Results 1 to 8 of 8
Thread: Audio System Design Tool - tiny issue on search
    Member dimitre's Avatar
    Aug 2016
    São Paulo
    84
    I've just noticed the search box (bottom left) doesn't return exact results
    but I can find some effects there if I type without the first letter. for example "elay" shows "delay" but typing "delay" doesn't show anything.
    Jul 2020
    1,178
    This is because the matching is case sensitive and you didn't type "Delay" - not a great user experience...
    Line 152 in gui/red/ui/palette.js needs to be changed from
    	    var re = new RegExp(val,);
    to
    	    var re = new RegExp(val, "i");
    to get this behaviour. I can create a pull-request if this seems a desirable fix.
    24,776
    Yes, please do.
    Would also be good if the filter matched against the short names, if that's feasible?
    Please understand I'm currently working on flash encryption support, so not keeping up with all forum threads, emails, github issues this week. If I'm unresponsive, please give it a week or so and then ping me.
    Jul 2020
    1,178
    https://github.com/PaulStoffregen/Audio/pull/400
    Not sure about shortnames - it currently uses the id I think which has the Audio class name embedded in it, or similar.
    Aug 2016
    São Paulo
    84
    Thank you!
    Today I'm working with my custom audio object,
    in design tool I usually pick chorus, design everything and replace in code. but I have to replace back to chorus to be able to get back in the Audio design tool.
    It would be great to have a Custom effect in design tool, which links to a non existant object, like for example AudioEffectCustom
    So we could use the design tool back and forth only by adding this line to the code
    typedef AudioEffectCustom AudioEffectSlicer;
    Germany
    9,054
    How does it know the number of in- and outputs?
    Aug 2016
    São Paulo
    84
    Most effects I've seen are 1-1 so it will be already helpful to use 1-1 as default.
    And we can have other objects with Ins-Outs in the name like for example
    AudioEffectCustom
    AudioEffectCustom1-2
    AudioEffectCustom2-2
    AudioEffectCustom2-1
    Senior Member manicksan's Avatar
    Jun 2020
    Sweden
    294
    if you use the Audio Design Tool at
    https://manicken.github.io/
    there is both the possibility to create "project"-assigned custom objects
    (using my built in Node Def Manager)
    but for a simpler approach
    it also have a object called userObject in the special category
    which allow to define an object with custom number of inputs and outputs
    the subtype is the type of your custom AudioObject
    for example: AudioEffectCustom
    in my tool it searches for the shortname non case sensitive
    in my thread there is more information
    https://forum.pjrc.com/threads/65740...gn-Tool-update
