Results 1 to 10 of 10
Thread: PlatformIO not entering programming mode reliably
    Sorry if this is more a question for PlatformIO but I've gotta start somewhere.
    I've been successfully programing for a while with no touch of my custom Teensy 3.2 based hardware.
    Recently I increased the amount of data that is sent from Teensy over SerialUSB to ~150bytes, 4 times a second. This seems to have caused entering the program mode to reliably fail:
    Quote Originally Posted by platformio.exe run --target upload
    Processing teensy31 (platform: teensy; board: teensy31; framework: arduino)
    Verbose mode can be enabled via `-v, --verbose` option
    CONFIGURATION: https://docs.platformio.org/page/boards/teensy/teensy31.html
    PLATFORM: Teensy (4.12.0) > Teensy 3.1 / 3.2
    HARDWARE: MK20DX256 72MHz, 64KB RAM, 256KB Flash
    DEBUG: Current (jlink) External (jlink)
    PACKAGES:
     - framework-arduinoteensy 1.153.0 (1.53)
     - tool-teensy 1.152.200516 (1.52)
     - toolchain-gccarmnoneeabi 1.50401.190816 (5.4.1)
    LDF: Library Dependency Finder -> http://bit.ly/configure-pio-ldf
    LDF Modes: Finder ~ chain, Compatibility ~ soft
    Found 93 compatible libraries
    Scanning dependencies...
    Dependency Graph
    |-- <AceRoutine> 1.3.1
    |   |-- <AceCommon> 1.4.5
    |-- <i2c_t3>
    Building in release mode
    Linking .pio\build\teensy31\firmware.elf
    Building .pio\build\teensy31\firmware.hex
    Checking size .pio\build\teensy31\firmware.elf
    Advanced Memory Usage is available via "PlatformIO Home > Project Inspect"
    RAM:   [=         ]  10.9% (used 7176 bytes from 65536 bytes)
    Flash: [==        ]  20.3% (used 53172 bytes from 262144 bytes)
    Configuring upload protocol...
    AVAILABLE: jlink, teensy-cli, teensy-gui
    CURRENT: upload_protocol = teensy-gui
    Uploading .pio\build\teensy31\firmware.hex
    Unable to open COM3 for reboot request
      Windows Error Info: Access is denied.
      more ideas... https://forum.pjrc.com/threads/40632?p=126667&viewfull=1#post126667
    Teensy did not respond to a USB-based request to enter program mode.
    After the first line "Uploading ..." is displayed, the Teensy loader app sits on this screen for ~6 seconds:
    Name:  Teensy Loader.png
    Log:
    Quote Originally Posted by Teensy Loader Verbose Info
    18:08:47.623 (post_compile 163): Begin, version=1.52, high-res time
    18:08:47.624 (loader): remote connection 1452 opened
    18:08:47.625 (loader): remote cmd from 1452: "comment: Teensyduino 1.52 - WINDOWS (teensy_post_compile)"
    18:08:47.626 (post_compile 163): Sending command: comment: Teensyduino 1.52 - WINDOWS (teensy_post_compile)
    18:08:47.626 (loader): remote cmd from 1452: "status"
    18:08:47.627 (loader): file changed
    18:08:47.642 (loader): File "firmware.hex". 53184 bytes, 20% used
    18:08:47.649 (loader): remote cmd from 1452: "dir:C:\Users\camer\git\Firmware\.pio\build\teensy31\"
    18:08:47.650 (post_compile 163): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:47.650 (post_compile 163): Sending command: dir:C:\Users\camer\git\Firmware\.pio\build\teensy31\
    18:08:47.651 (post_compile 163): Sending command: file:firmware.hex
    18:08:47.653 (loader): remote cmd from 1452: "file:firmware.hex"
    18:08:47.668 (loader): File "firmware.hex". 53184 bytes, 20% used
    18:08:47.674 (loader): remote cmd from 1452: "status"
    18:08:47.678 (post_compile 163): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:47.678 (post_compile 163): Disconnect
    18:08:47.688 (loader): remote connection 1452 closed
    18:08:47.689 (post_compile 164): Running teensy_reboot: "C:\Users\camer\.platformio\packages\tool-teensy\teensy_reboot.exe" teensy_reboot.exe "-board=TEENSY31"
    18:08:47.690 (loader): remote connection 1452 opened
    18:08:47.714 (reboot 165): Begin, version=1.52, high-res time
    18:08:47.714 (reboot 165): LoadLibrary cfgmgr32 ok
    18:08:47.714 (reboot 165): LoadLibrary ntdll ok
