Results 1 to 5 of 5
Thread: How to make the physical stack more reasonable?
    May 2015
    436
    Anyone have a good header option for plugging the the Teensy into the audio board and having a small board with a connector on top of the Teensy? I am trying to get away from a pcb - audio card- Teensy- pcb stack and just hook the Audio in and out up with a ribbon another cable.
    Jul 2020
    1,187
    Wouldn't that just need stacking headers for the Teensy?
    May 2015
    436
    Wouldnít that mean soldering in the Teensy to the audio board? Itís for work and would like everything to be as easy as possible to replace because of the abuse it will likely take. I guess itís their buck they could buy both. 🤷*♀️
    4,089
    Posts from Paul have indicated for the Teensy 4.0/4.1, it is generally better that the path between the Teensy and the audio board be as short as possible (i.e. don't use ribbon cable).
    As MartT says using stacking headers is one solution.
    • If you are going to solder connections to the bottom of the board, it is best to do that first before adding the connectors;
    • Unfortunately, the ethernet pins on the Teensy 4.1are are too close to the walls of the stacking pins;
    • If you mount the Teensy audio adapter n top of the Teensy, you loose access to the Teensy reset button (Teensy 3.2 and 4.0), USB host pins (Teensy 3.6 and 4.1), the back row pins (Teensy 3.2 and 4.0), and the special analog pins (Teensy 3.2, 3.5. and 3.6);
    • If you mount the Teensy audio adapter underneath the Teensy, you have the last 10 pins hanging out in space for the larger boards (Teensy 3.5, 3.6, and 4.1).
    Sparkfun has a set of stacking headers just the right size for the Teensy 3.5, 3.6, and 4.1 (note, for the 5 pin header, you will typically want to clip the pins so that it doesn't stack since the normal breadboard does not have special pinouts for those pins):
    Adafruit has a set of stacking headers just the right size for the Teensy 3.2 and 4.0:
    Generally what I do is buy larger stacking headers, and cut them down to the 14 pin or 24 pins as needed. I use a diagonal cutter, first taking out the next pin.I use a rotary tool to smooth down the cut. Buy more than you need. I usually mess up one by cutting too close to the last pin:
    Another option is to get a prototype board with dual sets of pins, and connect the first 14 rows on each side, so you can mount the Teensy and Audio Adapter in parallel:
    Quote Originally Posted by DaQue View Post
    Wouldn’t that mean soldering in the Teensy to the audio board? It’s for work and would like everything to be as easy as possible to replace because of the abuse it will likely take. I guess it’s their buck they could buy both. ��*♀️
    You could do that. Or you could solder stacking headers to the Teensy board and either stacking headers or regular male headers to the Audio board. Then you can attach the audio board to the Teensy and remove it as necessary. It would be nice if somebody offered a Teensy with stacking headers soldered in instead of either normal male headers or no headers. Likewise it would be nice if the audio board had an option to add the headers.
    14,892
    There are nice quality Low Profile headers @somebody linked and ProtoSupplies did a bulk order and has them :
    protosupplies.com/product/header-set-low-profile-1x14-breakaway-gold-4-pack/
    and
    protosupplies.com/product/header-set-low-profile-1x24-breakaway-gold-4-pack/
    Higher cost - but they stack short - didn't put any under Audio board yet - but stack height will be over spacer of direct solder that is too close.
    Both M & F are breakable and come in header-set-low-profile-1x40-breakaway-gold/ also available - but above 'sets' are pre broken to length for Teensy at 14 and 24 pins.
Tags for this Thread
