Results 1 to 2 of 2
Thread: USB C PCB routing advice
    Hi everyone,
    I'm planning to use this connector for a project with the Teensy4: https://www.mouser.sg/ProductDetail/...Rfehpd11NNIg==
    I have some questions on routing the PCB trace on both the A and B side. I have first routed it to the A side and made sure that the trace lengths are the same. But how should I go about routing it to the B side so that the USB C connector can be flipped? It's not possible to do a trace between the pins. If I do it like below, then would there be the adverse effect of having different trace lengths for the high speed signals?
    Is there a better way to route the signal?
    The D+ and D- traces are in purple/pink
Name:	Screen Shot 2021-07-21 at 12.41.47 PM.jpg
    May 2015
    USA
    1,005
    Don't do the short connection between A6 and B6 - go around the left side to get to B6.
