Sandro
Hi all,
I've recently installed Arduino 1.8.15 with Teensyduino 1.54; using T4.1@600MHz, when I try to compile an audio application (I also checked standard examples like WavFilePlayer, SamplePlayer, and others) I get this error:
Has anyone encountered this problem?
Thanks in advance
In file included from C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\synth_simple_drum.h:31:0,
from C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\synth_simple_drum.cpp:27:
C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/AudioStream.h: In member function 'float AudioStream::processorUsage()':
C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/AudioStream.h:111:142: error: 'F_CPU_ACTUAL' was not declared in this scope
#define CYCLE_COUNTER_APPROX_PERCENT(n) (((float)((uint32_t)(n) * 6400u) * (float)(AUDIO_SAMPLE_RATE_EXACT / AUDIO_BLOCK_SAMPLES)) / (float)(F_CPU_ACTUAL))
C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/AudioStream.h:145:38: note: in expansion of macro 'CYCLE_COUNTER_APPROX_PERCENT'
float processorUsage(void) { return CYCLE_COUNTER_APPROX_PERCENT(cpu_cycles); }
C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/AudioStream.h: In member function 'float AudioStream::processorUsageMax()':
C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/AudioStream.h:146:41: note: in expansion of macro 'CYCLE_COUNTER_APPROX_PERCENT'
float processorUsageMax(void) { return CYCLE_COUNTER_APPROX_PERCENT(cpu_cycles_max); }
C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/AudioStream.h: In static member function 'static void AudioStream::update_all()':
C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/AudioStream.h:165:50: error: 'IRQ_SOFTWARE' was not declared in this scope
static void update_all(void) { NVIC_SET_PENDING(IRQ_SOFTWARE); }
C:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy4/AudioStream.h:165:62: error: 'NVIC_SET_PENDING' was not declared in this scope
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\synth_simple_drum.cpp: In member function 'void AudioSynthSimpleDrum::noteOn()':
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\synth_simple_drum.cpp:35:17: error: '__disable_irq' was not declared in this scope
__disable_irq();
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\synth_simple_drum.cpp:42:16: error: '__enable_irq' was not declared in this scope
__enable_irq();
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\synth_simple_drum.cpp: In member function 'void AudioSynthSimpleDrum::secondMix(float)':
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\synth_simple_drum.cpp:60:17: error: '__disable_irq' was not declared in this scope
__disable_irq();
C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio\synth_simple_drum.cpp:63:16: error: '__enable_irq' was not declared in this scope
__enable_irq();
Thanks in advance
