Results 1 to 13 of 13
Thread: is my Teensy broken or Pins behaving strangely
    Aug 2021
    5
    hi there, i'm new to this forum and programming.
    I have a teensy 4.0 and the issue is:
    (non working code below, baut please follow this principle
    i have 16 pushbuttons attached to the teensy.
    the buttons should count up a variable (looperStati) with each press.
    The code works, but on pins 6, 9, 10 and 13 the Variable always starts with 1!, not with 0.
    or: with i++ always one more than it should be.
    i tried different codes
    swapped button.
    same result.
    Even weirder: when reset, everything except 6,9,10,13 works
    after powerOn: every pini is one too hight!
    ideas?
    HTML Code:
    String schalter [] = {"LO1", "LO2", "LO3", "LO4", "PB1", "PB2", "PB3", "PB4", "SO1", "SO2", "SO3", "SO4", "FX1", "FX2", "CLR", "S16"};
    bool schalterA [16];
    unsigned long timers [16];
    unsigned long longClick = 700;
    byte looperStati [16];
    void looperDown (int i){
          timers[i] = millis();
    void looperUp (int i){
      if ((millis() - timers[i]) < longClick) {
        if (looperStati[i] == 0) {
            Serial.print (schalter[i]);
            Serial.println (" Recording");
            looperStati[i]++;
        else if (looperStati[i] == 1) {
            Serial.println (" Playing");
            looperStati[i]++;
        else if (looperStati[i] == 2) {
            Serial.println (" Stopped");
            looperStati[i]++;
         else if (looperStati[i] == 3) {
            looperStati[i]++;
        else if (looperStati[i] == 4) {
            looperStati[i] = 3;
    if (((millis() - timers[i]) >= longClick) && looperStati[i] >= 3) {
          looperStati[i] = 1;
      for(int i=0; i<16; i++){
        pinMode(i+5, INPUT_PULLUP);
        schalterA[i] = HIGH;
        looperStati[i] = 0;
      for (int i = 0; i < 16; i++)
        bool inputVal = digitalRead(i + 5);
        if (schalterA[i] != inputVal)
          schalterA[i] = inputVal;
          //Serial.println(schalter[i]);
          if (inputVal)
            looperUp (i);
            looperDown (i);
    Jul 2021
    7
    I'm not exactly sure, but I think your code might be plagued by chatter - check out https://www.pjrc.com/teensy/td_libs_Bounce.html for more info.
    1,750
    Shouldn't that be > or >= ?
    As it is, it will respond to contact bounce (chatter). As @wootie11 suggests, have a look at the Bounce library and let it handle the bouncing contacts.
    Pete
    Aug 2021
    5
    hi @Wootie11 , hi el supremo, thanks for your reply,
    my buttons are hardware debounced with a RC-network.
    I checked with the bounce-checker behind the link wootie posted.
    No chatter.
    BUT: have a look at thisClick image for larger version.
Name:	Bildschirmfoto 2021-08-03 um 20.00.20.png
    pin 6 starts at 2.
    And could chatter be an explanation for EVERY switch to start at 2 AFTER Power up and at 1 after reset with button?
    puzzled...
    1,750
    That is the problem. The click sequence seems to make sense once that change is made. It might also help to reduce longClick to something like 100 (or even less).
    Pete
    Germany
    9,333
    How does your RC Network look like? Can you post a schematic?
    Aug 2021
    5
    input pin is internal pullup, pushbutton connects to ground,
    1K Resistor between switch and Input, 0.1uF capacitor from pin (and resistor) to ground.
    Germany
    9,333
    Quote Originally Posted by Llevelynn View Post
    Yes, this is why you see the different behaviour between power on and reset.
    The cap needs some time to load on power on (you use "pullup"). After a reset it is loaded already.
    Just add a delay to setup() to make it consistent for poweron/reset - after pinMode()
    Aug 2021
    5
    Ok, that makes sense!
    thanks a lot
    but does not explain the behaviour of pin 6,9,10,13, I think.
    I swapped the switches, swapped the Capacitors, tried without Capacitors...
    Is there something different to these Pins that might require different Cap/Res Values?
    strange stuff
    Germany
    9,333
    thanks a lot
    strange stuff
    Do they work if you disconnect the caps, resistors and buttons? use a wire and short them to ground then, to test it.
    Germany
    9,333
    What means "recording" in your progrm. Is there something else connected?
    1,750
    I figured out why you had 700ms for the longClick so ignore my comments in message #5.
    I've added code to use the Bounce library and it works well on a T4 here.
    If you use the Bounce library you can get rid of the external RC components.
    As far as I can see, there is no reason for there to be anything special about any of the pins (6,9,10,13) except that pin 13 already has the builtin LED on it which can sometimes cause problems when it is used for other purposes.
    // Add Bounce library
    #include <Bounce.h>
    Bounce *buttons[16];
    // debounce period in milliseconds
    const int ms = 10;
          looperStati[i]++;
        } else if (looperStati[i] == 1) {
          looperStati[i]++;
        } else if (looperStati[i] == 2) {
          looperStati[i]++;
        } else if (looperStati[i] == 3) {
          looperStati[i]++;
        } else if (looperStati[i] == 4) {
          looperStati[i] = 3;
        looperStati[i] = 1;
      for(int i=0; i<16; i++) {
        looperStati[i] = 0;
        // Add a Bounce object for each button
        buttons[i] = new Bounce(i+5,ms);
      delay(2000);
      Serial.println("Start");
      // Update each button
      for(int i = 0; i < 16; i++) {
        buttons[i]->update();
        if(buttons[i]->risingEdge()) looperUp (i);
        if(buttons[i]->fallingEdge())looperDown(i);
    Pete
    Aug 2021
    5
    thanks everyone, i Will test the whole thing again without my debouncing circuits and the Software debounce.
    If I ever find the time, that is...
