Krischomat
Trying to get the Grain Generator of the Faust IDE´s examples running. But I cannot get control of the parameters. Here is the Faust Code:
And this is the Teensy Code:
I tried to use the Analog Ins that are declared in the Faust Code (A0, A1, A2, A3) without doing anything about it in the Teensy code but it is not working. And I tried to controll the parameters by delcalaring it in the Teensy code, which is commented out in the code here. There one knob was actually doing something...
Whats the way here? I already hear the Audio that I routed through the GrainGenerator object and it is doing something to the Audio.
// Grain Generator.
// Another granular synthesis example.
// This one is not finished, but ready for more features and improvements...
// ANALOG IN:
// ANALOG 0 : Population: 0 = almost nothing. 1 = Full grain
// ANALOG 1 : Depth of each grain, in ms.
// ANALOG 2 : Position in the table = delay
// ANALOG 3 : Speed = pitch change of the grains
// ANALOG 4 : Feedback
import("all.lib");
// FOR 4 grains - MONO
// UI //////////////////////////////////////////
popul = 1 - hslider("population[BELA: ANALOG_0]", 1, 0, 1, 0.001); // Coef 1 = maximum; 0 = almost nothing (0.95)
taille = hslider("taille[BELA: ANALOG_1]", 100, 4, 200, 0.001 ); // Size in milliseconds
decal = 1 - hslider("decal[BELA: ANALOG_2]",0,0,1,0.001); // Read position compared to table write position
speed = hslider("speed[BELA: ANALOG_3]", 1, 0.125, 4, 0.001);
feedback = hslider("feedback[BELA: ANALOG_4]",0,0,2,0.001);
freq = 1000/taille;
tmpTaille = taille*ma.SR/ 1000;
clocSize = int(tmpTaille + (tmpTaille*popul*10)); // duration between 2 clicks
// CLK GENERAL /////////////////////////////////
// 4 clicks for 4 grains generators.
// (idem clk freq/4 and a counter...)
detect1(x) = select2 (x < 10, 0, 1);
detect2(x) = select2 (x > clocSize*1/3, 0, 1) : select2 (x < (clocSize*1/3)+10, 0, _);
detect3(x) = select2 (x > clocSize*2/3, 0, 1) : select2 (x < (clocSize*2/3)+10, 0, _);
detect4(x) = select2 (x > clocSize-10, 0, 1);
cloc = (%(_,clocSize))~(+(1)) <: (detect1: trig),(detect2: trig),(detect3: trig),(detect4: trig);
// SIGNAUX Ctrls Player ////////////////////////
trig = _<:_,mem: >;
envelop = *(2*PI):+(PI):cos:*(0.5):+(0.5);
rampe(f, t) = delta : (+ : select2(t,_,delta<0) : max(0)) ~ _ : raz
with {
raz(x) = select2 (x > 1, x, 0);
delta = sh(f,t)/ma.SR;
sh(x,t) = ba.sAndH(t,x);
rampe2(speed, t) = delta : (+ : select2(t,_,delta<0) : max(0)) ~ _
with {
delta = sh(speed,t);
// RWTable //////////////////////////////////////
unGrain(input, clk) = (linrwtable(wf , rindex) : *(0.2 * EnvGrain))
with {
SR = 44100;
buffer_sec = 1;
size = int(SR * buffer_sec);
init = 0.;
EnvGrain = clk : (rampe(freq) : envelop);
windex = (%(_,size) ) ~ (+(1));
posTabl = int(ba.sAndH(clk, windex));
rindex = %(int(rampe2(speed, clk)) + posTabl + int(size * decal), size);
wf = size, init, int(windex), input;
// LINEAR_INTERPOLATION_RWTABLE //////////////////////////////////
// read rwtable with linear interpolation
// wf : waveform to read (wf is defined by (size_buffer,init, windex, input))
// x : position to read (0 <= x < size(wf)) and float
// nota: rwtable(size, init, windex, input, rindex)
linrwtable(wf,x) = linterpolation(y0,y1,d)
with {
x0 = int(x); //
x1 = int(x+1); //
d = x-x0;
y0 = rwtable(wf,x0); //
y1 = rwtable(wf,x1); //
linterpolation(v0,v1,c) = v0*(1-c)+v1*c;
// FINALISATION /////////////////////////////////////////////////////////////////////////////////////
routeur(a, b, c, d, e) = a, b, a, c, a, d, a, e;
processus = _, cloc : routeur : (unGrain, unGrain, unGrain, unGrain) :> fi.dcblockerat(20);
process = _,_: ((+(_,_) :processus) ~(*(feedback))),((+(_,_) :processus) ~(*(feedback)));
#include <Bounce.h>
#include "GrainGenerator.h"
GrainGenerator grain;
AudioInputI2S in;
AudioOutputI2S out;
AudioConnection patchCord1(in, 0, grain, 0);
AudioConnection patchCord2(in, 0, grain, 1);
AudioConnection patchCord3(grain, 0, out, 0);
AudioConnection patchCord4(grain, 1, out, 1);
AudioMemory(240);
audioShield.enable();
audioShield.volume(0.5);
float populvalue = analogRead(A10) / 1023.0;
float taillevalue = map (analogRead(A11), 0.0, 1023.0, 4.0, 200.0);
float decalvalue = analogRead(A12) / 1023.0;
float speedvalue = 1.0;
float feedbackvalue = analogRead(A13) / 511.5;
grain.setParamValue("popul",populvalue);
grain.setParamValue("taille",decalvalue);
grain.setParamValue("decal",speedvalue);
grain.setParamValue("feedbackvalue",feedbackvalue);
delay(10);
Serial.print("popul:");
Serial.print(populvalue);
Serial.print(" ");
Serial.print("taille:");
Serial.print(taillevalue);
Serial.print(" ");
Serial.print("decal:");
Serial.print(decalvalue);
Serial.print(" ");
Serial.print("feedback:");
Serial.println(feedbackvalue);
