Page 2 of 2 FirstFirst 1 2
Results 26 to 35 of 35
Thread: USB Audio samplerates added
  1. #26
    Germany
    9,349
    Perhaps try the program in the attachment. Select the teensy, scroll the list on the right down. There should be the number 48000 somewhere...
    If not, something is wrong with the code on the teensy..
    IF there is 48000, shutdown the pc, use different USB-Port and start again (I hope this helps) - Control panel should now show 48kHz
    Attached Files Attached Files
  2. #27
    Senior Member PaulS's Avatar
    Apr 2015
    Netherlands
    665
    Even if I uninstall both Teeny audio devices, disconnect & connect the T4.0 and then let Windows search and find both Teensy devices again, the Sound Control Panel shows 44100 Hz.
    Paul
  3. #28
    Germany
    9,349
    Hm.. ok I look again this evening. Maybe I forgot a file?
  4. #29
    Apr 2015
    Netherlands
    665
    Weird, this is what USBtreeview shows on my PC [2 identical entries]:
            ------- Audio Streaming Format Type Descriptor --------
    bLength                  : 0x0B (11 bytes)
    bDescriptorType          : 0x24 (Audio Interface Descriptor)
    bDescriptorSubtype       : 0x02 (Format Type)
    bFormatType              : 0x01 (FORMAT_TYPE_I)
    bNrChannels              : 0x02 (2 channels)
    bSubframeSize            : 0x02 (2 bytes per subframe)
    bBitResolution           : 0x10 (16 bits per sample)
    bSamFreqType             : 0x01 (supports 1 sample frequence)
    tSamFreq[1]              : 0x0AC44 (44100 Hz)
    Data (HexDump)           : 0B 24 02 01 02 02 10 01 44 AC 00                  .$......D..
    Paul
  5. #30
    Germany
    9,349
    Ok. Seems to be my fault and I forgot a changed file. I'll look later.
    Ehh... it is a 4.x, right? :-)
  6. #31
    Apr 2015
    Netherlands
    665
    Yes, it's a Teensy 4.0.
    Just for sanity, I closed the Arduino environment completely and started it up again.
    Then recompiled and uploaded the same sketch and now USBtreeview shows:
    tSamFreq[1]              : 0x0BB80 (48000 Hz)
    Data (HexDump)           : 0B 24 02 01 02 02 10 01 80 BB 00                  .$.........
    48 kHz! Strange...
    And the Sound Control Panel shows 48 kHz as well:
    But no sine wave is outputted this time...
    Paul
  7. #32
    Germany
    9,349
    Perhaps your sine program doesn't like the Teensy? I have no other Idea.
    Ok, I took your program, and the thing I modified was to use the PT8211 instead.
    I use WInAmp to play a radio stream. Sounds good.
    This is how it looks like in Windows. Accidentially, it uses still the 88.2 KHz which I had choosen to test the WavePlayer.
Name:	2021-07-31 18_24_33-Eigenschaften von Digitale Audioschnittstelle.png
ID:	25453Click image for larger version.
Name:	2021-07-31 18_24_51-Eigenschaften von Digitale Audioschnittstelle.png
ID:	25454Click image for larger version.
Name:	2021-07-31 18_25_12-Eigenschaften von Digitale Audioschnittstelle.png
ID:	25455Click image for larger version.
Name:	2021-07-31 18_25_27-Eigenschaften von Digitale Audioschnittstelle.png
  8. #33
    Apr 2015
    Netherlands
    665
    Yeah, could be. Although in the Sound Control Panel [which has less tabs then before - Advanced and Spatial Sound are missing] the Test button has been greyed out... I set the sample rate to be 88200 Hz as well.
    So I installed Audacity and generated a 1kHz tone at 88200 Hz. When I tried to play this 30sec audioclip, Audacity bails out with this error:
    Not sure what to do next... Did you mention that you forgot to include a changed file?
    Paul
  9. #34
    Germany
    9,349
    I don't know.
    Attached my current local Teensy4 directory.
    If that still does not work (make sure to make a "clean" build)... then I don't know what's going on.
  10. #35
    Apr 2015
    Netherlands
    665
    Thanks for the zip file.
    Did a clean Teensyduino 1.54 re-install. Then copied all the files from your zip file over to the teensy4 directory.
    Opened the Arduino IDE, compiled and ran the sketch.
    Result is exactly the same as in my previous message #33. Schade.
    Not sure what is going on - my guess is that Windows 10 is just very picky here? For example, it shows less tabs at the 88200 kHz setting.
ID:	25463 Click image for larger version.
    I think I'm going to stop here...but thanks for your efforts!
    Paul
