Results 1 to 12 of 12
Thread: Issues with Teensy 4.1
    Jul 2021
    5
    We have been using the Teensy 4.1 for quiet some time now and we without any intervention they seem to stop working. We connected it via USB to our computer and after a while it stops working.
    We have repeatedly been facing this issue with multiple devices. Kindly let us know what we are doing wrong and how we can revive these devices if possible.
    1,721
    There is no way to know. You haven't posted any code and you haven't even said what it is supposed to do, nor what "stops working" actually means.
    You should reduce your code to the smallest amount which demonstrates the problem. While doing this the problem sometimes becomes obvious but if not, post your code here so that the problem can be replicated by other users.
    Pete
    Senior Member ETMoody3's Avatar
    Mar 2014
    New Ulm, Mn
    176
    This might also be an issue with USB power management on the hosting computer, but without more information the only thing anyone can do is randomly guess.
    Jul 2021
    5
    The Teensy 4.1 was getting power and communicating via USB to Jetson Nano Dev Kit. It was working fine for a couple of days. Teensy was working normally for a couple of days, now it doesn't power up(LEDs don't light up, not detected as a USB device).
    The ICs close to the micro-USB port heat up, and the 3v3 pin and GND pins are short. I read up a few other threads similar to this issue.
    It is quite apparent that this Teensy is dead.
    Are there any ways to safeguard Teensy 4.1 externally when powering via USB?
    Mar 2014
    New Ulm, Mn
    176
    I seriously doubt the Jetson over powered the usb system if it still works.
    You haven't told us what, if any, other things are attached to the Teensy that might have failed and shorted out the 3.3v supply.
    Jul 2021
    5
    There were a couple of encoders and two Pro Minis were connected to it. The pro minis were communicating via UART. The encoders were triggering interrupts on Teensy.
    Mar 2014
    New Ulm, Mn
    176
    But to answer your question yes there are ways to electrically isolate usb devices from the host computer that provide power via an external source. Again, the Jetson is a 5 volt system - I have one - and it seems highly unlikely it was a source of lethal voltage.
    Search for "ADUM3160 usb isolator device" and you will find many choices.
    Mar 2014
    New Ulm, Mn
    176
    If those pro minis were 5 volt... they would have introduced 5 volts directly to the Teensy pins.
    Jul 2021
    5
    The pro minis are the 3.3v version.
    This makes me wonder because the encoders are powered with 5v but they've been working fine with the teensy for quite some time for me.
    Is it possible that 5v intolerance won't damage the teensy right away, and it happens over time? I've been using these encoders for quite some time.
    Mar 2014
    New Ulm, Mn
    176
    The encoders might well have been the source of trouble.
    As for them not damaging it right away... that doesn't seem intuitive.
    At this point, I'll draw back and see if anyone else has any input in that regard.
    However out of curiosity I'm going to set up a common encoder with 5v and see what I get on an oscilloscope. Not all encoders are the same.
    Jul 2021
    5
    Yeah as for the encoders not damaging it right away, it is counter-intuitive.
    Thanks for your help
    Mar 2014
    New Ulm, Mn
    176
ID:	25330Click image for larger version.
    Well, this is a highly available and common encoder breakout. It may not be what you are using. Some encoders I use only attach to the data pins and ground. This one asks for a supply, ground, and then gives data pins. I use these with 3.3 v on a lot of projects.
    Powered with 5 volts, encoder movements give a very fast 5 volt spike. Hopefully the attached (cheapo) oscilloscope picture is informative.
