Results 1 to 7 of 7
Thread: What is the frequency stability rating of the 24MHz crystal used on teensy4.0/1?
    Sep 2019
    United States
    49
    I'm working on something that requires pretty minimal drift between multiple devices.
    I'm hoping I can pull it off with a Teensy4.
    Is there a part-number/manufacturer (or just a rating) for the 24MHz crystal used on
    these boards? Specifically, I need to know the PPM rating of the main crystal and
    whether or not it is consistent across boards (i.e. is a single manufacturer with a
    specified rating used?).
    Thanks,
    May 2015
    USA
    1,071
    Mine is off by about 9 ppm. If this is an audio application and you have a reference, you can tweak the rate to be exactly correct.
    Sep 2019
    United States
    49
    I won't have a reference, just standalone teensy4 (if possible), so I'm hoping I can get the manufacturer's rating.
    I can see "2400T E8YU2" on the crystal, but can't get any info from google on that...
    Thanks,
    Senior Member PaulS's Avatar
    Apr 2015
    Netherlands
    654
    Looks very much like an EPSON FA2016AN series crystal, datasheet here.
    But only Paul Stoffregen can tell what the exact part# is that PJRC orders...
    Paul
    Apr 2015
    Netherlands
    654
    Found a message from Paul Stoffregen, mentioning "That's well within the crystal's 30 ppm spec".
    Paul
    Sep 2019
    United States
    49
    Wow, thanks for digging (more effectively than I did)!
    2,655
    FWIW, i have anecdotal data on crystal drift measured with GPS PPS on various T4s, see
    https://forum.pjrc.com/threads/54711...l=1#post195166
    your mileage may vary. of course, temperature and age can affect frequency drift.