    18:08:47.716 (reboot 165): found_usb_device, id=\\?\usb#vid_16c0&pid_0483#4294967295#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    18:08:47.716 (reboot 165): found_usb_device, loc=usb:0/140000/0/1/3/3    Port_#0003.Hub_#0009
    18:08:47.716 (reboot 165): found_usb_device, hwid=USB\VID_16C0&PID_0483&REV_0275
    18:08:47.716 (reboot 165): found_usb_device, devinst=0000000a
    18:08:47.716 (reboot 165): add: loc=usb:0/140000/0/1/3/3, class=Ports, vid=16C0, pid=0483, ver=0275, serial=4294967295, dev=\\?\usb#vid_16c0&pid_0483#4294967295#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    18:08:47.716 (reboot 165):   comport_from_devinst_list attempt
    18:08:47.716 (reboot 165):   found Ports in classguid_list at index=0
    18:08:47.716 (reboot 165):   port COM3 found from devnode
    18:08:47.716 (reboot 165): found_usb_device complete
    18:08:47.720 (loader): remote connection 1424 opened
    18:08:47.722 (loader): remote cmd from 1424: "show:arduino_attempt_reboot"
    18:08:47.723 (reboot 165): found Teensy Loader, version 1.52
    18:08:47.723 (reboot 165): Sending command: show:arduino_attempt_reboot
    18:08:47.724 (loader): got request to show arduino rebooting message
    18:08:47.728 (loader): remote cmd from 1424: "comment: Teensyduino 1.52 - WINDOWS (teensy_reboot)"
    18:08:47.729 (reboot 165): Sending command: comment: Teensyduino 1.52 - WINDOWS (teensy_reboot)
    18:08:47.732 (loader): remote cmd from 1424: "status"
    18:08:47.736 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:47.736 (reboot 165): do_reset (serial) COM3
    18:08:47.737 (loader): remote cmd from 1424: "status"
    18:08:47.741 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:47.741 (reboot 165): status read, retry 0
    18:08:47.841 (loader): remote cmd from 1424: "status"
    18:08:47.850 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:47.850 (reboot 165): status read, retry 1
    18:08:47.951 (loader): remote cmd from 1424: "status"
    18:08:47.957 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:47.957 (reboot 165): status read, retry 2
    18:08:48.057 (loader): remote cmd from 1424: "status"
    18:08:48.062 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:48.062 (reboot 165): status read, retry 3
    18:08:48.163 (loader): remote cmd from 1424: "status"
    18:08:48.167 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:48.167 (reboot 165): status read, retry 4
    18:08:48.268 (loader): remote cmd from 1424: "status"
    18:08:48.272 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:48.272 (reboot 165): status read, retry 5
    18:08:48.373 (loader): remote cmd from 1424: "status"
    18:08:48.376 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:48.376 (reboot 165): status read, retry 6
    18:08:48.476 (loader): remote cmd from 1424: "status"
    18:08:48.480 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:48.480 (reboot 165): status read, retry 7
    18:08:48.580 (loader): remote cmd from 1424: "status"
    18:08:48.584 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:48.584 (reboot 165): status read, retry 8
    18:08:48.684 (loader): remote cmd from 1424: "status"
    18:08:48.688 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:48.688 (reboot 165): status read, retry 9
    18:08:48.789 (loader): remote cmd from 1424: "status"
    18:08:48.793 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:48.793 (reboot 165): status read, retry 10
    18:08:48.894 (loader): remote cmd from 1424: "status"
    18:08:48.900 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:48.900 (reboot 165): status read, retry 11
    18:08:49.001 (loader): remote cmd from 1424: "status"
    18:08:49.005 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:49.005 (reboot 165): status read, retry 12
    18:08:49.105 (loader): remote cmd from 1424: "status"
    18:08:49.111 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:49.111 (reboot 165): status read, retry 13
    18:08:49.212 (loader): remote cmd from 1424: "status"
    18:08:49.220 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:49.220 (reboot 165): status read, retry 14
