Getting the number of files in an SD card - Teensy 4.0 and Audio Shield
Taemin
I am trying to get the number of files in an SD card using the SD.h library. I am using Teensy 4.0 and the Audio Shield. There are 4 .wav files in my 16GB SD card but for some reason, the output(which shows the number each time it goes through one file and shows the final number at the end) stops at 2 and shows "Detected files: " without the D, e, and the number missing.
AudioInputI2S            i2s1;           //xy=530,578
AudioAnalyzeNoteFrequency notefreq;       //xy=995,569
AudioConnection          patchCord1(i2s1, 0, notefreq, 0);
AudioControlSGTL5000     sgtl5000_1;     //xy=769,647
#define SDCARD_CS_PIN    10
#define SDCARD_MOSI_PIN  7
#define SDCARD_SCK_PIN   14
File file;
int fileNum = 0;
  delay(250);
  AudioMemory(200);
  delay(250);
  sgtl5000_1.enable();
  sgtl5000_1.inputSelect(AUDIO_INPUT_LINEIN);
  SPI.setMOSI(SDCARD_MOSI_PIN);
  SPI.setSCK(SDCARD_SCK_PIN);
    while (1) {
  file = SD.open("/");
  reloadFileList();
void reloadFileList() {
  while(true) {
    File entry =  file.openNextFile();
    if(entry.isDirectory()) {
      fileNum ++;
      Serial.println(fileNum);
    if (!entry) {
      Serial.println("Detected files: " + fileNum);
    entry.close();
Anyone know why?
Does
  while(true) {
    if (!entry) {
    if(!entry.isDirectory()) {
      fileNum ++;
    entry.close();
behave differently?
note: if entry is directory I did not count it as file
It did behave differently. Now it does count up to 4, but the final output is still weird. On my original question, I forgot to attach a photo but this is what I meant
Thanks now it works. I wonder why it did that. Maybe it had a problem adding string and int together
