fileSystem: In function 'void saveConfigToSD()':
fileSystem:1135: error: 'File' was not declared in this scope
File sdfile; // File object
fileSystem:1138: error: 'sdfile' was not declared in this scope
sdfile = SD.open( fname, FILE_WRITE );
fileSystem: In function 'void saveChannelToSd(uint8_t)':
fileSystem:1151: error: 'File' was not declared in this scope
fileSystem:1154: error: 'sdfile' was not declared in this scope
fileSystem: In function 'void saveGenerativeToSD(int)':
fileSystem:1166: error: 'File' was not declared in this scope
fileSystem:1169: error: 'sdfile' was not declared in this scope
fileSystem: In function 'void saveAsciiPatternToSd(uint8_t)':
fileSystem:1181: error: 'File' was not declared in this scope
fileSystem:1184: error: 'sdfile' was not declared in this scope
fileSystem: In function 'void saveEuclideanToSd(uint8_t)':
fileSystem:1196: error: 'File' was not declared in this scope
fileSystem:1199: error: 'sdfile' was not declared in this scope
fileSystem: In function 'void saveVennEuclideanColliderToSd(uint8_t)':
fileSystem:1211: error: 'File' was not declared in this scope
fileSystem:1214: error: 'sdfile' was not declared in this scope
fileSystem: In function 'void savePlanetaryToSD(uint8_t)':
fileSystem:1231: error: 'File' was not declared in this scope
fileSystem:1234: error: 'sdfile' was not declared in this scope
fileSystem: In function 'void saveParticlesToSD(uint8_t)':
fileSystem:1246: error: 'File' was not declared in this scope
fileSystem:1249: error: 'sdfile' was not declared in this scope
fileSystem: In function 'void saveDrummerPatternSD(int)':
fileSystem:1278: error: 'File' was not declared in this scope
fileSystem:1286: error: 'sdfile' was not declared in this scope
fileSystem: In function 'void saveDrummerKitSD(int)':
fileSystem:1303: error: 'File' was not declared in this scope
fileSystem:1307: error: 'sdfile' was not declared in this scope
fileSystem: In function 'void save303PatternSD(int)':
fileSystem:1321: error: 'File' was not declared in this scope
fileSystem:1324: error: 'sdfile' was not declared in this scope
fileSystem: In function 'void saveTicTacToeSettingsToSd(uint8_t)':
fileSystem:1366: error: 'File' was not declared in this scope
fileSystem:1369: error: 'sdfile' was not declared in this scope
fileSystem: In function 'void saveTicTacToeGamesToSd(uint8_t)':
fileSystem:1381: error: 'File' was not declared in this scope
fileSystem:1384: error: 'sdfile' was not declared in this scope
fileSystem: In function 'void saveDrummerPatternSD_WORKINPROGRESS(int)':
fileSystem:1418: error: 'File' was not declared in this scope
fileSystem:1450: error: 'sdfile' was not declared in this scope
fileSystem: In function 'void sdOpenInitFile()':
fileSystem:1539: error: 'File' was not declared in this scope
fileSystem:1543: error: 'sdfile' was not declared in this scope
sdfile = SD.open( INIT_PATH, FILE_READ ); // try to open text.asq // ========== SD open file to read ====================================
fileSystem: In function 'void sdOpenConfigFile(int)':
fileSystem:1595: error: 'File' was not declared in this scope
fileSystem:1602: error: 'sdfile' was not declared in this scope
sdfile = SD.open( fname, FILE_READ ); // try to open text.asq // ========== SD open file to read ====================================
fileSystem: In function 'void sdOpen303File(int, int)':
fileSystem:1636: error: 'File' was not declared in this scope
fileSystem:1640: error: 'sdfile' was not declared in this scope
fileSystem: In function 'void sdOpenDrummerFile(int, int)':
fileSystem:1674: error: 'File' was not declared in this scope
fileSystem:1678: error: 'sdfile' was not declared in this scope
fileSystem: In function 'void sdOpenDrummerKitFile(int, int)':
fileSystem:1820: error: 'File' was not declared in this scope
fileSystem:1824: error: 'sdfile' was not declared in this scope
fileSystem: In function 'void writeNames(int)':
fileSystem:2032: error: 'File' was not declared in this scope
fileSystem:2036: error: 'sdfile' was not declared in this scope
fileSystem: In function 'void sdOpenFile(int, int)':
fileSystem:2048: error: 'File' was not declared in this scope
File sdfile;
fileSystem:2052: error: 'sdfile' was not declared in this scope
fileSystem: In function 'void writeInitFile()':
fileSystem:2091: error: 'File' was not declared in this scope
File sdfile;
fileSystem:2093: error: 'sdfile' was not declared in this scope
sdfile = SD.open( INIT_PATH, FILE_WRITE );
Multiple libraries were found for "SdFat.h"
Used: C:\Users\nick\OneDrive\Documents\Arduino\libraries\SdFat
Not used: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SdFat
