Results 1 to 5 of 5
Thread: Ethernet without RJ45 jack?
    29
    Would it be possible to connect a Teensy 4 to an Ethernet switch without the intermediate RJ45 jack + magnetics? I'm considering connecting a couple of them (each to its own switch port of course), and I would think that for 10..30 cm of cabling + magnetics on the switch side, perhaps the extra "stuff" could be avoided?
    Another way to ask is: could a Teensy 4 be wired up directly to a cable with an RJ45 plug on the end?
    Jul 2020
    1,458
    It wouldn't be ethernet compliant of course, but I suspect for short cable runs you could get away with it, until someone plugs the cable into a PoE sender that is.
    29
    True, but that (and DC unbalance) could perhaps be solved with 0.1 F caps in series.
    There have been experiments with this approach, e.g. http://www.youritronics.com/magnetic-less-ethernet/.
    It would allow plugging a Teensy 4 into a spare Ethernet jack (plus power from USB).
    29
    May 2015
    USA
    1,094