    18:08:49.320 (loader): remote cmd from 1424: "status"
    18:08:49.329 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:49.329 (reboot 165): status read, retry 15
    18:08:49.430 (loader): remote cmd from 1424: "status"
    18:08:49.439 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:49.439 (reboot 165): status read, retry 16
    18:08:49.540 (loader): remote cmd from 1424: "status"
    18:08:49.548 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:49.548 (reboot 165): status read, retry 17
    18:08:49.649 (loader): remote cmd from 1424: "status"
    18:08:49.658 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:49.658 (reboot 165): status read, retry 18
    18:08:49.759 (loader): remote cmd from 1424: "status"
    18:08:49.764 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:49.764 (reboot 165): status read, retry 19
    18:08:49.864 (loader): remote cmd from 1424: "status"
    18:08:49.870 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:49.870 (reboot 165): status read, retry 20
    18:08:49.971 (loader): remote cmd from 1424: "status"
    18:08:49.975 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:49.975 (reboot 165): status read, retry 21
    18:08:50.076 (loader): remote cmd from 1424: "status"
    18:08:50.084 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:50.084 (reboot 165): status read, retry 22
    18:08:50.185 (loader): remote cmd from 1424: "status"
    18:08:50.192 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:50.192 (reboot 165): status read, retry 23
    18:08:50.293 (loader): remote cmd from 1424: "status"
    18:08:50.300 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:50.300 (reboot 165): status read, retry 24
    18:08:50.401 (loader): remote cmd from 1424: "status"
    18:08:50.411 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:50.411 (reboot 165): status read, retry 25
    18:08:50.511 (loader): remote cmd from 1424: "status"
    18:08:50.524 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:50.524 (reboot 165): status read, retry 26
    18:08:50.625 (loader): remote cmd from 1424: "status"
    18:08:50.634 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:50.634 (reboot 165): status read, retry 27
    18:08:50.735 (loader): remote cmd from 1424: "status"
    18:08:50.741 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:50.741 (reboot 165): status read, retry 28
    18:08:50.841 (loader): remote cmd from 1424: "status"
    18:08:50.854 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:50.854 (reboot 165): status read, retry 29
    18:08:50.955 (loader): remote cmd from 1424: "status"
    18:08:50.961 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:50.961 (reboot 165): status read, retry 30
    18:08:51.062 (loader): remote cmd from 1424: "status"
    18:08:51.070 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:51.070 (reboot 165): status read, retry 31
    18:08:51.171 (loader): remote cmd from 1424: "status"
    18:08:51.177 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:51.177 (reboot 165): status read, retry 32
    18:08:51.277 (loader): remote cmd from 1424: "status"
    18:08:51.285 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:51.285 (reboot 165): status read, retry 33
    18:08:51.385 (loader): remote cmd from 1424: "status"
    18:08:51.392 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:51.392 (reboot 165): status read, retry 34
    18:08:51.493 (loader): remote cmd from 1424: "status"
    18:08:51.499 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:51.499 (reboot 165): status read, retry 35
    18:08:51.600 (loader): remote cmd from 1424: "status"
    18:08:51.609 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:51.609 (reboot 165): status read, retry 36
    18:08:51.710 (loader): remote cmd from 1424: "status"
    18:08:51.718 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:51.718 (reboot 165): status read, retry 37
    18:08:51.819 (loader): remote cmd from 1424: "status"
