],0);
if(usbMIDI.getType()==0x90&&usbMIDI.getData1()==0x25)
playPlayer(slot[1],1);
if(usbMIDI.getType()==0x90&&usbMIDI.getData1()==0x26)
//playFile(slot[2],2);
if(usbMIDI.getType()==0x90&&usbMIDI.getData1()==0x27)
//playFile(slot[3],3);
if(usbMIDI.getType()==0x90&&usbMIDI.getData1()==0x28)
//playFile(slot[4],4);
if(usbMIDI.getType()==0x90&&usbMIDI.getData1()==0x29)
//playFile(slot[5],5);
if(usbMIDI.getType()==0x90&&usbMIDI.getData1()==0x2A)
//playFile(slot[6],6);
if(usbMIDI.getType()==0x90&&usbMIDI.getData1()==0x2B)
//playFile(slot[7],7);
if(usbMIDI.getType()==0x90&&usbMIDI.getData1()==0x2C)
//playFile(slot[8],8);
if(usbMIDI.getType()==0x90&&usbMIDI.getData1()==0x2D)
//playFile(slot[9],9);
if(usbMIDI.getType()==0x90&&usbMIDI.getData1()==0x2E)
//playFile(slot[10],10);
if(usbMIDI.getType()==0x90&&usbMIDI.getData1()==0x2F)
//playFile(slot[11],11);
if(usbMIDI.getType()==0x90&&usbMIDI.getData1()==0x30)
//playFile(slot[12],12);
if(usbMIDI.getType()==0x90&&usbMIDI.getData1()==0x31)
//playFile(slot[13],13);
if(usbMIDI.getType()==0x90&&usbMIDI.getData1()==0x32)
//playFile(slot[14],14);
if(usbMIDI.getType()==0x90&&usbMIDI.getData1()==0x33)
// playFile(slot[15],15);
void playPlayer(const byte sample_num, const byte player_num)
byte x = (sample_num/10)%10;
byte y = (sample_num)%10;
filechar[7]='0'+x;
filechar[8]='0'+y;
//Serial.println(filechar);
switch(player_num)
case 0:
//playWav1.stop();
playSdWav1.play(filechar);
case 1:
//playWav2.stop();
playSdWav2.play(filechar);
case 2:
//playWav3.stop();
playSdWav3.play(filechar);
case 3:
//playWav4.stop();
playSdWav4.play(filechar);
case 4:
//playWav5.stop();
playSdWav5.play(filechar);
case 5:
//playWav6.stop();
playSdWav6.play(filechar);
case 6:
//playWav7.stop();
playSdWav7.play(filechar);
case 7:
//playWav8.stop();
playSdWav8.play(filechar);
case 8:
//playWav9.stop();
playSdWav9.play(filechar);
case 9:
//playWav10.stop();
playSdWav10.play(filechar);
case 10:
//playWav11.stop();
playSdWav11.play(filechar);
case 11:
//playWav12.stop();
playSdWav12.play(filechar);
case 12:
//playWav13.stop();
playSdWav13.play(filechar);
case 13:
//playWav14.stop();
playSdWav14.play(filechar);
case 14:
//playWav15.stop();
playSdWav15.play(filechar);
case 15:
//playWav16.stop();
playSdWav16.play(filechar);
void dinmidi()
Serial.println(MIDI.getChannel());
Serial.println(MIDI.getType(),HEX);
Serial.print(MIDI.getData1(),HEX);
Serial.print(MIDI.getData1(),DEC);
Serial.print(MIDI.getData2(),HEX);
Serial.print(MIDI.getData2(),DEC);
// if(type==0x90)
byte data1 = MIDI.getData1();//note
byte data2 = MIDI.getData2();//velo
switch(data1)
case 0x24:
case 0x25:
case 0x26:
playPlayer(slot[2],2);
case 0x27:
playPlayer(slot[3],3);
case 0x28:
playPlayer(slot[4],4);
case 0x29:
playPlayer(slot[5],5);
case 0x2A:
playPlayer(slot[6],6);
case 0x2B:
playPlayer(slot[7],7);
case 0x2C:
playPlayer(slot[8],8);
case 0x2D:
playPlayer(slot[9],9);
case 0x2E:
playPlayer(slot[10],10);
case 0x2F:
playPlayer(slot[11],11);
case 0x30:
playPlayer(slot[12],12);
case 0x31:
playPlayer(slot[13],13);
case 0x32:
playPlayer(slot[14],14);
case 0x33:
playPlayer(slot[15],15);
