Results 1 to 11 of 11
Thread: AudioProcessorUsage on higher samplingrates
    Senior Member CorBee's Avatar
    Jun 2018
    Netherlands
    498
    Hi
    As we are developing the TeensyBat (https://forum.pjrc.com/threads/38988...etector/page36) with further enhancements I would like to keep track of
    the AudioprocessorUsage(). This is directly available from the Audiostream library see https://www.pjrc.com/teensy/td_libs_...ssorUsage.html
    I have tested this on a T36 and got readouts that are at 0.5 whilst the above html states :
    Returns an estimate of the total CPU time used during the most recent audio library update. The number is an integer from 0 to 100, representing an estimate of the percentage of the total CPU time consumed.
    The library declares this also as a float so 0.5 could for instance mean 50% of 0-1 but ...
    The odd thing is that when I test alike code on a T41 the same setup gives values around 3.2 ...
    I have seen (@FrankB) some people mentioning that this calculation is dependent also on the samplerates. As we are using a lot higher samplerates than the defaults (we go up to 384k without problems) I was wondering how I can calculate a reliable estimate.
    kind regards
    Cor
    24,782
    The range is 0 to 100.
    A code change to the definition of AUDIO_SAMPLE_RATE (making it a float) ends up promoting the entire calculation to float on all boards except Teensy LC.
    Maybe you're hitting a numerical precision issue?
    Find these 4 lines in AudioStream.h and change them to uint32_t.
            uint16_t cpu_cycles;
            uint16_t cpu_cycles_max;
            static uint16_t cpu_cycles_total;
            static uint16_t cpu_cycles_total_max;
    Then edit AudioStream.cpp. File this lines and remove the right shift by 4 bits. (I believe it's 6 bits on Teensy 4.x because much higher clock speeds are possible)
                            cycles = (ARM_DWT_CYCCNT - cycles) >> 4;
            totalcycles = (ARM_DWT_CYCCNT - totalcycles) >> 4;
    This will keep all the numerical precision of the cycle counter.
    Then back in AudioStream.h, edit CYCLE_COUNTER_APPROX_PERCENT()
    #define CYCLE_COUNTER_APPROX_PERCENT(n) (((n) + (F_CPU / 32 / AUDIO_SAMPLE_RATE * AUDIO_BLOCK_SAMPLES / 100)) / (F_CPU / 16 / AUDIO_SAMPLE_RATE * AUDIO_BLOCK_SAMPLES / 100))
    Change 16 to 1, and 32 to 2, since you're now collecting the full cycle count.
    Germany
    9,056
    On T4.x the sample rate is float.
    Not sure when and why this happened, or if it was intended - but it is no problem. You just need to know it.
    Jun 2018
    Netherlands
    498
    Hi Paul,
    Ill try that now, will report here.
    cheers
    Cor
    Jun 2018
    Netherlands
    498
    Had to change this in the Audiostream.cpp
    uint32_t AudioStream::cpu_cycles_total = 0;
    uint32_t AudioStream::cpu_cycles_total_max = 0;
    After this the code runs fine on a T4.1 and reports 0.6-0.7, changing regularly. On the T3.6 I simply get a readout of 0.5 which is also constant, the reporting is all
    using the same code so it must be in the readout of AudioProcessorUsage().
    Should I now see this as 0.6 in the range 0-100 or 0.6 in the range 0.0 -1.0 ... is the processor nearly sleeping or working hard ?
    I am using a single adapted audioStream library setup for both T3.6 and T4.1 (I cloned this from the core for T4) to allow for instance the usage of
    PSRAM for really large audio-buffers (up to 10 seconds at 281k has allready been tested and works fine).
    //audio in PSRAM for T41
    #if defined(__IMXRT1062__)
    #ifdef PSRAM
    #define AudioMemory(num) ({ \
    	static EXTMEM audio_block_t data[num]; \
    	AudioStream::initialize_memory(data, num); \
    #else
    	static DMAMEM audio_block_t data[num]; \
    (@PAUL)
    I was wondering if any of the codechanges you proposed are also valid for the T3.6 or not. For instance I have left this part for the T3.6 intact (see below) and added a T41 section.
     #if defined(__MK66FX1M0__)
    			   cycles = (ARM_DWT_CYCCNT - cycles) >> 6;
    The setup for the CYCLE_COUNTER_APPROX_PERCENT
    //OLD #define CYCLE_COUNTER_APPROX_PERCENT(n) (((float)((uint32_t)(n) * 6400u) * (float)(AUDIO_SAMPLE_RATE_EXACT / AUDIO_BLOCK_SAMPLES)) / (float)(F_CPU_ACTUAL))
    #define CYCLE_COUNTER_APPROX_PERCENT(n) (((n) + (F_CPU / 2 / AUDIO_SAMPLE_RATE * AUDIO_BLOCK_SAMPLES / 100)) / (F_CPU / 1 / AUDIO_SAMPLE_RATE * AUDIO_BLOCK_SAMPLES / 100))
    #if defined(KINETISK)
    #elif defined(KINETISL)
    #define CYCLE_COUNTER_APPROX_PERCENT(n) ((n) * (int)(AUDIO_SAMPLE_RATE) + (int)(AUDIO_SAMPLE_RATE/2)) / (AUDIO_BLOCK_SAMPLES * 10000)
    Thanks for helping me out,
    regards
    Cor
    Germany
    9,056
    I wonder if it would be better to use F_CPU_ACTUAL for the T4. However, this is not a constant...
    However, there is probably no way around it. After all, you want correct results.
    Jun 2018
    Netherlands
    498
    The only thing I find important is that the numbers the CYCLE_COUNTER_APPROX_PERCENT delivers do give a good idea of the relative processor-time needed to process a single incoming audio_block of data (as that what I think it does).
    Jun 2018
    Netherlands
    498
    Seems I wasnt reading @PAUL carefully, he stated to remove the >>4:
    Ive just done that and I see on the T4.1 a 2.3/2.4 % usage. Thats usefull information, on the T3.6 I am still getting only 0.5 so something must be wrong still in my setup.
    Cor
    Jun 2018
    Netherlands
    498
    It seems that I am not getting a proper readout for ARM_DWT_CYCCNT on the T3.6. Will check which register this should be.
    Jun 2018
    Netherlands
    498
    Checked my code using VisualCode and the reference for ARM_DWT_CYCCNT is
    going to :
    #define ARM_DWT_CYCCNT (*(volatile uint32_t *)0xE0001004) // Cycle count register
    So nothing odd at that point. But this register never seems to show a value larger than 0, as if the cyclecounter never got started ?
    EDIT: this part in sofware_isr is also present and active ...
    	ARM_DEMCR |= ARM_DEMCR_TRCENA;
    	ARM_DWT_CTRL |= ARM_DWT_CTRL_CYCCNTENA;
    	uint32_t totalcycles = ARM_DWT_CYCCNT;
    	uint32_t totalcycles = micros();
    Jun 2018
    Netherlands
    498
    It seems the compiler was not picking up things as I had hoped, but I now have proper readouts for T3.6 and T4.1. On the T3.6 I see that the current TeensyBat uses 10% of the available time to process audioblocks and on the T4.1 this is 2.3%. Both processors thus do not have a very "heavy" task at hand.
    Thanks !