    18:08:51.827 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:51.827 (reboot 165): status read, retry 38
    18:08:51.928 (loader): remote cmd from 1424: "status"
    18:08:51.935 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:51.935 (reboot 165): status read, retry 39
    18:08:52.036 (loader): remote cmd from 1424: "status"
    18:08:52.045 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:52.045 (reboot 165): status read, retry 40
    18:08:52.145 (loader): remote cmd from 1424: "status"
    18:08:52.153 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:52.153 (reboot 165): status read, retry 41
    18:08:52.254 (loader): remote cmd from 1424: "status"
    18:08:52.260 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:52.260 (reboot 165): status read, retry 42
    18:08:52.360 (loader): remote cmd from 1424: "status"
    18:08:52.368 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:52.368 (reboot 165): status read, retry 43
    18:08:52.469 (loader): remote cmd from 1424: "status"
    18:08:52.475 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:52.475 (reboot 165): status read, retry 44
    18:08:52.575 (loader): remote cmd from 1424: "status"
    18:08:52.583 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:52.583 (reboot 165): status read, retry 45
    18:08:52.684 (loader): remote cmd from 1424: "status"
    18:08:52.689 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:52.689 (reboot 165): status read, retry 46
    18:08:52.789 (loader): remote cmd from 1424: "status"
    18:08:52.795 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:52.795 (reboot 165): status read, retry 47
    18:08:52.895 (loader): remote cmd from 1424: "status"
    18:08:52.903 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:52.903 (reboot 165): status read, retry 48
    18:08:53.004 (loader): remote cmd from 1424: "status"
    18:08:53.010 (reboot 165): Status: 1, 1, 0, 38, 0, 0, C:\Users\camer\git\Firmware\.pio\build\teensy31\, firmware.hex
    18:08:53.010 (reboot 165): status read, retry 49
    18:08:53.111 (reboot 165): Teensy did not respond to a USB-based request to automatically reboot.
    18:08:53.125 (loader): remote connection 1424 closed
    18:08:53.155 (loader): remote connection 1452 closed
    Curiously, the log does not fill "linearly". The "(loader)" outputs appear on my screen one at a time, as the arrive, as confirmed by timestamps. Once it gives up retrying, the other lines appear and get interleaved.
    If I slow down my status line prints, it uploads more reliably.
    I start the upload while the serial monitor is open. I can see the serial monitor close. Curiously, after the programming "fails", PlatformIO reports "Success" and then restarts the serial monitor. However I can see clearly that my "sketch" has not restarted since the initialization outputs don't happen (and it waits for Serial, with 10 sec timeout, at start).
    24,824
    I see "version=1.52" in the verbose info log. Maybe give 1.54 a try?
    Teensyduino 1.54 did fix a long-standing issue with use of volatile on the USB buffer descriptor table, possibly affecting all Teensy 3.x boards. Hard to say if that will make any difference, but I can at least confirm 1.54 has a bug fix which might matter. It's worth a try.
    Senior Member CorBee's Avatar
    Jun 2018
    Netherlands
    506
    To use the latest 1.54 the platformio.ini file needs to have this line:
    platform = https://github.com/platformio/platform-teensy.git
    otherwise it will use 1.53 (current default stable version).
    cheers
    Cor
    Aug 2018
    Brisbane, Australia
    69
    Quote Originally Posted by CorBee View Post
    cheers
    Cor
    Actually the platformio framework-arduinoteensy was updated to 1.154.0 yesterday
    Jun 2018
    Netherlands
    506
    Quote Originally Posted by thebigg View Post
    Actually the platformio platform-teensy was updated yesterday
    Then the user probably needs to update pio core ? Or do these updates automagically appear ?
