Results 1 to 6 of 6
Thread: Change the IP of Teensy 4.1 using UDP (again)
    Using an SPI with the teensy 3,2, I can change the IP relative easily from say 192.168.1.236 to .237 but when I do it with the 4.1, it does not respond to the new IP address.
    This code works for me with Teensy3.2 Any suggestions?. It's not a deal breaker but would be nice to get it to work.
    Thanks,
    Simon
    Udp.stop();
    Ethernet.begin(mac, new_ip);
    Udp.begin(localPort);
    PS: Asked before but no one responded.
    you are stopping udp but not ethernet, I don't know if you can actually change that live?
    In my project I do reboot teensy after applying any change, so it restarts fresh with all the new settings saved in memory.
    I don't know if that's a possible workaround for you. The command I use is CPU_RESTART;
    Thanks. I can actually write the ip to flash and re-start but I was hoping to be able to just change it without loosing other variables etc. It DOES work with the Teensy 3.2 and the WizIO over SPI so I was just wondering if anyone had an idea. It's not a deal breaker.
    Obviously I am using the native ethernet headers. Also seems to hang when you check if the cable is plugged in (if it isn't) but the 3.2 didn't. Again not a deal breaker just would like it to work.
    Maybe I should digging into the sources :-)
    Simon
    Quote Originally Posted by SimonWakley View Post
    Simon
    yes, the cable requirement is also a bug of the native library, there is a workaround but you have to change the library:
    https://github.com/vjmuzik/NativeEthernet/issues/12
    Mar 2017
    Oakland, CA, USA
    252
    You should be able to call Ethernet.setlocalIP() (https://www.arduino.cc/en/Reference/EthernetSetLocalIP)
    Note: Iíve got another library, QNEthernet, that doesnít block when thereís no cable attached. Itís based on lwIP, as an alternative.
    Cheltenham, UK
    365
    This is worth a read.
    Seems that IwIP was developed for use in embedded systems (sounds familiar).
    @shawn how does IwIP compare with uIP?
