Results 1 to 1 of 1
Thread: TDM using the odd channels for 24 bit audio
    Aug 2016
    Australia
    204
    I'm working on an 8x8 matrix mixer using my updated CS42448 board (see https://forum.pjrc.com/threads/58836...ed-performance)
    As per the instructions I'm only using the even TDM channels.
    I'm wondering whether there's any intelligence in the odd channels that can be used to regenerate 24 bit audio. I seem to remember a comment somewhere that the odd channels contain the low 8 bits shifted up, but can't find it again now.
    It wouldn't take much effort to convert macaba's crosspoint mixer code https://forum.pjrc.com/threads/43752-Crosspoint-Mixer? to TDM x 16 : 8 x 24 bit matrix : TDM x 16, as long as there's no other processing to be done.
    Just connecting the odd channels across from TDMin to TDMout doesn't seem to change much:
    24 bit (odd and even) Rightmark results (the THD + N figures are anomalous, as I had the input level at the onset of overload to maximise dynamic range. With the input 3 dB lower, THD+N is at -95dB):
Name:	24 bit tdm.png
    16 bit (even only):
Name:	16 bit tdm.png
    BTW, straight through, my Focusrite audio interface has more dynamic range, so I'm not caught with its limitations.