    Aug 2018
    Brisbane, Australia
    69
    Undo the platform= override in platformio.ini then run
    pio platform update
    Aug 2018
    Brisbane, Australia
    69
    If you are using the platformio plugin in vscode and you have configured it to show PIO Home at startup, then you can check for updates by selecting Platforms / Updates which will update it on demand. PIO Home also checks periodically (weekly?) for platform and library updates and notifies you if anything is not up to date...
    Lightbulb It was Windows the whole time
    Thank you all for the replies. I tried updating to 1.54 but, unfortunately, that did not fix the problem.
    Looking into it more, I noticed that if I ran the upload twice, it would pretty reliably work. That got me thinking, it could just be something weird with the serial port and Windows. We are getting an "Access Denied" error after all...
    In searching for why PlatformIO wasn't using the GitHub version... I noticed a way to run some python before uploading.
    I put in a 1 second delay. No joy. 2 seconds. No luck. Let's go for the moon, 10 seconds. WHAT? Works!
    Turns out even though the serial monitor was closed automatically by the PlatformIO VS Code extension, it was still "using" the port for like 3 seconds!
    I expanded on the script to explore some more. Turns out larger builds would take long enough to give the COM port enough time to close. Some short builds, basically with the intent of sending a software reset, would reliably be too short. I've gotten it to take over 3 seconds in certain situations to have the old COM port be "let go".
    Anyway, the next question is, is this worth dealing with in Teensy Loader? Maybe an "Access Denied" error is only fatal after a ~10 second timeout? Or should this be filed as a PlatformIO bug?
    Oh, and before I forget:
    extra_script.py
    Import("env")
    from time import sleep, monotonic
    import os
    from serial import Serial
    import configparser
    config = configparser.ConfigParser()
    config.read(env["PROJECT_CONFIG"])
    port = config["env:" + env["PIOENV"]]["monitor_port"]
    def before_upload(source, target, env):
        # Maybe this is just a Windows thing?
        if os.name != "nt":
            return
        print(f"Trying to open serial port, {port}, repeatedly, until we can.")
        tries = 0
        start = monotonic()
        while True:
            try:
                with Serial(port, 9600):
                    break
            except:
                tries += 1
                # Be nice
                sleep(0.01)
        duration = monotonic() - start
        print(f"It took {tries} tries, in {duration:.2f}s, for {port} to become available.")
    env.AddPreAction("upload", before_upload)
    And in platformio.ini:
    extra_scripts =
      extra_script.py
    Last edited by cinderblock; 07-29-2021 at 09:03 AM. Reason: Automatically get monitor_port
    Germany
    1,607
    You can also give the TyTools a try. They combine uploading and a serial monitor which should prevent such stuff. TyCommander is also able to handle multiple Teensies in parallel has buttons to reset / reboot the boards ans shows general info about the connected Teensies. https://github.com/Koromix/tytools.
    Here a instruction how to integrate it to PIO: https://www.gitmemory.com/issue/Koro...s/63/761178889
Name:	Screenshot 2021-07-29 105328.gif
    Updated version of the wait script for PlatformIO. Handles certain errors more cleanly.
    from typing import Any, TYPE_CHECKING
    if TYPE_CHECKING:
        Import: Any = None
        env: Any = {}
    Import("env")
    import os
    import configparser
        # Only tested on Windows
        if os.name != "nt":
            return
        tries = 0
        start = monotonic()
        while True:
            try:
                with open(port):
                    break
            except IOError as e:
                # File not found
                if e.errno == 2:
                    # print("Port does not exist.")
                    break
                # Permission denied
                if e.errno == 13:
                    # This is the error we're waiting for
                    tries += 1
                    # Be nice
                    sleep(0.01)
                    # Repeat until we can open it
                    continue
                # Other exceptions we don't know about
                raise e
        if tries != 0:
            status = f"It took {tries} tries, in {duration:.2f}s, for {port} to become available."
            print(status)
        print("Good to go!")
