Page 2 of 2 FirstFirst 1 2
Results 26 to 30 of 30
Thread: Simultaneously reading 8 GPIO pins
  1. #26
    May 2015
    USA
    1,075
    And for people who think that pointers are needed to speed things up, this takes the same time. And IMO, is clearer and less prone to errors like above.
    for (unsigned i = 0; i < BUFFER_SIZE; ++i)
            buffer[i] = GPIO6_PSR;
  2. #27
    There seems to be some discrepancy using the ARM_DWT_CYCCNT command to record the number of cycles per instruction (CPI). Running:
    const byte InterruptPin = 1;
    void setup(){
      pinMode(InterruptPin, INPUT);
      attachInterrupt(digitalPinToInterrupt(InterruptPin), CPI_Time, RISING);
    void CPI_Time(){
      int clk_1 = ARM_DWT_CYCCNT;
      asm(
      "nop \n\t"
      "nop \n\t"
      "nop \n\t"
      "nop \n\t"
      "nop"
      int clk_2 = ARM_DWT_CYCCNT;
      Serial.printf("CPI: %d \n", clk_2-clk_1);
    Only prints out:
    CPI: 3
    CPI: 3
    CPI: 3
    CPI: 3
    CPI: 3
    clearly, there are 5 no operation (nop) commands, each using a single CPI, so the output should be 5, no?
  3. #28
    29
    The Cortex-M7 is superscalar, i.e. it can process more than one instruction per clock cycle.
    I think that can explain it - see https://en.wikipedia.org/wiki/ARM_Cortex-M#Cortex-M7
    See also https://www.nxp.com/docs/en/white-paper/CORTEXM7WP.pdf:
    "High-performance, 6-stage pipeline with dual-instruction issue, enabling it to execute up to two instructions per clock cycle"
  4. #29
    :O you are a genius, yep that appears to be what is happening, it's running 2 instructions at once. Thank you for the info!
    Also, I tried the code from #26 and printed the buffer out after to see what it was capturing, and I am getting a random number on the output for example:
    53792780.
    I know I will need to use IOMUX somehow, to tell port 6 to be GPIO, and I want to use pins:
    17, 16, 22, 23, 20, 21, 26, 27 in that order to get the 8 bits out of GPIO6 since the bits are all pretty close to each other and can be addressed using 0xCFC00000 --> 0B11001111110000000000000000000000
    Any help on how to read and store those specific pins on an interrupt call would be really appreciated. Additionally, I am guessing the two MSB bits will need to be shifted to the right two places somehow to get the 8 bits all together.
  5. #30
    Jul 2015
    118
    Quote Originally Posted by RandoRkt View Post
    To set the pins as GPIO Inputs:
      pinMode(16,  INPUT);
      pinMode(17,  INPUT);
      pinMode(20,  INPUT);
      pinMode(21,  INPUT);
      pinMode(22,  INPUT);
      pinMode(23,  INPUT);
      pinMode(26,  INPUT);
      pinMode(27,  INPUT);
    I want to use pins:
    Here's how to move those bits down to the lower 8 bits:
        uint32_t sample = GPIO6_PSR;
        // shift bits 22-27 to bits 0-5
        buffer[i] = (sample & 0x0FC00000) >> 22;
        // shift bits 30-31 to bits 6-7
        buffer[i] = buffer[i] | (sample & 0xC0000000) >> 24;
