Vox Imperium - Pinout question (teensy 3.2)
vader7071
New member
I am making the Vox Imperium trooper amp seen here: https://learn.sparkfun.com/tutorials/vox-imperium-stormtrooper-voice-changer/all. I got all the parts listed, and was able to get the unit to function. But as I am trying to hide all the circuitry in the helmet, I noticed it would be real nice if the mic input could be set to pin A9 (aka 23) instead of A2 (aka 16). This way I would be able to use a 3 wire connector and hit my GND, 3v3, and Audio-In all next to each other.
I looked at the pinouts and the different notes about the ADC, and I "think" I read correctly that I can change the following lines of code and I will be good. I just want to make sure what I am thinking is correct.
Original Code using A2 (pin 16):
AudioInputAnalog         adc1;
Modified code using A9 (pin 23):
AudioInputAnalog         adc1(A9);
The unit I have assembled I am going to leave as-is, but I have the parts to build a 2nd module, and if this will work, I plan on making the change to that unit.
Below is the complete code:
#include <SerialFlash.h>
AudioInputAnalog         adc1;           //xy=255,182
AudioFilterBiquad        biquad1;        //xy=394,182
AudioPlaySerialflashRaw  playFlashRaw1;  //xy=535,319
AudioFilterStateVariable filter1;        //xy=558,189
AudioAnalyzePeak         peak1;          //xy=559,255
AudioMixer4              mixer1;         //xy=710,196
AudioOutputAnalog        dac1;           //xy=844,196
AudioConnection          patchCord1(adc1, biquad1);
AudioConnection          patchCord2(biquad1, 0, filter1, 0);
AudioConnection          patchCord3(biquad1, peak1);
AudioConnection          patchCord4(playFlashRaw1, 0, mixer1, 2);
AudioConnection          patchCord5(filter1, 0, mixer1, 0);
AudioConnection          patchCord6(filter1, 2, mixer1, 1);
AudioConnection          patchCord7(mixer1, dac1);
// Parameters
const bool DEBUG = false;
const bool BEGIN_CLICK = true;  // Play click on voice start
const bool END_SOUND = true;    // Play click/burst on voice end
const bool FEEDBACK_SUPPRESSION = false;  // Enables input filter
const unsigned int LOWPASS_CUTOFF = 2200; // Hz
const unsigned int CROSSOVER_FREQ = 2000; // Filter center freq
const float BASS_GAIN_ON = 0.01;
const float BASS_GAIN_OFF = 0.0;
const float TREBLE_GAIN_ON = 0.25;    // Voice output volume
const float TREBLE_GAIN_OFF = 0.0;
const float SFX_GAIN = 0.5;           // Sound clip volume
const float SQUELCH_CUTOFF = 0.10;    // Voice threshold
const int HYSTERESIS_TIME_ON = 20;    // Milliseconds
const int HYSTERESIS_TIME_OFF = 400;  // Milliseconds
// Pins
const int FLASH_CS = 6;               // Serial flash chip select
const int AMP_ENABLE = 5;             // Amplifier enable pin
// On/Off state machine states
typedef enum volState {
  QUIET,
  QUIET_TO_LOUD,
  LOUD,
  LOUD_TO_QUIET,
} VolState;
// Global variables
elapsedMillis fps; // Sample peak only if we have available cycles
VolState state = QUIET;
unsigned long timer;
  if ( DEBUG ) {
  // Initialize amplifier
  AudioMemory(20);
  dac1.analogReference(EXTERNAL); // much louder!
  delay(50);                      // time for DAC voltage stable
  pinMode(AMP_ENABLE, OUTPUT);
  // wait up to 10 seconds for Arduino Serial Monitor
  unsigned long startMillis = millis();
  if ( DEBUG ) {
    while ( !Serial && ( millis() - startMillis < 10000 ) );
  // Butterworth lowpass filter (reduces audio feedback)
  if ( FEEDBACK_SUPPRESSION ) {
    biquad1.setLowpass(0, LOWPASS_CUTOFF, 0.707);
    biquad1.setLowpass(0, 8000, 0.707);
  // Configure the State Variable filter
  filter1.frequency(CROSSOVER_FREQ);
  filter1.resonance(0.707);
  // Adjust gain into the mixer
  mixer1.gain(0, BASS_GAIN_OFF);
  mixer1.gain(1, TREBLE_GAIN_OFF);
  mixer1.gain(2, SFX_GAIN);
  // Initialize serial flash
  if ( !SerialFlash.begin(FLASH_CS) ) {
    if ( DEBUG ) {
      Serial.println( "Unable to access SPI Flash chip" );
  // Use the time since boot as a seed (I know, not great, but
  // the audio toolbox took away my analogRead)
  int seed = micros() % 32767;
  if ( DEBUG ) {
    Serial.print("Seed: ");
    Serial.println(seed);
  randomSeed(seed);
  if ( DEBUG ) {
    Serial.println("Finished init");
  if ( (fps > 24) && peak1.available() ) {
    // State machine
    switch ( state ) {
      // Wait until the mic picks up some sound
      case QUIET:
        if ( peak1.read() > SQUELCH_CUTOFF ) {
          timer = millis();
          state = QUIET_TO_LOUD;
      // If sound continues, play sound effect
      case QUIET_TO_LOUD:
        if ( peak1.read() <= SQUELCH_CUTOFF ) {
          state = QUIET;
          if ( millis() > timer + HYSTERESIS_TIME_ON ) {
            if ( DEBUG ) {
              Serial.println("ON");
            // Turn on amp, play sound, turn on mic
            digitalWrite(AMP_ENABLE, HIGH);
            if ( BEGIN_CLICK ) {
              playFile("click.raw");
            mixer1.gain(0, BASS_GAIN_ON);
            mixer1.gain(1, TREBLE_GAIN_ON);
            // Go to next state
            state = LOUD;
      // Filter mic input and play it through speakers
      case LOUD:
          timer = millis();
          state = LOUD_TO_QUIET;
      // If no sound for a time, play click or burst
      case LOUD_TO_QUIET:
          state = LOUD;
          if ( millis() > timer + HYSTERESIS_TIME_OFF ) {
            if ( DEBUG ) {
              Serial.println("OFF");
            // Play a random sound
            if ( END_SOUND ) {
              if ( random(2) ) {
                playFile("click.raw");    // orig = break.raw
            // Turn off mic and amp
            digitalWrite(AMP_ENABLE, LOW);
            state = QUIET;
      // You really shouldn't get here
      default:
// Play a sound clip from serial flash
void playFile( const char* filename ) {
  if ( DEBUG ) {
    Serial.print("Playing file: ");
    Serial.print(filename);
  // Start playing the file
  playFlashRaw1.play(filename);
  // A brief delay for the library read info
  delay(5);
  // Wait for the file to finish playing
  while ( playFlashRaw1.isPlaying() );
  if ( DEBUG ) {
    Serial.println("...done");
This is just a guess.
I think it would work since you use the prop shield and not the audio shield. The audio shield uses pin 23/A9, so if you used the audio shield, pin 23/A9 would not be avialable. Both pin 23/A9 and 16/A2 are in the ADC0 group, so you wouldn't have to worry about using a different ADC group. But as I said, this is a guess.
Thank you. Going to try this out and reply back.
It does work. By changing the one line, I was able to get my audio input, power, and ground all next to each other for easy wiring. Thank you.
