If you're asking about the DCS-Bios for Arduino, I've downloaded and had a look at it. Some of the code in DcsBios.h refers directly to Arduino hardware registers which is why it won't compile for a Teensy. If you can modify this code to work with Teensy, it will compile. It 'only' involves receive and transmit of serial characters and the ISR for receive serial interrupt.
thanks for confirming that. I was looking and the USB-HI stuff, it also did not work. can you recommend a sketch that would work for the Teensy for use as a rudder input?
thanks,
Philip
