Results 1 to 15 of 15
Thread: Modify register in SGTL5000
    Member DIYLAB's Avatar
    Jun 2020
    Germany
    64
    Teensy 4.0, Audiolib
    can someone please help me to set a register in SGTL5000?
    It is about the red marked register, there should be set "1".
    I would be grateful for a concrete example, because I am not an expert to inherit from the Audiolib or at all with bit manipulations.
    Thanks a lot!
    3,317
    modify "control_sgtl5000.h"
    to read
    	bool lineInLevel(uint8_t n) { return lineInLevel(n, n); }
    	bool lineInLevel(uint8_t left, uint8_t right) {return lineInLevel(left, right, 0);}
    	bool lineInLevel(uint8_t left, uint8_t right, uint8_t att);
    and "control_sgtl5000.cpp) to read
    bool AudioControlSGTL5000::lineInLevel(uint8_t left, uint8_t right, uint8_t att)
    	if (left > 15) left = 15;
    	if (right > 15) right = 15;
    	return write(CHIP_ANA_ADC_CTRL, (left << 4) | right | (att & 1) <<8);
    then you can use all three options
    sgtl5000.lineInLevel(level);
    sgtl5000.lineInLevel(left,right);
    sgtl5000.lineInLevel(left,right,att);
    please test and report
    Jun 2020
    Germany
    64
    Thank you very much, you are fast ;o)
    Is there also a way without changing the lib itself?
    I want to publish my project later and I don't know if everyone can or wants to change the lib.
    Kind regards
    Bruno
    3,317
    maybe the following could work
    in the sketch (.ino) file you add the following code
    (without changing the audio library)
    #include "control_sgtl5000.h"
    class mSGTL5000: public AudioControlSGTL5000
       public:
    	if (reg == CHIP_ANA_CTRL) ana_ctrl = val;
    	Wire.beginTransmission(i2c_addr);
    	Wire.write(reg >> 8);
    	Wire.write(reg);
    	Wire.write(val >> 8);
    	Wire.write(val);
    	if (Wire.endTransmission() == 0) return true;
    	return false;
    then instead of
    AudioControlSGTL5000 sgtl5000;
    or whatever you class declaration is
    you use
    mSGTL5000 sgtl5000;
    This gives you an additional call with optional 6dB attenuation
    Senior Member CorBee's Avatar
    Jun 2018
    Netherlands
    507
    I wonder if that code will work , as I liked the idea i have tested this on Teensybat, the code below works for me.
    #include "control_sgtl5000.cpp"
    class Bat_SGTL5000: public AudioControlSGTL5000
    {  uint16_t reg=CHIP_ANA_ADC_CTRL;
       public:
       void attGAIN(uint8_t att)
       {  uint16_t input_gain=AudioControlSGTL5000::read(reg);
           write(reg, (input_gain << 4) | input_gain | (att & 1) <<8);
    3,317
    Did you try with include file only? on Arduino?
    IMO, including the whole code is only necessary if the audio library is not compiled.
    If you include the implementation (.cpp) than you may get linker issues, when audio library is also compiled (as Arduino likes to do it)
    Anyhow, I have no audioboard with me, so I cannot test right now.
    Jun 2018
    Netherlands
    507
    I am not on arduino ... so that might make the difference. Ive justed tested this in the bat-detector code and it seems to work as planned.
    Jun 2018
    Netherlands
    507
    And using only the include the compiler (platformio ) was complaining about CHIP_ANA_ADC_CTRL as that is decllared in the .cpp
    3,317
    Quote Originally Posted by CorBee View Post
    OK, I see, the symbols are only defined in the cpp file.
    so better solution would be
    #define CHIP_ANA_ADC_CTRL		0x0020
       public:
    somehow I got earlier (post #4) the wrong cut and past (too late to be edited there)
    Jun 2018
    Netherlands
    507
    That should also work, in my case I opted to read the current gain settings and simply switch the bit on/off.
    EDIT: Tested and that works fine.
    3,317
    In your case, there is a modify pre-programmed in the base class that does what you did.
    Jun 2018
    Netherlands
    507
    I am not aware of any option in the audio lib to change that specific bit for CHIP_ANA_ADC_CTRL. We for instance have micGain but that always sets this ATT bit to 0 again. The same for lineinlevel.
    cheers
    Cor
    3,317
    what I mean is that you could replace
    by
         void attGAIN(uint8_t att) {  modify(reg,  (att & 1) <<8, 1<<8); }
    at least that what I guess!
    Jun 2018
    Netherlands
    507
    I had forgotten all about that modify command, thanks for suggesting that !
    Jun 2020
    Germany
    64
    Thank you both, works fine!
    class mSGTL5000 : public AudioControlSGTL5000 {
    public:
        void attGAIN(uint8_t att) { modify(0x0020, (att & 1) << 8, 1 << 8); }
    Kind regards
    Bruno
