Results 1 to 4 of 4
Thread: Vox Imperium - Pinout question (teensy 3.2)
    Aug 2021
    3
    I am making the Vox Imperium trooper amp seen here: https://learn.sparkfun.com/tutorials...ce-changer/all. I got all the parts listed, and was able to get the unit to function. But as I am trying to hide all the circuitry in the helmet, I noticed it would be real nice if the mic input could be set to pin A9 (aka 23) instead of A2 (aka 16). This way I would be able to use a 3 wire connector and hit my GND, 3v3, and Audio-In all next to each other.
    I looked at the pinouts and the different notes about the ADC, and I "think" I read correctly that I can change the following lines of code and I will be good. I just want to make sure what I am thinking is correct.
    Original Code using A2 (pin 16):
    AudioInputAnalog         adc1;
    Modified code using A9 (pin 23):
    AudioInputAnalog         adc1(A9);
    The unit I have assembled I am going to leave as-is, but I have the parts to build a 2nd module, and if this will work, I plan on making the change to that unit.
    Below is the complete code:
    AudioInputAnalog         adc1;           //xy=255,182
    AudioFilterBiquad        biquad1;        //xy=394,182
    AudioPlaySerialflashRaw  playFlashRaw1;  //xy=535,319
    AudioFilterStateVariable filter1;        //xy=558,189
    AudioAnalyzePeak         peak1;          //xy=559,255
    AudioMixer4              mixer1;         //xy=710,196
    AudioOutputAnalog        dac1;           //xy=844,196
    AudioConnection          patchCord1(adc1, biquad1);
    AudioConnection          patchCord2(biquad1, 0, filter1, 0);
    AudioConnection          patchCord3(biquad1, peak1);
    AudioConnection          patchCord4(playFlashRaw1, 0, mixer1, 2);
    AudioConnection          patchCord5(filter1, 0, mixer1, 0);
    AudioConnection          patchCord6(filter1, 2, mixer1, 1);
    AudioConnection          patchCord7(mixer1, dac1);
    // Parameters
    const bool DEBUG = false;
    const bool BEGIN_CLICK = true;  // Play click on voice start
    const bool END_SOUND = true;    // Play click/burst on voice end
    const bool FEEDBACK_SUPPRESSION = false;  // Enables input filter
    const unsigned int LOWPASS_CUTOFF = 2200; // Hz
    const unsigned int CROSSOVER_FREQ = 2000; // Filter center freq
    const float BASS_GAIN_ON = 0.01;
    const float BASS_GAIN_OFF = 0.0;
    const float TREBLE_GAIN_ON = 0.25;    // Voice output volume
    const float TREBLE_GAIN_OFF = 0.0;
    const float SFX_GAIN = 0.5;           // Sound clip volume
    const float SQUELCH_CUTOFF = 0.10;    // Voice threshold
    const int HYSTERESIS_TIME_ON = 20;    // Milliseconds
    const int HYSTERESIS_TIME_OFF = 400;  // Milliseconds
    // Pins
    const int FLASH_CS = 6;               // Serial flash chip select
    const int AMP_ENABLE = 5;             // Amplifier enable pin
    // On/Off state machine states
    typedef enum volState {
      QUIET,
      QUIET_TO_LOUD,
      LOUD,
      LOUD_TO_QUIET,
    } VolState;
    // Global variables
    elapsedMillis fps; // Sample peak only if we have available cycles
    VolState state = QUIET;
    unsigned long timer;
      if ( DEBUG ) {
      // Initialize amplifier
      AudioMemory(20);
      dac1.analogReference(EXTERNAL); // much louder!
      delay(50);                      // time for DAC voltage stable
      pinMode(AMP_ENABLE, OUTPUT);
      // wait up to 10 seconds for Arduino Serial Monitor
      unsigned long startMillis = millis();
      if ( DEBUG ) {
        while ( !Serial && ( millis() - startMillis < 10000 ) );
      // Butterworth lowpass filter (reduces audio feedback)
      if ( FEEDBACK_SUPPRESSION ) {
        biquad1.setLowpass(0, LOWPASS_CUTOFF, 0.707);
        biquad1.setLowpass(0, 8000, 0.707);
      // Configure the State Variable filter
      filter1.frequency(CROSSOVER_FREQ);
      filter1.resonance(0.707);
      // Adjust gain into the mixer
      mixer1.gain(0, BASS_GAIN_OFF);
      mixer1.gain(1, TREBLE_GAIN_OFF);
      mixer1.gain(2, SFX_GAIN);
      // Initialize serial flash
      if ( !SerialFlash.begin(FLASH_CS) ) {
        if ( DEBUG ) {
          Serial.println( "Unable to access SPI Flash chip" );
      // Use the time since boot as a seed (I know, not great, but
      // the audio toolbox took away my analogRead)
      int seed = micros() % 32767;
      if ( DEBUG ) {
        Serial.print("Seed: ");
        Serial.println(seed);
      randomSeed(seed);
      if ( DEBUG ) {
        Serial.println("Finished init");
      if ( (fps > 24) && peak1.available() ) {
        // State machine
        switch ( state ) {
          // Wait until the mic picks up some sound
          case QUIET:
            if ( peak1.read() > SQUELCH_CUTOFF ) {
              timer = millis();
              state = QUIET_TO_LOUD;
          // If sound continues, play sound effect
          case QUIET_TO_LOUD:
            if ( peak1.read() <= SQUELCH_CUTOFF ) {
              state = QUIET;
              if ( millis() > timer + HYSTERESIS_TIME_ON ) {
                if ( DEBUG ) {
                  Serial.println("ON");
                // Turn on amp, play sound, turn on mic
                digitalWrite(AMP_ENABLE, HIGH);
                if ( BEGIN_CLICK ) {
                  playFile("click.raw");
                mixer1.gain(0, BASS_GAIN_ON);
                mixer1.gain(1, TREBLE_GAIN_ON);
                // Go to next state
                state = LOUD;
          // Filter mic input and play it through speakers
          case LOUD:
              timer = millis();
              state = LOUD_TO_QUIET;
          // If no sound for a time, play click or burst
          case LOUD_TO_QUIET:
              state = LOUD;
              if ( millis() > timer + HYSTERESIS_TIME_OFF ) {
                if ( DEBUG ) {
                  Serial.println("OFF");
                // Play a random sound
                if ( END_SOUND ) {
                  if ( random(2) ) {
                    playFile("click.raw");    // orig = break.raw
                // Turn off mic and amp
                digitalWrite(AMP_ENABLE, LOW);
                state = QUIET;
          // You really shouldn't get here
          default:
    // Play a sound clip from serial flash
    void playFile( const char* filename ) {
      if ( DEBUG ) {
        Serial.print("Playing file: ");
        Serial.print(filename);
      // Start playing the file
      playFlashRaw1.play(filename);
      // A brief delay for the library read info
      delay(5);
      // Wait for the file to finish playing
      while ( playFlashRaw1.isPlaying() );
      if ( DEBUG ) {
        Serial.println("...done");
    4,090
    This is just a guess.
    I think it would work since you use the prop shield and not the audio shield. The audio shield uses pin 23/A9, so if you used the audio shield, pin 23/A9 would not be avialable. Both pin 23/A9 and 16/A2 are in the ADC0 group, so you wouldn't have to worry about using a different ADC group. But as I said, this is a guess.
    Aug 2021
    3
    Thank you. Going to try this out and reply back.
    Aug 2021
    3
    It does work. By changing the one line, I was able to get my audio input, power, and ground all next to each other for easy wiring. Thank you.
