Results 1 to 7 of 7
Thread: I2s input limitation 16 bits 44100 ?
    Jul 2021
    3
    Hello
    Can the audio lib get from I2S in 24 bits 192 khz?
    with an external ADC planned for that.
    I read that it was limited to 16 bit 44100,
    if so what teensy card
    thank you
    3,317
    Quote Originally Posted by artouste View Post
    Hello
    thank you
    The audio library is designed for 16bot 44.1 kHz, but you can change. There is lot of evidence on this forum.
    9,255
    44.1/16 bit is CD quality.... not sure if 192/24 makes much sense...
    Jul 2021
    3
    Thank you for your quick response
    I will browse the forum a bit more.
    If you have 1 or 2 links that speak of that that would be great
    Jul 2020
    1,219
    Hello
    The official library is 16 bit throughout, though some people are working on branches that extend to higher bitdepth -
    have a search around, theres a few active threads on these IIRC.
    thank you
    The default sample rate is 44100Hz, but you can change this with one line I believe. On a fast Teensy its
    not a problem to run lots faster. The bat-detector thread has details of a project using high sample rates for
    ultrasound for instance.
    The library is optimized for 32-bit processors without floating point support so it'll work on any ARM-based
    Teensy. Its interrupt driven and many I/O objects use DMA for best performance.
    Jul 2021
    3
    Thank you
    this is exactly what i need
    I will read (mora mora) 36 pages of the topic
    Senior Member CorBee's Avatar
    Jun 2018
    Netherlands
    507
    The code I am using for the TeensyBat on a Teensy4.1 can be found overhere:
    https://forum.pjrc.com/threads/65225...%2C+true%29%3B
    for a Teenst 3.6 our code is based on:
    https://github.com/FrankBoesing/AudioTiming/
